Commodore VIC-20
Revision as of 07:22, 12 May 2025 by Josh (talk | contribs)
Commodore VIC-20
Commodore VIC-20 – The Friendly Computer
ManufacturerCommodore Business Machines
TypeHome Computer
Released1980 (Japan), 1981 (Worldwide)
DiscontinuedJanuary 1985
Intro priceUS$299.95 (1981)
CPUMOS Technology 6502 @ 1.1 MHz (PAL) / 1.02 MHz (NTSC)
Memory5 KB RAM (3.5 KB usable), expandable up to 32 KB
StorageExternal cassette tape (Datasette), optional 5.25" floppy disk drive
Display176×184 pixels, 22×23 text characters, 16 colors
Sound3 square wave generators + 1 noise channel (mono)
Dimensions40.3 cm × 20.4 cm × 7.2 cm
Weight1.8 kg
OS / FirmwareCommodore BASIC 2.0 (in ROM)
PredecessorCommodore PET 4000 Series
SuccessorCommodore 64
CodenameVIC-20, VC-20 (Germany), VIC-1001 (Japan)
Model no.VIC-1001, VIC-20, VC-20
The Commodore VIC-20 was a groundbreaking home computer introduced by Commodore Business Machines in 1980. Known as the VIC-1001 in Japan and the VC-20 in Germany, it was the first computer to sell over one million units, making computing accessible to the masses.
At its core, the VIC-20 utilized the MOS Technology 6502 8-bit microprocessor, operating at 1.1 MHz for PAL systems and 1.02 MHz for NTSC systems. This CPU was also employed in other notable systems like the Apple II and Commodore 64.
Memory and Storage
The VIC-20 came with 5 KB of RAM, with approximately 3.5 KB available for user programs. Memory could be expanded up to 32 KB via external cartridges.
For storage, the VIC-20 relied on external devices:
  • Datasette – a cassette tape drive for loading and saving programs.
  • VIC-1540/VIC-1541 – optional 5.25" floppy disk drives connected via the serial port.
Display and Graphics
The VIC-20 featured a 176×184 pixel resolution with a text display of 22 columns by 23 rows. It supported a palette of 16 colors. Graphics were character-based, and while it lacked a bitmap mode, users could define custom characters for simple graphics and animations.
Sound Capabilities
Sound was generated through the MOS Technology VIC chip, offering:
  • Three square wave generators.
  • One white noise generator.
  • Overall volume control.
These features allowed for basic music and sound effects in games and applications.
Input/Output and Expansion
The VIC-20 was equipped with several I/O ports:
  • Cartridge Port – for software and memory expansion cartridges.
  • User Port – for modems and user-designed peripherals.
  • Serial Port – for printers and disk drives.
  • Joystick Port – compatible with Atari-style joysticks.
  • Cassette Port – for the Datasette.
  • RF and Composite Video Outputs – for connection to TVs and monitors.
Over time, VIC-20 computers may experience issues common to vintage electronics, such as:
  • Aging capacitors leading to power supply instability or failure.
  • Keyboard contact wear causing unresponsive or erratic key behavior.
  • Overheating of the linear voltage regulator (LM323K), potentially leading to case deformation or component damage.
  • Degradation of the RF modulator affecting video output quality.
Regular maintenance, including capacitor replacement, keyboard cleaning, and ensuring proper heat dissipation, can help preserve the functionality of these systems. For detailed procedures, refer to the Commodore VIC-20 Maintenance Guide.
PCB Schematics & Service Guide
The VIC-20 features a modular motherboard design, facilitating repairs and upgrades. Detailed schematics and service manuals are available within the Commodore VIC-20 Technical Manual. Notable assembly versions include:
  • Assy 324003 – Early NTSC models.
  • Assy 251027-01 – VIC-20CR revision D (NTSC, new design).
  • Assy 324001-03 – VC-20 rev.B (PAL, old design).
Motherboard Images
Logic Board Schematic Diagrams
Commodore VIC-20 Logic Board
VIC-20 Logic Board Schematic
Technical Documentation
For detailed technical information, refer to the following resources:
