Module:Anchor
Revision as of 23:32, 24 September 2020 by RetroTechCollection>Pppery (Add class per edit request)
Documentation for this module may be created at Module:Anchor/doc
-- This module implements {{anchor}}.
local getArgs = require('Module:Arguments').getArgs
local tableTools = require('Module:TableTools')
local p = {}
function p.main(frame)
	-- Get the positional arguments from #invoke, remove any nil values,
	-- and pass them to p._main.
	local args = getArgs(frame)
	local argArray = tableTools.compressSparseArray(args)
	return p._main(unpack(argArray))
end
function p._main(...)
	-- Generate the list of anchors.
	local anchors = {...}
	local ret = {}
	for _, anchor in ipairs(anchors) do
		ret[#ret + 1] = '<span class="anchor" id="' .. anchor .. '"></span>'
	end
	return table.concat(ret)
end
return p
