Power Macintosh 6500 Specifications
Revision as of 13:39, 10 February 2026 by Josh (talk | contribs) (Created specifications page for Power Macintosh 6500)
This page contains detailed technical specifications for the Power Macintosh 6500 series.
Model Configurations
Power Macintosh 6500 Model Configurations
Model Order Number Processor RAM Hard Drive CD-ROM Zip Drive Modem Market
6500/225 M5606LL/A 225 MHz 32 MB 2.0 GB 12X Yes No Education
6500/225 M5611LL/A 225 MHz 32 MB 3.0 GB 12X No Yes Consumer
6500/250 M5607LL/A 250 MHz 32 MB 3.0 GB 12X Yes No Education
6500/250 M6189LL/A 250 MHz 32 MB 4.0 GB 24X Yes Yes Consumer
6500/250 M6127LL/A 250 MHz 48 MB 4.0 GB 12X Yes Yes Small Business
6500/275 M6191LL/A 275 MHz 32 MB 4.0โ€“6.0 GB 24X Yes Yes Consumer
6500/275 M6190LL/A 275 MHz 48 MB 6.0 GB 12X Yes Yes Small Business
6500/300 M6192LL/A 300 MHz 64 MB 6.0 GB 24X Yes Yes Consumer
All models share Apple Model Number M3548 and Gestalt ID 513.
Processor Specifications
CPU Specifications
Specification Value
Processor PowerPC 603e
Clock Speed 225, 250, 275, or 300 MHz
Architecture 32-bit RISC
Data Path 64-bit
FPU Integrated
System Bus 50 MHz
L1 Cache 32 KB
L2 Cache 256 KB (225/250 MHz) or 512 KB (275/300 MHz)
Memory Specifications
RAM Specifications
Specification Value
RAM Type 168-pin DIMM
Minimum Speed 60 ns
RAM Slots 2
Standard RAM 32โ€“64 MB (varies by model)
Maximum RAM 128 MB
Interleaving Not supported
ROM Specifications
Specification Value
ROM Type Macintosh ROM
ROM Size 4 MB
Video Specifications
Specification Value
Video RAM 2 MB SGRAM (60 ns)
VRAM Upgradeable No
Graphics Acceleration 2D/3D hardware acceleration
Maximum Resolution (24-bit) 832ร—624
Maximum Resolution (16-bit) 1152ร—870
Maximum Resolution (8-bit) 1280ร—1024
Second Display Supported with PCI video card
Supported Display Modes
Resolution Color Depth
512ร—384 24-bit (millions)
640ร—480 24-bit (millions)
800ร—600 24-bit (millions)
832ร—624 24-bit (millions)
1024ร—768 16-bit (thousands)
1152ร—870 16-bit (thousands)
1280ร—1024 8-bit (256 colors)
Storage Specifications
Component Specification
Hard Drive Interface IDE
Hard Drive Capacity 2.0, 3.0, 4.0, or 6.0 GB (varies by model)
Floppy Drive 1.44 MB 3.5" (manual eject)
CD-ROM 12X or 24X (varies by model)
Zip Drive Internal Zip 100 (most configurations)
Audio Specifications
Specification Value
Audio System SRS 3D surround sound
Subwoofer Integrated
Audio Input Stereo line in
Audio Output Stereo line out
Expansion and Ports
Expansion Slots
Slot Type Quantity Notes
PCI 2 Standard PCI slots
Comm-II 1 Modem slot (occupied in consumer models)
Video Input 1 Optional video capture card
TV 1 Optional TV/FM tuner card
Ports
Port Quantity Notes
Serial (Geoport) 2 Printer and modem ports
ADB 1 Apple Desktop Bus (keyboard/mouse)
SCSI 1 External 25-pin connector
Video Out 1 DB-15 monitor connector
Audio In 1 Stereo 3.5mm jack
Audio Out 1 Stereo 3.5mm jack
Networking
Networking Options
Internal Modem 33.6k (consumer models; absent in education models)
Ethernet 10Base-T (optional upgrade)
Physical Specifications
Physical Dimensions
Specification Imperial Metric
Height 16.0 inches 40.6 cm
Width 7.8 inches 19.8 cm
Depth 16.9 inches 42.9 cm
Weight 44.5 lbs 20.2 kg
Power Specifications
Power Requirements
Specification Value
Input Voltage 100Vโ€“125V or 200Vโ€“240V AC
Frequency 47โ€“63 Hz
Maximum Power 220 Watts
Operating System Support
Software Compatibility
Specification Value
Original OS Mac OS 7.5.5
Maximum OS Mac OS 9.1
Supported Range Mac OS 7.5.5 โ€“ 9.1
Timeline
Product Timeline
Event Date
6500/225 and 6500/250 Introduction February 17, 1997
6500/275 and 6500/300 Introduction April 4, 1997
All Models Discontinued March 14, 1998
