CRT Discharge Procedure
Cathode Ray Tubes (CRTs), used in vintage Macintosh and other classic computers, can retain a dangerous high voltage charge for hours or even days after being powered off. To avoid electric shock or injury, proper discharge is essential before performing internal repairs.
โ ๏ธ Safety Warning
Working with CRTs involves potentially lethal voltages (up to 25,000 volts). You should **only discharge a CRT** if you are confident and equipped to do so safely.
Minimum Safety Precautions
- Unplug the system and wait at least 30 minutes before starting.
- Use only insulated tools and wear rubber-soled shoes.
- Never work on a CRT in a damp or conductive environment.
- Discharge the CRT before touching or removing the analog board.
๐งฐ Tools Required
To safely discharge a CRT, you will need:
- Flat-head screwdriver โ Preferably with a long, insulated handle.
- Alligator clip jumper wire โ To ground the tool.
- Gloves โ High-voltage insulating gloves recommended.
- Discharge wand (optional) โ A purpose-built safe discharger for CRTs.
โก How to Build a Discharge Tool
A simple and safe CRT discharger can be made as follows:
- Attach one end of the alligator clip wire to the metal shaft of a long flat-head screwdriver.
- Attach the other end to a ground point on the CRT (see below).
- Wrap the shaft in electrical tape to avoid accidental contact with bare metal.
๐ Identifying the Ground Point
A safe ground point includes:
- The metal chassis of the CRT tube.
- The spring clamp grounding wire around the CRT funnel.
- The analog boardโs metal shield or logic board ground plane.
๐ ๏ธ Discharge Procedure
Step-by-Step
- Ensure the system is **unplugged** and left off for 30 minutes.
- Attach your alligator clip to a grounded part of the CRT or chassis.
- Hold the **screwdriver by the insulated handle only**.
- Carefully slide the screwdriver tip under the rubber suction cup (anode cap) on the CRT.
- You may hear a "pop" or crackle sound โ this is normal.
- Hold contact for at least **10 seconds** to allow the charge to dissipate.
- Remove the anode cap by pinching and lifting it free from the CRT.
Repeat Discharge
Some CRTs can regain charge due to internal capacitance. After 10โ15 minutes, it's a good idea to discharge the anode again before handling.
๐งน After Discharge Safety
- Always verify the CRT has been discharged before touching or removing the analog board.
- Keep your discharge tool handy during repair in case you need to re-discharge.
- After completing your work, reinstall the anode cap securely and avoid twisting it.
