Osborne 1
Revision as of 19:01, 12 May 2025 by Josh (talk | contribs)
Osborne 1
Osborne 1 portable computer (1981)
ManufacturerOsborne Computer Corporation
TypePortable Computer
ReleasedApril 1981
Discontinued1983
Intro priceUS$1,795 (1981)
CPUZilog Z80A @ 4 MHz
Memory64 KB RAM
StorageDual 5.25" single-sided, single-density floppy drives (91 KB each)
Display5" monochrome CRT (52ร—24 text)
SoundNone (beeper only)
Dimensions13.5" ร— 21.5" ร— 8.75"
Weight24.5 lb (11.1 kg)
OS / FirmwareCP/M 2.2
SuccessorOsborne Executive
CodenameOCC1
Model no.Osborne 1
The Osborne 1 is widely recognised as the first commercially successful portable computer. Released in April 1981 by Osborne Computer Corporation, it combined a Zilog Z80A CPU, CP/M operating system, and bundled productivity software in a compact, luggable form factor, making computing mobile for business users of the early 1980s.
At its core, the Osborne 1 is powered by a Zilog Z80A microprocessor running at 4 MHz. This 8-bit CPU was the standard for CP/M-based systems of the era, providing reliable performance for business applications such as word processing, spreadsheets, and database management.
The system architecture was designed for portability and compatibility with the CP/M 2.2 operating system, which allowed users to run a wide range of third-party software.
Memory and Storage
The Osborne 1 is equipped with:
  • 64 KB RAM โ€“ the maximum addressable by the Z80A CPU under CP/M.
  • ROM โ€“ minimal; mainly for bootstrapping the CP/M loader.
For storage, the Osborne 1 features:
  • Dual 5.25" single-sided, single-density floppy disk drives (each with a formatted capacity of 91 KB).
  • No internal hard drive or cassette interface.
The floppy drives were used for both program and data storage, with one typically holding the operating system and applications, and the other used for user data.
Display and Graphics
The Osborne 1 includes a built-in:
  • 5-inch monochrome CRT display
  • Text mode: 52 columns ร— 24 rows
While the screen is physically small, the system can output to an external monitor for improved readability. The display is strictly text-based, with no bitmap graphics capability.
Sound Capabilities
The Osborne 1 does not feature dedicated sound hardware. The only audio output is a simple beeper used for system alerts.
Input/Output and Expansion
The Osborne 1 provides a range of I/O options for its time:
  • Full-stroke keyboard โ€“ detachable, doubles as the system's carrying case cover.
  • IEEE-488 port โ€“ for parallel peripherals.
  • RS-232 serial port โ€“ for modems and serial devices.
  • Video output โ€“ composite video for external monitors.
  • Parallel printer port
  • Modem port โ€“ 300 baud internal modem (optional on some models).
  • Expansion connector โ€“ for third-party add-ons (e.g., external disk drives, RAM expansion).
These ports enabled connectivity with printers, modems, and other business peripherals, enhancing the system's utility in office environments.
Osborne 1 PCB and Service Documentation
Logic Board Logic Board Schematic
Osborne 1 Main Logic Board
Please refer to the Osborne 1 Technical Manual
The Osborne 1's service manual and schematics are available on the Osborne Documentation page. These documents provide detailed information on board layout, component identification, and troubleshooting procedures.
