Template:Uw-ublock-double
New accounts are blocked if their username is too similar to the username of another account. This is done in order to prevent confusion, impersonation, or abuse. This block is not meant to punish you, nor is it meant to imply or accuse you of any wrongdoing.
You are welcome to create a new account with a username that is more easily distinguishable, or if you'd rather continue using this account, request a username change by:
- Clicking on "Edit" in order to modify this page.
- Adding
{{unblock-un|user=your new username here|reason=your reason here}}to the bottom of your talk page. - Replacing "your new username here" with the username you'd like to be changed to, and replacing "your reason here" with any information that you'd like to provide to the reviewing administrator.
- Clicking on "Publish changes".
{{unblock|Your reason here}}. However, it is recommended that you review and understand Wikipedia's guide to appealing blocks first. Thank you.
| You have been blocked from editing. |
This message box is using an invalid "type=block" parameter and needs fixing.
