Macintosh LC 475 Troubleshooting
Revision as of 23:49, 15 July 2026 by Josh (talk | contribs) (Expand troubleshooting: exploding PRAM battery, SMD-cap leakage (chime-but-no-video), PSU recap; cited (68kMLA/Quagmire/Service Source))
This guide covers common issues and diagnostic procedures for the Macintosh LC 475.
Preliminary Checks
  • Power cable is securely connected.
  • Monitor cable is properly attached.
  • Keyboard and mouse are connected to ADB port.
  • No external SCSI devices are causing conflicts.
No Power
No Power Diagnostics
Symptom Possible Cause Action
Completely dead, no fan Power supply failure Check power supply capacitors; test with known-good PSU
Clicks or ticks repeatedly Short circuit or capacitor failure Inspect logic board for shorts
Fan spins briefly, then stops Thermal protection or PSU fault Check PSU output voltages
LED on but no startup Logic board issue Reset PRAM (Cmd+Opt+P+R); inspect board
Power Supply Voltages
  • +5V rail: 4.85V – 5.15V
  • +12V rail: 11.9V – 12.7V
Chimes but No Video
Chime But No Video
Normal chime, black screen VRAM failure or video circuit issue Reseat VRAM SIMMs; test with different monitor
Chime with garbage display VRAM or logic board damage Check VRAM SIMMs
Distorted or shifted image Video timing issue Check video output connector
Startup Chime Errors
Error Chime Codes
Chime Pattern Meaning Action
No chime CPU or ROM failure Reseat CPU; inspect logic board
Single tone (not normal chime) RAM failure Reseat 72-pin SIMM; test with different SIMM
Four tones (ascending) RAM failure Replace RAM SIMM
Sad Mac Errors
Sad Mac Error Codes
Code Meaning Action
0000000F / 00000001 ROM test failure ROM or logic board problem
0000000F / 00000002 Memory test failure Check RAM SIMM
0000000F / 00000003 Memory addressing error Reseat or replace RAM
Intermittent Operation
Intermittent Issues
Random freezes Capacitor failure, bad RAM, or CPU issue Recap board; test RAM; reseat CPU
Works when cold, fails when warm Thermal-related component failure Inspect for dry solder joints; check CPU seating
Spontaneous restarts Power supply instability Check PSU capacitors and output voltages
SCSI Problems
SCSI Troubleshooting
Hard drive not recognized SCSI ID conflict or cable issue Check SCSI ID (drive should be ID 0); reseat cables
Flashing question mark No bootable system found Boot from floppy; check hard drive
External devices not detected Termination or ID issue Verify termination; check all SCSI IDs are unique
Floppy Drive Issues
Floppy Drive Problems
Disk not ejecting Mechanical jam Manually eject; check mechanism
Cannot read disks Dirty heads Clean heads with IPA
Disks not recognized Drive failure Test with known-good drive
CPU Issues
The 68LC040 is socketed and can develop contact issues:
CPU Problems
No boot, no chime CPU not seated properly Remove and reseat CPU carefully
Random crashes Poor CPU contact Reseat CPU; clean socket contacts
FPU-dependent software crashes Using 68LC040 (no FPU) Upgrade to full 68040, or use software FPU emulator
Audio Issues
Audio Problems
No sound output Capacitor failure in audio circuit Recap logic board
Mono output only Damaged stereo circuit Check audio capacitors and output jack
Distorted audio Failing capacitors Replace capacitors
The Macintosh LC 475 uses a 3.6 V 1/2AA lithium PRAM battery (often a red Maxell). These are notorious for leaking and even exploding, spraying corrosive electrolyte across the logic board — a battery can burst while the machine sits in storage and destroy the board. Remove the PRAM battery from any un-serviced unit immediately. If one has leaked, neutralise and clean the residue and check the traces and vias around the battery and the nearby chips for corrosion, repairing any that are damaged.[1]
⚠️ Surface-mount capacitor leakage
The Macintosh LC 475 logic board uses surface-mount electrolytic capacitors that leak electrolyte from the bottom with age. The leakage corrodes traces and vias and is a leading cause of faults, so recap and clean the board as a first step. A common pattern is a board that chimes but shows no video after servicing — usually corrosion damage (broken traces or vias) around the leaked capacitors (for example near C136/C137), which must be traced and repaired.[2]
The compact LC "pizza-box" power supply also uses electrolytics that leak with age. A dead LC PSU can usually be revived by replacing all its electrolytic capacitors and cleaning the leakage; any working LC PSU should be recapped pre-emptively, as it will otherwise fail. Confirm the +5 V and +12 V rails after servicing.[2]
Processor and expansion
The LC 475 uses a 25 MHz Motorola 68LC040 (no FPU); a full 68040 can be fitted to add hardware floating-point. The 114-pin PDS expansion slot accepts LC-compatible I/O, display, network and video-capture cards. The Macintosh Quadra 605 is the same logic board sold under the Quadra name.[2]
  1. 1.0 1.1 "Warning! Exploding Maxell PRAM Batteries", 68kMLA; and "Mac Battery Leaks", MacDat. Source for the exploding/leaking Maxell PRAM battery and the resulting board damage, and the LC not booting without a battery.
  2. 2.0 2.1 2.2 "Quadra 605 / LC 475", Quagmire Repair; the Apple Macintosh LC/LC II/LC III/LC 475/Quadra 605 Service Source; and "Macintosh LC Recap", PAPPP's Rambling. Source for the SMD-capacitor leakage, the PSU recap, and the trace/via damage causing chime-but-no-video.
