IBM 3270 PC Maintenance Guide
Revision as of 22:32, 23 May 2026 by Josh (talk | contribs) (Deep technical XT/370 + 3270 PC family page with verified sources (IBM SA38-0037-00 Service Info Manual, IBM GA33-3141-0, IBM 1502336, Kozuh/Livingston/Spillman IBM Systems Journal 1984, seasip.info, Wikipedia))
This guide documents preventive maintenance for the IBM 3270 PC (machine type 5271, 1983). Because the 3270 PC chassis is mechanically an IBM PC XT (5160), chassis-level maintenance is identical to the XT; the 3270-specific procedures cover the specialist cards (Keyboard Adapter, 3270 PC Display Adapter, APA, PSS, 3278/79 Emulation Adapter), the 5271 Keyboard Element, the 5272 colour display, and the 3270 PC Control Program software environment.
Safety Warning
The 3270 PC uses the standard IBM 130 W switching PSU (Astec / Zenith). Mains-rectified bulk capacitors hold a lethal charge after power-off. Before any work inside the chassis:
  1. Power off and unplug the mains lead.
  2. Wait at least 30 seconds.
  3. Discharge each PSU bulk filter capacitor through a 1 kΩ / 5 W resistor.
  4. Verify with a multimeter.
The IBM 5272 / 5151 displays carry lethal high voltage on the flyback transformer and anode. Discharge the CRT anode to chassis ground via a high-voltage probe before any work on the display.
Documentation Set
  • IBM SA38-0037-00Personal Computer Family Service Information Manual (July 1989), Chapter 10 covers the 3270 PC family (5271 and 5371).
  • IBM G320-9539-0IBM 3270 Personal Computer Hints and Tips (June 1986).
  • IBM 1502336PC 3278/79 Emulation Adapter Technical Reference (October 1983).
  • IBM SC23-0103-23270 PC Control Program User's Guide and Reference (July 1984).
  • IBM 84X09823270 Workstation Program v1.0 User's Guide and Reference (April 1987) — the Control Program's software-only successor.
  • IBM 59X8423PC 3270 Emulation Program v2.00 User's Guide (March 1986).
  • IBM 83X9705IBM 3270 Connection Technical Reference (April 1987).
Opening the System Unit
Identical to the IBM PC XT (5160) Maintenance Guide:
  1. Power off and unplug all cables (mains, keyboard, video, printer, BNC twinax to controller).
  2. Five Philips #2 screws on the rear panel.
  3. Slide cover forward to release.
The 3270 PC interior is densely populated. A typical full configuration occupies:
  • Slot 1 — IBM Hard Disk Adapter (Model 6 / 30 / 50 / 70).
  • Slot 2 — Floppy Disk Adapter.
  • Slot 3 — 3270 PC Display Adapter.
  • Slot 4 — APA card (optional).
  • Slot 5 — PSS card (optional).
  • Slot 6 — 3278/79 Emulation Adapter.
  • Slot 7 — Keyboard Adapter card.
  • Slot 8 — XMA (1986 31/51/71 models) or other expansion.
All slot positions can vary; check the as-built configuration of your specific machine.
Card Inventory at Service Time
For each service visit, verify the card complement and check the as-built ROMs:
  1. Keyboard Adapter — Two ROM variants: 6323581 (simple) or 6323582 (complicated with NMI + serial). Critical: this card holds the video BIOS for the 3270 PC Display Adapter. Without it, the video cards do nothing.[1]
  2. 3270 PC Display Adapter — SCN2672 PVTC at 0180h–019Bh. Inspect the SCN2672 socket for oxidation.
  3. APA card (where fitted) — adds CGA modes + 3270-PC graphics modes.
  4. PSS card (where fitted) — Programmed Symbol Set, RAM-loaded fonts.
  5. 3278/79 Emulation Adapter — I/O at 2D0h–2D6h (older) or 2D0h–2D7h (newer). BNC twinax to controller.
Keyboard Adapter Dongle
A small external "dongle" cable splits the keyboard adapter card's DE-9 connector at the rear of the chassis into two 5-pin DIN connectors:
  • One for the 122-key 5271 Keyboard Element.
  • One that passes through to the standard XT keyboard port on the planar.
The dongle is a known service item — it can be lost, worn, or pin-damaged. Pinout is documented at seasip.info and is reproducible by a competent hobbyist with a soldering iron and the right connector shells.
PSU Voltage Checks
Same as the standard XT — see IBM PC XT (5160) Maintenance Guide.
A fully-loaded 3270 PC (all card slots occupied, hard drive fitted) draws close to the PSU's 130 W capacity. Rail sag under load is more common than on a stock XT and is the first symptom of aged PSU electrolytics — see IBM 3270 PC Capacitor Replacement Guide.
5271 Keyboard Element Maintenance
The 122-key Model F is a robust mechanism but has some specific service items:
  • Foam pad degradation under the buckling-spring capacitive pads — common on Model F keyboards of this era. Symptom: keys stop registering or require excessive force. Replacement foam is available from the Model F restoration community.
  • Cable strain relief — heavy cable on the keyboard side can damage the wire harness near the cable entry.
  • Keycap removal — use the IBM tool. Do not pull keycaps by hand; the stems are easily damaged.
  • Microcontroller (IBM part 1503828 / Motorola SC81155P) — described as "possibly a microcontroller" by community researchers; failure mode is uncertain because the part has never been publicly decapped. Replacement requires a donor keyboard with the same firmware.
Display Maintenance
IBM 5272 Color Display
  • CRT discharge: 12–15 kV at the anode.
  • Inspect flyback for cracked insulation.
  • Pin 4 of the DE-9 selects mono vs colour. If the display does not show colour, verify pin 4 is being correctly asserted by the host.
  • Color timings: hsync 24 kHz negative, vsync 63 Hz negative. Out-of-spec timings produce display drift / rolling.
IBM 5151 Monochrome Display
  • Standard IBM 5151 maintenance — see standard IBM PC documentation.
IBM 3295 Plasma Monitor
  • Plasma displays of this era can develop pixel rot. Severely affected panels are not repairable; replacement requires a donor.
  • Supports 62 × 160 or 46 × 106 text grids.
Cable to 3174 / 3274 Controller
The 3270 PC connects to a host mainframe through an IBM 3174 or 3274 cluster controller via BNC twinax (or RG-62 coax with BNC terminators). Maintenance:
  • Clean the BNC connector on both sides with deoxidising contact cleaner.
  • Verify the cable is properly terminated at the controller end (75 Ω terminator).
  • Verify the controller-side port is configured for a 3278 or 3279 emulator (the 3270 PC presents itself as a 3278 LU to the controller).
3270 PC Control Program Maintenance
The Control Program is on diskette (Models 2 / 4 / 24) or pre-installed on the hard drive (Models 6 / 26 / 30 / 50 / 70). Service items:
  • Image the Control Program diskettes immediately if you have an original set — they are increasingly rare and the install procedure required mainframe sysprog assistance in period.
  • Control Program v3.0 is required for Models 31/51/71 and all P-models. Earlier versions will not boot on these.
  • If a Control Program install fails on a P-model, verify the keyboard is a 101-key Enhanced AT-style — the P-models do not work with the 122-key 5271 Keyboard Element.
Floppy and Hard Drive Maintenance
Standard IBM PC XT 5.25" 360 KB DSDD floppy and 10 MB ST-412 (Model 6) or 20 MB hard drive (Models 30 / 50 / 70). Maintenance is identical to the IBM PC XT (5160) Maintenance Guide.
  • Philips #2 and T15 / T20 Torx screwdrivers.
  • Anti-static strap.
  • Digital multimeter with HV-rated probe.
  • High-voltage probe for CRT discharge.
  • IPA + foam swabs.
  • Soldering iron (fine tip) + solder wick.
  • Deoxidising contact cleaner.
  • IBM keycap removal tool (for the 5271 Keyboard Element).
  • Spare BNC terminators and RG-62 patch cables.
  • SA38-0037-00 PDF (chapter 10).
  • 1502336 PC 3278/79 Emulation Adapter Technical Reference PDF.
