File:Atari STBook Hardware Specification.pdf
[edit | edit source]ATARI STBook Hardware Specification, 10 September 1992. Published by Atari Corporation, marked "Atari Corporation Confidential".
Atari's own engineering description of the Atari ST Book: the MC68HC000 main system, the COMBO IC (memory controller, control logic and BLiTTER), pseudo-static RAM and its refresh machine, the IDE drive interface and its register map, the YM-3439 sound generator, the Ricoh RP5C15 real-time clock, the configuration switch register, the SHADOW LCD controller and the 640 x 400 panel, the BLiTTER, and pin assignments for the keyboard, parallel, RS232, MIDI and Pseudo-ACSI ports. Section 6 documents the 120-pin STBook/STylus expansion bus.
[edit | edit source]Internet Archive item Atari_STBook_Hardware_Specification_Sep_10_1992.
Licensing
[edit | edit source]Copyright ยฉ 1992 Atari Corporation. All rights reserved. No licence has ever been granted for redistribution. It is hosted here for the preservation and repair of obsolete hardware that has had no manufacturer support for over three decades. If you hold the rights to this document and want it removed, please contact the wiki operator.
| Date/Time | Dimensions | User | Comment | |
| current | 21:35, 23 September 2026 | 0 ร 0 (717 KB) | Josh (talk | contribs) | Atari's own STBook hardware specification, Sept 1992 |
