Super Nintendo Capacitor Replacement Guide
Revision as of 10:54, 5 May 2025 by Josh (talk | contribs) (Automated update by bot)
Replacing the electrolytic capacitors in a Super Nintendo (SNES) restores power stability, reduces video/audio noise, and prevents long-term board damage from leakage. While SNES capacitors rarely fail as spectacularly as in some earlier consoles, most units are now 30+ years old and original SMD electrolytics are at or beyond their design life—especially in humid climates.
🔍 Visual Inspection & Failure Signs
  • Leaking SMD cans – clear or brown residue, especially under or around surface-mount capacitors.
  • Corrosion or green/black pads – capacitor electrolyte is conductive and corrosive, often damaging traces.
  • Noisy audio / humming – dried-out audio rail capacitors cause background buzz or distortion.
  • Video artifacts – unstable or faded video may be caused by failed decoupling or coupling capacitors.
  • Random resets / power loss – main power filter caps with high ESR can cause intermittent operation.
If any capacitor shows signs of failure, it is strongly recommended to replace all electrolytic capacitors on the board.
📋 Super Nintendo Capacitor Lists
The SNES was produced in several board revisions. Always verify your board model and cross-check silkscreen references before ordering parts.
🖥️ SNES “1CHIP” & “SNS-CPU-GPM-02” (Typical Surface-Mount)
Super Nintendo (SNES) Electrolytic Capacitors – Common SMD Models
Board Ref Capacitance Voltage Purpose / Rail
C59 1000 µF 16 V Main +5 V input filter (power smoothing)
C58 470 µF 16 V Secondary +5 V filter (regulator output)
C60 220 µF 10 V Audio rail filter (prevents hum)
C61 10 µF 16 V Reset circuit (power-on reset timing)
C62 10 µF 16 V Video encoder decoupling
C63 10 µF 16 V Video encoder decoupling
C64 10 µF 16 V Video encoder decoupling
C65 10 µF 16 V Video encoder decoupling
C66 1 µF 50 V Audio output coupling (DC block)
C67 1 µF 50 V Audio output coupling (DC block)
Note: Some revisions use through-hole capacitors for C59/C58. Always check your board.
🛠️ Replacement Tips
  • Polarity matters! – SMD and through-hole electrolytics are polarized; match the negative stripe to the board marking.
  • Clean thoroughly – Remove all old electrolyte with isopropyl alcohol and a soft brush before installing new capacitors.
  • Use quality parts – Choose reputable brands (Nichicon, Panasonic, Rubycon) rated for 105°C and equal or higher voltage.
  • Consider solid polymer – For SMD locations, solid polymer capacitors are a durable, leak-proof upgrade.
⚡️ See Also
