BBC Micro Model A/B Capacitor Replacement Guide
Recapping a BBC Micro Model A or B is essential for ensuring stable power delivery, protecting irreplaceable ICs, and preventing damage from capacitor leakage. After four decades, the original electrolytic capacitors in these machines are often degraded or failing, causing unreliable operation, video instability, audio noise, or even catastrophic PCB corrosion. Proactive replacement preserves your BBC Micro for years to come.
๐ Visual Inspection & Failure Signs
Before starting, examine all electrolytic capacitors for:
- Bulging or domed tops โ Indicates internal pressure and imminent failure.
- Leaking electrolyte โ Brown, yellow, or green residue at the base or on the PCB, especially near the power supply section.
- Corroded or stained PCB โ Discoloured or lifted tracks around capacitors, particularly C9 and C1.
- Unusual odours โ A fishy or acrid smell can signal capacitor leakage.
If any capacitor shows signs of failure, replace all electrolytics on the mainboard and power supply. Even apparently โgoodโ capacitors may be out of tolerance or about to fail.
๐ BBC Micro Capacitor Lists
The BBC Micro Model A and B use a mixture of through-hole aluminium electrolytic capacitors, both on the mainboard and in the internal power supply unit (PSU). All values below are for original Issue 3โ7 boards and standard Astec AA11040C PSU; always cross-check your boardโs silkscreen and PSU label.
๐ฅ๏ธ Mainboard Electrolytic Capacitors
| Ref | Capacitance | Voltage | Notes / Function |
| C1 | 22 ยตF | 25 V | Video circuit decoupling |
| C2 | 1 ยตF | 63 V | Video output coupling |
| C3 | 10 ยตF | 16 V | Audio path (DC block) |
| C4 | 10 ยตF | 16 V | Audio path (DC block) |
| C5 | 10 ยตF | 16 V | Audio path (DC block) |
| C6 | 10 ยตF | 16 V | Audio path (DC block) |
| C7 | 10 ยตF | 16 V | Audio path (DC block) |
| C8 | 10 ยตF | 16 V | Audio path (DC block) |
| C9 | 220 ยตF | 16 V | Main 5 V rail decoupling (critical) |
| C10 | 10 ยตF | 16 V | Audio path (DC block) |
| C11 | 10 ยตF | 16 V | Audio path (DC block) |
| C12 | 10 ยตF | 16 V | Audio path (DC block) |
| C13 | 10 ยตF | 16 V | Audio path (DC block) |
| C14 | 10 ยตF | 16 V | Audio path (DC block) |
| C15 | 10 ยตF | 16 V | Audio path (DC block) |
| C16 | 10 ยตF | 16 V | Audio path (DC block) |
| C17 | 10 ยตF | 16 V | Audio path (DC block) |
| C18 | 10 ยตF | 16 V | Audio path (DC block) |
| C19 | 10 ยตF | 16 V | Audio path (DC block) |
| C20 | 10 ยตF | 16 V | Audio path (DC block) |
Some later Issue 7 boards use 25 V rated parts for all 10 ยตF capacitors. Use 25 V or higher if in doubt.
๐ Power Supply Unit (Astec AA11040C) Electrolytic Capacitors
| Ref (Astec) | Capacitance | Voltage | Notes / Function |
| C1 | 220 ยตF | 400 V | Mains filter (primary, high voltage) |
| C2 | 2200 ยตF | 16 V | +5 V output smoothing |
| C3 | 2200 ยตF | 16 V | +5 V output smoothing |
| C4 | 470 ยตF | 25 V | +12 V output smoothing |
| C5 | 470 ยตF | 25 V | -5 V output smoothing |
| C6 | 10 ยตF | 50 V | Control circuit decoupling |
| C7 | 1 ยตF | 50 V | Control circuit decoupling |
Some PSUs use slightly different numbering or values (e.g., 330 ยตF for C1 in rare variants). Always check the markings on your PSU before ordering replacements.
๐ ๏ธ Recapping Procedure
- Unplug the BBC Micro and allow it to sit for at least 10 minutes.
- Disassemble โ Remove the case screws, lift off the lid, and disconnect the keyboard ribbon and speaker wires.
- Remove the mainboard โ Unscrew and carefully lift out the mainboard.
- Discharge the PSU capacitors โ If recapping the PSU, ensure all capacitors are fully discharged before working. Use a resistor (e.g., 10 kฮฉ, 2 W) across the terminals of large cans.
- Desolder old capacitors โ Use a temperature-controlled iron (350โ375 ยฐC), desoldering braid, or a pump. Take care not to lift PCB pads, especially on the mainboard.
- Clean any leaked electrolyte โ Neutralise and clean with isopropyl alcohol and a soft brush. For stubborn corrosion, use a fibreglass pen.
- Install new capacitors โ Match polarity (long lead = positive), capacitance, and voltage (use equal or higher voltage). Observe correct orientation for all electrolytics.
- Trim leads and inspect joints โ Ensure all solder joints are shiny and free of bridges.
- Reassemble and test โ Refit the mainboard and keyboard, reconnect all cables, and reassemble the case.
๐งฐ Recommended Tools & Parts
- Temperature-controlled soldering iron (60โ80 W, 2 mm chisel tip)
- Desoldering braid and/or pump
- Isopropyl alcohol (IPA) and nylon brush
- High-quality 105 ยฐC, low-ESR capacitors (e.g., Panasonic FC/FR, Nichicon PW/PS, Rubycon YXF)
- Multimeter (for continuity and voltage checks)
- Fibreglass pen (for corrosion removal)
- Kapton tape (to insulate tall capacitors if needed)
- Protective eyewear and ESD precautions
โ๏ธ Post-Recap Voltage & Ripple Checks
After recapping, check the main voltage rails at the user port or directly on the mainboard:
| Test Point | Nominal Voltage | Acceptable Range | Max Ripple (p-p) |
| +5 V (ICs, user port pin 1) | 5.00 V | 4.85 โ 5.15 V | < 50 mV |
| +12 V (user port pin 6) | 12.00 V | 11.5 โ 12.5 V | < 100 mV |
| -5 V (user port pin 8) | -5.00 V | -4.75 โ -5.25 V | < 100 mV |
If ripple exceeds these values, re-check PSU capacitor installation and soldering.
๐ก Additional Tips
- Replace all electrolytics together โ If one has failed, the rest are not far behind.
- Use higher voltage ratings if space allows โ Modern capacitors are smaller; 25 V or 35 V parts often fit where 16 V were used.
- Mind PSU safety โ The mains filter capacitor (C1) holds charge and can be dangerous. Discharge with care.
- Check for PCB corrosion โ Clean thoroughly before fitting new parts, especially around C1 and C9.
- Avoid cheap generic capacitors โ Use reputable brands for reliability.
- Retain original lead spacing โ Modern capacitors may have narrower leads; bend gently to fit.
- Power up with a current-limited bench supply or fused mains lead after recapping the PSU.
