Sega Saturn (Model 2) Capacitor Replacement Guide
Recapping a Sega Saturn (Model 2) is crucial for restoring stable video, audio, and power delivery. Ageing electrolytic capacitors in these mid-1990s consoles can cause audio distortion, video artefacts, random resets, and even permanent board damage from leakage. Proactive replacement ensures reliable operation and preserves your Saturn for years to come.
🔍 Visual Inspection & Failure Signs
Before beginning, carefully inspect the mainboard and power supply for:
  • Bulging or domed capacitor tops – Indicates internal pressure and imminent failure.
  • Leaking electrolyte – Brown or greenish residue around capacitor bases, especially near the audio and power sections.
  • Corrosion or PCB staining – Green or blackened areas signal leakage and possible trace damage.
  • Audio or video issues – Buzzing, hissing, or rolling video may trace to dried-out SMD capacitors.
  • Random resets or failure to boot – High ESR in power rail capacitors can cause instability.
If any capacitor shows trouble, replace all electrolytic capacitors on the board.
📋 Sega Saturn Model 2 Capacitor List
The Saturn Model 2 (VA0, VA1, VA2, etc.) uses a mix of through-hole and SMD electrolytic capacitors. Values and locations may vary slightly by region and board revision—always cross-check your silkscreen and part markings.
🖥️ Mainboard Electrolytic Capacitors
Sega Saturn Model 2 Mainboard Electrolytic Capacitors
Ref. Designator Capacitance Voltage Type Location / Function
C1, C2, C3, C4, C5, C6, C7, C8, C9, C10 10 µF 16 V SMD Audio, video, RAM decoupling
C11, C12, C13, C14, C15, C16 22 µF 16 V SMD Audio path, DAC filtering
C17, C18, C19 47 µF 16 V SMD Power rail smoothing
C20, C21, C22 100 µF 10 V SMD Audio amp, video encoder
C23, C24 220 µF 10 V SMD Audio output, 5 V rail
C25 470 µF 10 V SMD Main 5 V decoupling
C26 1000 µF 10 V Through-hole Main 5 V bulk filter (near power input)
Some board revisions may use 6.3 V or 25 V rated capacitors for certain positions. Always match or exceed the original voltage rating.
🔌 Power Supply Board (Internal PSU)
Sega Saturn Model 2 Power Supply Capacitors
Ref. Designator Capacitance Voltage Type Notes
C101 220 µF 200 V Through-hole Mains filter (primary side)
C102 1000 µF 16 V Through-hole 5 V rail output filter
C103 470 µF 16 V Through-hole 9 V rail output filter
C104 47 µF 50 V Through-hole Standby/auxiliary rail
Some Saturns use an external PSU (“Type B”); if so, only the mainboard needs recapping.
🛠️ Recapping Procedure
  1. Disassemble the Saturn: Remove the screws from the case bottom, gently separate the top shell, and unplug the power supply and drive cables.
  2. Remove the mainboard: Take out all screws securing the mainboard. Disconnect controller ports and ribbon cables.
  3. Label connectors and take photos to aid reassembly.
  4. Desolder each capacitor: Use a soldering iron (350–375 °C) and desoldering braid or pump. For SMD capacitors, gently heat both sides and lift with tweezers.
  5. Clean pads thoroughly: Remove all old flux and leaked electrolyte with isopropyl alcohol and a brush.
  6. Install new capacitors: Match polarity (long lead = positive for through-hole; SMD stripe = negative). Use low-ESR, 105 °C rated capacitors. For SMD, bend radial leads flat if necessary.
  7. Inspect for solder bridges and clean the board again.
  8. Reassemble and test before fully closing the case.
  • Temperature-controlled soldering iron (fine tip, 2 mm chisel for through-hole, conical for SMD)
  • Desoldering braid and/or spring pump
  • Tweezers for SMD removal
  • Isopropyl alcohol (99%) and antistatic brush
  • Multimeter (for continuity and voltage checks)
  • High-quality 105 °C, low-ESR capacitors (Nichicon, Panasonic, Rubycon)
  • Kapton tape (to insulate capacitors near shielding)
  • ESD mat and wrist strap
⚙️ Post-Recap Voltage & Ripple Checks
After reassembly, verify the main voltage rails at the power supply output or mainboard test points:
Expected Voltage Rails (No Disc, Idle Menu)
5 V rail (mainboard input) 4.90 – 5.10 V < 40 mV
9 V rail (if present) 8.7 – 9.3 V < 80 mV
Audio amp Vcc 4.8 – 5.1 V < 40 mV
Excessive ripple or unstable voltage may indicate a missed or incorrectly installed capacitor.
💡 Extra Tips
  • Always match polarity! SMD caps have a stripe for negative; through-hole, the long lead is positive.
  • Clean up any leaked electrolyte thoroughly—residue is corrosive and conductive.
  • Replace all electrolytics at once—partial recaps are unreliable.
  • Use slightly higher voltage ratings if space allows, but do not exceed original capacitance by more than 20%.
  • If you hear buzzing or see video artefacts after recap, double-check for solder bridges or reversed capacitors.
  • Dispose of old capacitors responsibly at an electronics recycling centre.
