Macintosh Quadra 840AV Capacitor Replacement Guide
Revision as of 11:41, 10 February 2026 by Josh (talk | contribs) (Created capacitor replacement guide for Quadra 840AV)
Replacing electrolytic capacitors (recapping) in your Macintosh Quadra 840AV is essential for long-term reliability. The surface-mount electrolytic capacitors used on the logic board can leak over time, causing corrosion and component failure.
Capacitor Inspection
Before recapping, inspect the logic board for signs of capacitor failure:
  • Bulging Tops – Capacitors with domed tops instead of flat are failing
  • Leaking Electrolyte – Brown or orange residue around capacitor bases
  • Corrosion or PCB Staining – Discoloration of the PCB near capacitors
  • Crystalline Deposits – White or yellowish crystite formations
Even capacitors that look fine externally may have leaked internally. Preventive recapping is recommended for any Quadra 840AV that hasn't been serviced.
Macintosh Quadra 840AV Capacitor List
Logic Board Capacitors
The Quadra 840AV logic board (820-0382) uses surface-mount electrolytic capacitors. The following list covers typical values found on the board:
Logic Board Capacitor Specifications
Location Capacitance Voltage Type Notes
Audio Section 10µF 16V SMD Electrolytic Multiple; critical for audio
Audio Section 47µF 16V SMD Electrolytic Audio coupling
Power Filtering 100µF 16V SMD Electrolytic Multiple locations
Power Filtering 220µF 16V SMD Electrolytic Main filter caps
Reset Circuit 10µF 16V SMD Electrolytic Near PRAM battery
Video Section 47µF 16V SMD Electrolytic Video I/O circuitry
DSP Section 10µF 16V SMD Electrolytic Near AT&T DSP 3210
Note: Exact capacitor locations and values should be verified against your specific board revision. The 840AV logic board went through revisions.
Power Supply Capacitors
The power supply contains larger through-hole electrolytic capacitors that may also need replacement:
Power Supply Capacitor Examples
1000µF 25V Radial Electrolytic Primary filter
470µF 25V Radial Electrolytic Secondary filter
220µF 16V Radial Electrolytic Output filtering
100µF 16V Radial Electrolytic Various locations
47µF 25V Radial Electrolytic Various locations
Warning: The power supply contains high-voltage capacitors. Discharge properly before servicing.
Required Tools
  • Temperature-controlled soldering iron (recommended: 350°C for SMD)
  • Fine tip for SMD work
  • Desoldering braid or solder wick
  • Flux (no-clean recommended)
  • Isopropyl alcohol (99%) and ESD-safe brushes
  • Multimeter
  • Magnification (loupe or microscope)
  • Anti-static mat and wrist strap
  • Safety glasses
Replace with high-quality capacitors:
  • SMD: Panasonic, Nichicon, Rubycon SMD electrolytics
  • Alternative: Polymer or tantalum capacitors (same value, check polarity)
  • Through-hole (PSU): Nichicon, Rubycon, Panasonic
Procedure
  1. Prepare the workspace
    • Use an anti-static mat
    • Ensure good lighting and ventilation
    • Have isopropyl alcohol ready for cleaning
  1. Document capacitor positions
    • Photograph the board before starting
    • Note polarity markings on each capacitor
  1. Remove old capacitors
    • Apply flux to capacitor terminals
    • Heat both terminals simultaneously if possible
    • Gently lift the capacitor away
    • Clean pads with solder wick and isopropyl alcohol
  1. Clean the board
    • Remove any leaked electrolyte with isopropyl alcohol
    • Inspect traces for damage
    • Check for lifted pads
  1. Install new capacitors
    • Apply fresh flux to pads
    • Tin one pad with solder
    • Position capacitor, observing correct polarity
    • Tack one side, then solder the other
    • Reflow first side if needed
  1. Inspect and test
    • Check all solder joints under magnification
    • Verify no bridges or cold joints
    • Test continuity where appropriate
    • Clean flux residue with isopropyl alcohol
Voltage Adjustment After Recap
After recapping, verify power supply voltages:
Target Voltage Ranges
Rail Target Acceptable Range
+5V 5.0V 4.85V – 5.15V
+12V 12.0V 11.9V – 12.7V
-12V -12.0V -11.5V – -12.7V
Trace Repair
If capacitor leakage has damaged traces:
  1. Identify damaged traces using multimeter continuity test
  2. Scrape away damaged areas carefully
  3. Jumper with fine wire (30 AWG recommended)
  4. Secure jumper wires with UV-cure solder mask or epoxy
  5. Document all repairs for future reference
Additional Tips
  • Work methodically – Replace capacitors one section at a time
  • Take photos – Document before, during, and after
  • Don't overheat – SMD pads can lift easily
  • Test incrementally – Power on and test after each section if possible
  • Keep spares – Order extra capacitors in case of damage
  • Consider tantalum – For critical areas, tantalum caps won't leak
Common Mistakes to Avoid
  • Incorrect polarity (will destroy new capacitors)
  • Excessive heat lifting pads
  • Incomplete cleaning of leaked electrolyte
  • Using low-quality replacement capacitors
  • Skipping power supply capacitors
