Power Macintosh 6500 Troubleshooting
Troubleshooting is essential for diagnosing and resolving issues with your Power Macintosh 6500. This guide covers common problems and their solutions.
Preliminary Checks
[edit | edit source]Before troubleshooting, verify:
- Power cable is securely connected
- Monitor is connected and powered on
- Keyboard and mouse are connected to ADB port
- No disks are in the floppy or CD-ROM drives during startup
No Power
| No response when power button pressed | Failed power supply | Check power outlet; test with known-good cable; inspect PSU capacitors |
| Power light on but no startup | Logic board failure | Reseat RAM and PCI cards; check for capacitor leakage |
| Clicking or ticking sound | Power supply fault | Replace power supply |
| Powers on briefly then shuts off | Short circuit or thermal protection | Check for loose screws or debris; inspect for failed components |
Startup Issues
| Chime but no video | Video circuit failure or RAM issue | Reseat RAM; test with different monitor; check VRAM |
| No chime, no video | Dead logic board or RAM failure | Remove all RAM and test; reset PRAM (Cmd+Opt+P+R) |
| Flashing question mark | No bootable system found | Check hard drive connections; boot from CD-ROM; reinstall system |
| Sad Mac icon | Hardware failure | Note error code; see Sad Mac Error Codes |
| Gray screen with no boot | System software corruption | Boot from CD; reinstall system software |
Sad Mac Error Codes
[edit | edit source]The 6500 may display Sad Mac codes indicating hardware failures. See Sad Mac Error Codes for a complete reference.
Common codes:
- 0000000F / 00000001: RAM failure (check/replace RAM)
- 0000000F / 00000005: ROM checksum failure
- 00000003 / 00000001: Bus error during boot
RAM Issues
| System reports less RAM than installed | Bad DIMM or incorrect speed | Verify 60 ns or faster DIMMs; test each DIMM individually |
| Random crashes or freezes | Faulty RAM | Run memory test software; try known-good RAM |
| Death chimes at startup | RAM not recognized | Reseat or replace RAM; clean DIMM contacts |
Hard Drive Issues
| Drive not recognized | Cable connection or drive failure | Check IDE cable; verify jumper settings; test drive externally |
| Slow performance | Failing drive or fragmentation | Back up data immediately; consider replacement |
| Clicking sounds from drive | Imminent drive failure | Replace drive immediately; attempt data recovery |
| "This disk is unreadable" | File system corruption | Run Disk First Aid; reformat if necessary |
CD-ROM and Zip Drive Issues
| CD-ROM not reading discs | Dirty lens or laser failure | Clean lens; check for disc damage; replace drive |
| CD tray won't eject | Belt slippage or mechanical failure | Use paperclip emergency eject; replace belt |
| Zip "click of death" | Drive head or media failure | Replace Zip drive; do not use affected disks in other drives |
| Zip drive not recognized | SCSI termination issue | Check internal SCSI chain; reseat drive |
Video and Display Issues
| No video output | Bad connection or video circuit failure | Check monitor cable; test with different monitor |
| Distorted or wavy display | Refresh rate mismatch or interference | Adjust monitor settings; move away from interference sources |
| Wrong colors or color banding | VRAM issue | Zap PRAM; check video settings in Monitors control panel |
| Video works only at low resolution | VRAM or video chip failure | Video subsystem may need repair |
Audio Issues
| No audio output | Muted or disconnected speakers | Check Sound control panel; verify speaker connections |
| Distorted audio | Bad capacitors or speaker damage | Recap if necessary; test with headphones |
| Crackling or popping | Capacitor failure | See Power Macintosh 6500 Capacitor Replacement Guide |
PRAM and Settings Issues
[edit | edit source]If the system loses settings, displays wrong date/time, or has unusual startup behavior:
- Reset PRAM: Hold Cmd+Option+P+R during startup until you hear a second chime
- Replace PRAM Battery: The 4.5V alkaline battery may be depleted
⚠️ PRAM battery
[edit | edit source]The Power Macintosh 6500 uses a 3.6 V 1/2AA lithium PRAM battery that leaks and can burst, corroding the logic board. Remove it from any un-serviced unit and clean/repair any leakage before troubleshooting.[1]
⚠️ Recap (logic board and PSU)
[edit | edit source]The Power Macintosh 6500 uses aluminium electrolytic capacitors on both the logic board and the power supply, and they leak with age. Recap and clean both boards as a first step; the large 2200 uF PSU filter capacitors in particular are a known failure point, giving a dead machine, failure to power on, or instability.[2]
[edit | edit source]- ↑ 68kMLA — Exploding Maxell PRAM Batteries. Source for the leaking/exploding 3.6 V lithium PRAM battery.
- ↑ Recap-a-Mac — Power Macintosh 6100; Badcaps "Macintosh 6100 power supply"; and the Apple Performa/Power Macintosh 6400/6500 Service Source. Source for the logic-board and power-supply electrolytic failures (including the 2200 uF PSU capacitors) and the recap.
[edit | edit source]Surface-mount capacitor leakage
[edit | edit source]The Power Macintosh 6500 logic board uses surface-mount electrolytic capacitors whose electrolyte turns corrosive with age and creeps across the board, eating through traces, pads and IC pins. Typical signatures are a machine that will not chime, chimes but shows no video, plays distorted or missing audio, or shows a garbled or checkerboard screen. Wash the affected area and replace every electrolytic with a tantalum or polymer part, then repair any lifted traces. The switch-mode power supply (ASTEC or TDK on the LC-family machines) holds its own electrolytics and fails the same way, so recap it alongside the board.[1]
PRAM battery
[edit | edit source]The Power Macintosh 6500 backs up its clock and Parameter RAM from a 3.6 V ½AA lithium cell. These cells — red Maxell parts especially — leak or burst and corrode the board, so remove an aged one on sight. A flat cell can also stop a soft-power machine booting or disturb the video; left plugged in, trickle power preserves the settings, but a machine switched off at the wall with a dead cell loses them. Clean the area and fit a fresh 3.6 V cell.[2]
Boot chime and Sad Mac
[edit | edit source]Read the start-up sound first: a normal chime with a black screen points to the display path or the monitor, an absent chime or a "chord of death" points to RAM or a core fault, and a Sad Mac shows a numeric code — see Sad Mac Error Codes.
Related Pages
[edit | edit source]- Power Macintosh 6500
- Power Macintosh 6500 General Maintenance
- Power Macintosh 6500 Capacitor Replacement Guide
- Sad Mac Error Codes
- ↑ Mac84, Macintosh LC series power-supply recapping guide; the MacCaps capacitor reference; and iFixit. Source for surface-mount electrolytic leakage eating traces, pads and pins, the ASTEC/TDK LC power-supply cap failures, and Apple's use of tantalum (non-leaking) capacitors on the Quadra 700/900 logic boards.
