Template:Uw-ublock-double
Revision as of 21:35, 26 December 2024 by RetroTechCollection>HouseBlaster (spacing)
Your account has been blocked from editing Wikipedia because your username appears to be too similar to the username of another Wikipedia account.
New accounts are blocked if their username is too similar to the username of another account. This is done in order to prevent confusion, impersonation, or abuse. This block is not meant to punish you, nor is it meant to imply or accuse you of any wrongdoing.
You are welcome to create a new account with a username that is more easily distinguishable, or if you'd rather continue using this account, request a username change by:
  1. Clicking on "Edit" in order to modify this page.
  2. Adding {{unblock-un|user=your new username here|reason=your reason here}} to the bottom of your talk page.
  3. Replacing "your new username here" with the username you'd like to be changed to, and replacing "your reason here" with any information that you'd like to provide to the reviewing administrator.
  4. Clicking on "Publish changes".
If you feel that you were blocked in error, you may appeal this block by adding the following text to the bottom of your user talk page here: {{unblock|Your reason here}}. However, it is recommended that you review and understand Wikipedia's guide to appealing blocks first.
Thank you.
This message box is using an invalid "type=block" parameter and needs fixing.
