Module:GetParameters
Revision as of 22:33, 15 May 2025 by Josh (talk | contribs) (1 revision imported: Citation Import)
Documentation for this module may be created at Module:GetParameters/doc
local p = {}
Helper function that populates the argument list given that user may need to use a mix of
named and unnamed parameters.  This is relevant because named parameters are not
identical to unnamed parameters due to string trimming, and when dealing with strings
we sometimes want to either preserve or remove that whitespace depending on the application.
function p.getParameters( frame_args, arg_list )
    local new_args = {};
    local index = 1;
    local value;
    for i,arg in ipairs( arg_list ) do
        value = frame_args[arg]
        if value == nil then
            value = frame_args[index];
            index = index + 1;
        end
        new_args[arg] = value;
    end
    return new_args;
end
Helper Function to interpret boolean strings
function p.getBoolean( boolean_str )
    local boolean_value;
    if type( boolean_str ) == 'string' then
        boolean_str = boolean_str:lower();
        if boolean_str == 'false' or boolean_str == 'no' or boolean_str == '0'
                or boolean_str == '' then
            boolean_value = false;
        else
            boolean_value = true;
        end
    elseif type( boolean_str ) == 'boolean' then
        boolean_value = boolean_str;
    else
        error( 'No boolean value found' );
    end
    return boolean_value
end
function p.defined(frame)
	local arg = mw.text.trim(frame.args[1])
	--if arg == tostring(tonumber(arg)) then -- undesired result for '-0'
	--	arg = tonumber(arg)
	--end
	--if mw.ustring.find(arg, '^%s*-?[1-9][0-9]*%s*$') ~= nil or arg == '0' then
	--end
	if mw.ustring.find(arg, '^-?[1-9][0-9]*$') ~= nil then
		arg = tonumber(arg)
	elseif arg == '0' then
		arg = 0
	end
	return frame:getParent().args[arg] ~= nil
end
return p
