Template:Permanently protected/doc
Revision as of 08:34, 3 January 2025 by RetroTechCollection>MusikAnimal (add notice to update bot config if the template is moved, redirected or deleted. See Special:Permalink/1267019141#Bot troubles on 2024 Port Vila earthquake)
Use this template on the talk page of permanently protected pages. Use {{Temporarily protected}} on the talk page of temporarily protected pages.
If the template in question does not have a /doc page, and the {{Permanently protected}} does not have a nodoc parameter, then the talk page will be categorized in Category:Templates needing documentation pages.
The parameter |nobutton=yes can be used to hide the "Request edit" button on talk pages that soft-redirect to a centralized discussion page.
Note that, despite what the template above says, {{Permanently protected}} itself is not fully protected, it is just โ€Žโ€Ž[edit=autoconfirmed] (indefinite) โ€Ž[move=sysop] (indefinite).
