RetroTechCollection:Editing Tools
Revision as of 10:03, 25 March 2026 by Josh (talk | contribs)
The RTC Wiki Editing Tools are a suite of gadgets designed to speed up article creation on the RetroTechCollection Wiki.
Available Tools
Infobox Generator
Access: Special:BlankPage/InfoboxGenerator or via the toolbar button when editing an article.
A form-based tool for generating infobox wikitext. Supports both Computer and Peripheral/Accessory infobox types.
Features:
  • Form fields for all infobox parameters
  • Auto-linking for predecessor/successor fields
  • Correct image formatting (File: prefix, sizing)
  • Live preview via the wiki's parser
  • Copy to clipboard
  • Direct insertion into the editor
Spec Sheet Importer
Access: Special:BlankPage/SpecImporter
Imports technical specifications from EveryMac.com and maps them to RTC Wiki infobox fields.
Features:
  • Search EveryMac by model name
  • Quick-select dropdown for common Macintosh models
  • Full spec display with editable infobox field mapping
  • Side-by-side view: mapped fields + raw EveryMac data for reference
  • Generate infobox wikitext directly or fill the Infobox Generator form
  • Server-side caching (24 hours) to reduce EveryMac requests
Supported data mapping:
  • Release/discontinuation dates
  • CPU (processor type + speed)
  • Memory (standard + maximum)
  • Storage (HDD, floppy, optical)
  • Display (built-in + resolution)
  • Sound capabilities
  • Dimensions and weight
  • OS support range
  • Pricing
  • Model numbers
  • Case type โ†’ infobox type mapping
How to Enable
Both tools are enabled by default. You can manage them in Preferences โ†’ Gadgets under "Editing tools".
When enabled, both tools add links to the sidebar under "Tools":
  • Infobox Generator
  • Spec Importer
Workflow
A typical workflow for creating a new article:
  1. Open the Spec Importer (Special:BlankPage/SpecImporter)
  2. Search for the model (e.g. "Macintosh IIsi")
  3. Review and edit the imported specs
  4. Click "Generate Infobox Wikitext" โ€” the wikitext is copied to clipboard
  5. Create the new article and paste the infobox at the top
  6. Continue writing the article using the style guides
