Revision as of 22:47, 26 April 2023 by RetroTechCollection>JBW(This wording makes no sense when the notice is seen as a result of an attempt by a blocked editor to edit, and when it is seen on the talk page it sometimes leads to placing unblock requests out of chronological order, which can lead to confusion. For both those reasons, it is not a good form of words to use.)
Your account has been blocked indefinitely because it appears to impersonate another Wikipedia user. Users are not allowed to edit with inappropriate usernames, nor is other disruptive behavior ever allowed. If you think there are good reasons why you should be unblocked, you may appeal this block by adding the text {{unblock|reason=Your reason here ~~~~}} at the bottom of your talk page. For best results, please read the guide to appealing blocks first.
You have been blocked from editing.
This message box is using an invalid "type=block" parameter and needs fixing.
