This guide covers common faults with the Macintosh IIvx , including startup failures, video problems, CD-ROM issues, and storage errors.
Preliminary Checks
Verify the power cable is secure
Test with a known-good outlet
Disconnect all external SCSI devices
Remove any NuBus or PDS cards
Check for visible capacitor leakage or battery corrosion
No Power
Macintosh IIvx. Source: Wikimedia Commons.
Power Issues
Symptom
Possible Cause
Action
Completely dead
Blown fuse, failed PSU, bad cord
Check outlet; test power cord; check PSU fuse
Clicking or ticking
Failed PSU capacitors
Recap power supply
Powers on briefly then dies
Overload protection, shorted component
Disconnect cards and drives; test with minimal config
Fan spins but no startup
Dead PRAM battery, failed logic board
Replace PRAM battery; check for capacitor damage
Startup Failures
Startup Problems
Symptom
Possible Cause
Action
No chime, no video
Dead logic board, failed capacitors
Recap logic board; check PRAM battery
Chime but no video
VRAM issue, video connector
Reseat VRAM SIMMs; check video cable
Sad Mac error
Hardware failure
Decode error code; test RAM
Flashing question mark
No boot device
Check SCSI drive; verify termination
Chimes of death
RAM failure
Reseat or replace RAM SIMMs
Sad Mac Error Codes
Common Sad Mac Codes
Code Range
Meaning
Action
01XXXX
ROM test failure
Check for corrosion; may need logic board repair
02XXXX โ 05XXXX
RAM test failure
Try different SIMMs; clean SIMM slots
0DXXXX
NuBus card failure
Remove all NuBus cards
0EXXXX
SCSI controller failure
Check for capacitor damage
0FXXXX
Data bus failure
Logic board damage
See Sad Mac Error Codes for complete reference.
Video Problems
Display Issues
Symptom
Possible Cause
Action
No video after chime
VRAM failure, cable issue
Reseat VRAM; check video cable and monitor
Distorted or garbled
VRAM configuration, bad VRAM
Ensure matching VRAM SIMMs; try removing VRAM upgrade
Wrong colors
VRAM issue, video DAC
Reseat VRAM; check for capacitor damage
Flickering
Loose cable, monitor issue
Check video cable; test with different monitor
Audio Problems
Sound Issues
Symptom
Possible Cause
Action
No startup chime
Audio circuit failure, capacitor damage
Recap logic board
Distorted audio
Failed capacitors
Recap logic board
No audio through jack
Jack issue, cable
Test with different cable/speakers
CD-ROM Issues
CD-ROM Problems (if installed)
Symptom
Possible Cause
Action
Drive not recognized
SCSI ID conflict, loose cable
Check SCSI ID (usually 3); reseat ribbon cable
Disc not reading
Dirty lens, worn laser
Clean lens with CD lens cleaner
Tray won't open
Mechanical failure, stuck tray
Use emergency eject hole (paperclip); lubricate mechanism
Audio CDs work but data CDs don't
Driver issue, laser calibration
Reinstall CD-ROM driver; laser may be failing
Slow performance
Dirty lens, failing drive
Clean lens; 2X drives are slow by design
Serial Port Issues
The IIvx serial ports are limited to 57.6 kbit/s:
Serial Port Problems
Symptom
Possible Cause
Action
Modem connection fails
Speed limitation
Configure modem for 57.6 kbit/s or lower
MIDI timing problems
Port speed insufficient
Use external MIDI interface card
Printing slow or fails
Speed setting
Check printer driver settings
SCSI and Storage
Drive Problems
Symptom
Possible Cause
Action
No bootable System
Check SCSI drive; verify cable; test with boot floppy
Wrong SCSI ID, termination
Verify unique SCSI IDs; check termination
System freezes during boot
SCSI bus conflict
Disconnect all SCSI; add one at a time
Floppy not reading
Dirty heads, failed drive
Clean heads; test with different disks
SCSI Termination
Internal hard drive: terminated (usually SCSI ID 0)
Internal CD-ROM (if installed): usually SCSI ID 3, not terminated
External devices: terminate only the last device in chain
Verify each device has a unique SCSI ID (0โ6)
Capacitor Failure Symptoms
Symptom
Likely Cause
Solution
Random crashes
Failed logic board caps
Full logic board recap
Audio distortion
Caps near audio circuit
Recap logic board
No startup
Power or reset circuit caps
Recap; check traces
Intermittent operation
Multiple failing caps
Full recap
See Macintosh IIvx Capacitor Replacement Guide for procedures.
โ ๏ธ PRAM battery โ remove it now
The Macintosh IIvx carries a 3.6 V 1/2AA lithium PRAM battery. These leak and can burst , spraying corrosive electrolyte across the logic board and destroying nearby components — often while the machine simply sits in storage. Remove the PRAM battery from any un-serviced unit. If one has leaked, neutralise and clean the residue and repair corroded traces and vias before troubleshooting.[ 1]
โ ๏ธ Surface-mount capacitor leakage
The Macintosh IIvx logic board uses surface-mount electrolytic capacitors that leak with age and corrode the board; recap and clean the logic board as a first step, then recap the power supply.[ 2]
The desktop power supply uses electrolytic capacitors that fail with age. The classic symptoms are a machine that will rarely turn on, cannot be switched off without unplugging it, and clicks from the PSU when merely plugged in . Recap the power supply and confirm the +5 V and +12 V rails. (This PSU form factor is shared across the IIci, IIcx, IIvi, IIvx, Performa 600, Quadra 650 and Quadra 700.)[ 3]
Related Pages
