Template:Uw-uhblock-double
Revision as of 23:19, 6 September 2025 by Josh (talk | contribs) (1 revision imported)
Your account has been blocked indefinitely because it appears to impersonate another Wikipedia user. Users are not allowed to edit with inappropriate usernames, nor is other disruptive behavior ever allowed. If you think there are good reasons why you should be unblocked, you may appeal this block by adding the text {{unblock|reason=Your reason here ~~~~}} at the bottom of your talk page. For best results, please read the guide to appealing blocks first.
This message box is using an invalid "type=block" parameter and needs fixing.
