Module:Parameter names example
Revision as of 10:41, 10 July 2023 by Infobox>Gonnym (if these are wanted, they should be handled differently (by passing a parameter to this module) as these cause pages to appear as unknown parameters for templates that don't use them)
Documentation for this module may be created at Module:Parameter names example/doc
-- This module implements {{parameter names example}}.
local p = {}
local function makeParam(s)
	local lb = '{'
	local rb = '}'
	return lb:rep(3) .. s .. rb:rep(3)
end
local function italicize(s)
	return "''" .. s .. "''"
end
local function plain(s)
	return s
end
function p._main(args, frame)
	-- Find how we want to format the arguments to the template.
	local formatFunc
	if args._display == 'italics' or args._display == 'italic' then
		formatFunc = italicize
	elseif args._display == 'plain' then
		formatFunc = plain
	else
		formatFunc = makeParam
	end
	-- Build the table of template arguments.
	local targs = {}
	for k, v in pairs(args) do
		if type(k) == 'number' then
			targs[v] = formatFunc(v)
		elseif not k:find('^_') then
			targs[k] = v
		end
	end
	--targs['nocat'] = 'yes';
	--targs['categories'] = 'no';
	--targs['demo'] = 'yes';
	-- Find the template name.
	local template
	if args._template then
		template = args._template
	else
		local currentTitle = mw.title.getCurrentTitle()
		if currentTitle.prefixedText:find('/sandbox$') then
			template = currentTitle.prefixedText
		else
			template = currentTitle.basePageTitle.prefixedText
		end
	end
	-- Call the template with the arguments.
	frame = frame or mw.getCurrentFrame()
	local success, result = pcall(
		frame.expandTemplate,
		frame,
		{title = template, args = targs}
	if success then
		return result
	else
		return ''
	end
end
function p.main(frame)
	local args = require('Module:Arguments').getArgs(frame, {
		wrappers = 'Template:Parameter names example'
	return p._main(args, frame)
end
return p
