Macintosh SE/30 Troubleshooting
Begin troubleshooting by confirming the analog board provides correct voltages: ideally, +5 V DC (within 4.90–5.10 V) and +12 V DC at drive connectors. If the SE/30 appears completely dead (no fan, CRT glow, or startup chime), inspect analog power components, including fuses, rectifiers CR2 and CR3, transistor Q2, and resistor R22. Verify no external peripherals or expansion cards are causing boot issues. Ensure reset and interrupt switches function freely, and inspect the logic board carefully for corrosion from a leaking PRAM battery. Perform a full recap of the logic board, replacing all electrolytic capacitors to eliminate instability caused by capacitor leakage.
"Simasimac" – Horizontal Stripe Pattern
The notorious "Simasimac" manifests as horizontal black-and-white stripes and no startup chime, typically due to capacitor leakage disrupting reset circuits. Clean and reseat ROM and RAM SIMMs; replace the PRAM battery if below 3 V. Conduct thorough trace inspections, especially near capacitors, using a multimeter or oscilloscope to verify continuity on CPU address/data lines. Check for a stable 16 MHz clock at the CPU and a correct reset pulse sequence. If persistent, examine the Apple Sound Chip (ASC) at UB11 or the Bourns network filter RP2. Repair or replace damaged traces, capacitors, or suspect components accordingly.
Chimes of Death and Sad Mac Codes
The Chimes of Death indicate severe early boot issues, primarily RAM or ROM access problems. Confirm RAM configuration: each bank must have four identical SIMMs, with the larger bank installed as Bank A. Reseat and clean ROM SIMMs; swap with known-good ROM if possible. Check continuity of RAM address/data lines, especially under leaking capacitors. Replace problematic ICs such as 74F258 multiplexers if RAM troubleshooting fails. Rarely, VIA chips or severe corrosion can cause unusual boot behaviors—inspect carefully for abnormal heat or visual damage. You can find more information on Sad Mac Codes on the Sad Mac Error Codes page.
Video Display Issues
No Video but Chime Present
If the system audibly boots but displays no image, ensure analog brightness controls are correct and verify CRT glow. Faulty video ICs (e.g., UE8 multiplexer) commonly cause blank screens. Reseat socketed video chips, confirm IC continuity, and replace suspect ICs after oscilloscope tests confirm missing or incorrect video/sync pulses at P1 connector.
Vertical "Jailbar" Stripes
Vertical stripes typically result from incorrect RAM configurations. Each RAM bank must contain identical SIMMs, with the larger SIMMs occupying Bank A. Adjust RAM configuration to correct this issue.
Checkerboard Pattern
A checkerboard screen usually signals ROM issues. Clean and reseat the ROM SIMM, ensuring compatibility (original SE/30 or Macintosh IIsi ROM).
Disk Drive and SCSI Issues
A frozen mouse pointer against a gray background often indicates SCSI controller (NCR 53C80) failure. Test by disconnecting internal SCSI devices; replace the controller chip or repair damaged termination resistors. Floppy drive issues often involve dirty mechanisms, faulty SWIM floppy controllers, or VIA chip solder problems. Ensure drive cleanliness, verify SWIM functionality, and resolder or replace faulty ICs as required. You can find more information on HDD and Floppy Drive issue on the Macintosh HDD Maintenance and Macintosh HDD Maintenance pages.
Audio and ADB Issues
Audio
No startup sound points to issues with the ASC or analog audio amplifier. Verify sound through the headphone jack; sound there indicates analog board faults. Replace faulty ASC chips or audio amplifier components after careful continuity and visual inspections.
ADB
Dead keyboard or mouse commonly results from blown fuse F1 or damaged ADB microcontroller (Egret). Check and replace fuse; verify the microcontroller functionality. Replacement ICs or compatible modern substitutes are available. Also, check solder joints on VIA chips and ADB connectors.
Recurring Reset or Clock Issues
Erratic clock or PRAM losses typically signify dead PRAM batteries or faulty 32.768 kHz crystals. Random resets often stem from power rail instabilities or electrolyte contamination around the Egret or VIA chips.
Brief Analog Board Troubleshooting
- Bright vertical lines indicate horizontal deflection faults; repair P1 connector solder joints and replace capacitor C15. - Bright horizontal lines signify vertical deflection faults; repair P1 joints and replace vertical IC TDA1170A if necessary. - Wavy or interference patterns commonly result from aging flyback transformers; replace with improved models. - PSU clicking usually indicates logic board shorts or faulty startup components (CR2/CR3 diodes, transistor Q2, resistor R22). Repair accordingly.
