Macintosh SE/30 Reloaded Logic Board
Type Logic Board
First released 2023
Latest revision N/A
Operating voltage —
Layers / PCB 4-layer PCB
Compatibility Macintosh SE/30
Model No. SE30RL
Overview
Fully assembled SE/30 Reloaded Logic Board (placeholder)
Preparation and Inspection
Step Description
Required Components and Tools
Components Tools
  • EPROM (27C64 Video ROM)
  • Hot air rework station
  • Fine-gauge solder (0.5mm)
  • ESD tweezers and microscope
  • GAL and EPROM programmers
Assembly Techniques
Surface-Mount Soldering
SMD soldering demonstration (placeholder)
Component Technique
Through-Hole Soldering
  2. All SMD passives
  3. SMD ICs and transistors
Power Check
File:Bench Test Setup.jpg
Bench power-up and testing (placeholder)
Subsystem Tests
Subsystem Verification
Subsystem Test
File:Diagnostic Screen.jpg
Simasimac error screen (placeholder)
Symptom Potential Cause
  • Optional 32-bit clean ROM SIMM support (no need for MODE32).
  • Modern Molex-style power connector instead of card-edge.
Community Resources
Conclusion
The Macintosh SE/30 Reloaded Logic Board project brings new life to vintage hardware. Designed by the community, it offers a reliable, clean, and modern way to revive a classic machine—with the flexibility to tinker, experiment, and extend.
This page is based on extensive community documentation, builder experiences, and verified design files. Please consult the official GitHub repository and forums for the most current support and development updates.
