File:Peacedove.svg
Original file (SVG file, nominally 714 × 729 pixels, file size: 24 KB)
This file is from Wikimedia Commons and may be used by other projects. The description on its file description page there is shown below.
Description
English: Peace dove
Date
Source Own work
Author Mark Miller
Other versions
Derivative works of this file:
SVG development
InfoField
 The SVG code is valid.
 This icon was created with Inkscape…important.
Licensing
I, the copyright holder of this work, hereby publish it under the following license:
w:en:Creative Commons
attribution share alike
This file is licensed under the Creative Commons Attribution-Share Alike 3.0 Unported license.
You are free:
  • to share – to copy, distribute and transmit the work
  • to remix – to adapt the work
Under the following conditions:
  • attribution – You must give appropriate credit, provide a link to the license, and indicate if changes were made. You may do so in any reasonable manner, but not in any way that suggests the licensor endorses you or your use.
  • share alike – If you remix, transform, or build upon the material, you must distribute your contributions under the same or compatible license as the original.
Captions
Add a one-line explanation of what this file represents
Items portrayed in this file
depicts
17 October 2012
image/svg+xml
24,884 byte
243efb4aeca2ccb1ce1d3d797bec40affdb3d0cc
current07:39, 18 October 2012Thumbnail for version as of 07:39, 18 October 2012714 × 729 (24 KB)wikimediacommons>AmadscientistUser created page with UploadWizard
