Macintosh Quadra 800 Troubleshooting
Troubleshooting is essential for diagnosing and resolving issues with your Macintosh Quadra 800. This guide covers the most common problems encountered with this system.
Preliminary Checks
editBefore detailed troubleshooting, verify:
- Power cable is securely connected
- Power outlet is functional (test with another device)
- All internal cables are properly seated
- PRAM battery is installed and has charge
- No foreign objects are inside the case
Power Supply Specifications:
- Input: 100V-240V AC, 47-63 Hz
- Maximum: 200 watts
No Power (System Dead)
edit| Symptom | Possible Cause | Recommended Action |
| No response when power button pressed | Dead PRAM battery | Replace 3.6V lithium battery |
| No response | Failed power supply | Test PSU voltages; replace if out of spec |
| No response | Faulty power switch | Test continuity of power switch; replace if faulty |
| Power light on, no startup | Logic board failure | Check for corrosion, reseat chips, test components |
| Ticking or clicking sound | Short circuit or PSU issue | Disconnect all peripherals and internal drives; test bare system |
Power Supply Testing
editMeasure voltages at the logic board power connector:
- +5V: Should read 4.85V – 5.15V
- +12V: Should read 11.9V – 12.7V
- -12V: Should read approximately -12.0V
If voltages are out of specification, the power supply may need capacitor replacement or full replacement.
Startup Chime but No Video
| Chime, no video on any monitor | Failed VRAM | Reseat or replace VRAM SIMMs |
| Chime, no video | Faulty video output circuit | Test with NuBus video card if available |
| Chime, no video | Incompatible monitor | Try a different monitor or adapter |
| Distorted or garbled video | VRAM failure | Replace VRAM SIMMs |
| Distorted video | Incorrect VRAM configuration | Ensure matching VRAM SIMMs are installed |
| Video works on NuBus card only | On-board video failure | Use NuBus video card as workaround; logic board repair needed for on-board video |
| Random freezes | Bad RAM | Test RAM modules individually; replace faulty SIMMs |
| Random freezes | Overheating | Clean dust from interior; verify fan operation |
| Boots sometimes, not others | Weak PRAM battery | Replace PRAM battery |
| Boots sometimes | Marginal power supply | Test voltages under load; recap or replace PSU |
| Freezes during disk access | SCSI issues | Check termination, cables, and device IDs |
| Freezes during disk access | Failing hard drive | Run diagnostic software; backup and replace drive |
Sad Mac Error Codes
editA Sad Mac icon indicates a hardware failure detected during POST. The codes displayed below the icon help identify the failing component.
See the Sad Mac Error Codes page for a comprehensive list.
Common Quadra 800 Sad Mac Codes:
| Code | Meaning | Action |
| 0000000F 00000001 | ROM test failed | Logic board fault; may need repair |
| 0000000F 00000002 | Memory test failed | Test/replace RAM SIMMs |
| 0000000F 00000003 | Memory addressing error | Check SIMM seating; test individual SIMMs |
| 0000000F 00000004 | Memory test — byte error | Replace faulty SIMM |
| 0000000F 0000000E | Data bus test error | Logic board issue |
| 0000000F 0000000F | Address line test error | Logic board issue or RAM problem |
SCSI Issues
| Flashing question mark | No bootable drive found | Check SCSI cables and termination; verify drive is spinning |
| Flashing question mark | Corrupt system folder | Boot from CD or floppy; reinstall system |
| Drive not recognized | Incorrect SCSI ID | Ensure unique IDs (0-6) for each device |
| Drive not recognized | Missing termination | Add terminator to last device in chain |
| Intermittent SCSI errors | Bad cables | Replace SCSI ribbon cable |
| External device not seen | Termination power issue | Some devices need termination power; check settings |
Memory Issues
| Sad Mac on startup | Faulty SIMM | Remove SIMMs one at a time to identify bad module |
| Less RAM recognized than installed | Incompatible SIMM | Use 60 ns or faster 72-pin SIMMs |
| Less RAM recognized | SIMM not fully seated | Reseat all SIMMs |
| Intermittent errors | Dirty contacts | Clean SIMM contacts with isopropyl alcohol |
| Memory errors in specific applications | Marginal SIMM | Replace SIMM even if it passes basic tests |
Floppy Drive Issues
editSee: Macintosh Floppy Drive Maintenance
| Disk not recognized | Dirty heads | Clean heads with cleaning disk |
| Disk not recognized | Misaligned heads | Professional realignment or drive replacement |
| Disk ejects immediately | Bad disk | Try different disk |
| Disk ejects immediately | Drive failure | Replace floppy drive mechanism |
| Read/write errors | Worn heads | Replace floppy drive |
CD-ROM Issues
editIf equipped with the AppleCD 300i:
| Disc not recognized | Dirty laser lens | Clean lens with appropriate cleaner |
| Disc not recognized | Incorrect SCSI ID | Verify CD-ROM has unique SCSI ID (typically 3) |
| Audio CDs don't play | Software issue | Check CD player software settings |
| Slow reading | Dirty lens | Clean laser lens |
| Tray won't open | Mechanical failure | Use emergency eject hole; may need drive replacement |
NuBus Card Issues
| Card not recognized | Poor contact | Reseat card firmly |
| Card not recognized | Dirty contacts | Clean card edge connector with isopropyl alcohol |
| System unstable with card | Incompatible card | Check compatibility; update drivers |
| System unstable with card | Power supply overloaded | Remove other cards; test individually |
| Conflicts between cards | Resource conflicts | Try different slot configurations |
Startup Sequence
editNormal Quadra 800 startup sequence:
- Power supply activates
- Startup chime sounds
- POST (Power-On Self-Test) runs
- RAM test completes
- SCSI bus scans for devices
- Boot device selected
- System software loads
- Desktop appears
If the sequence fails at any point, the failure location indicates which component to troubleshoot.
editThe Quadra 800 carries a 3.6 V 1/2AA lithium PRAM battery. These leak and can burst, spraying corrosive electrolyte across the logic board and destroying nearby components — often while the machine simply sits in storage. Remove the PRAM battery from any un-serviced unit. If one has leaked, neutralise and clean the residue and repair corroded traces and vias before troubleshooting.[1]
editUnlike the LC and Mac II surface-mount-electrolytic boards, the 68040-family Quadra 800 logic board uses tantalum capacitors, which do not leak with age — the logic board does not normally need recapping. If the board misbehaves, look to leaked-PRAM-battery corrosion, socket/connector contacts and the power supply rather than to board capacitors.[2]
editThe power supply uses electrolytic capacitors that fail with age (fails to power on, unexpected power-off, clicking when plugged in). Recap the power supply and confirm the rails.[3]
edit- ↑ "Warning! Exploding Maxell PRAM Batteries", 68kMLA; and MacDat — Macintosh II family. Source for the leaking/exploding lithium PRAM battery that destroys nearby components.
- ↑ "Apple Macintosh Quadra 650", Retro Viator; and the Apple Macintosh Quadra/Centris 650 Service Source. Source for the 68040-family logic boards using tantalum capacitors (no logic-board recap needed) while the power supply uses electrolytics that do need replacing.
- ↑ "Compact/Desktop Power Supply Capacitor Lists (by make and model)", 68kMLA; and "Capacitor Replacement in a Vintage Power Supply", Big Mess o' Wires. Source for the shared desktop PSU form factor (IIci/IIcx/IIvi/IIvx/Performa 600/Quadra 650/Quadra 700), the electrolytic failure symptoms and the PSU capacitor lists.
editSurface-mount capacitor leakage
editThe Macintosh Quadra 800 logic board uses surface-mount electrolytic capacitors whose electrolyte turns corrosive with age and creeps across the board, eating through traces, pads and IC pins. Typical signatures are a machine that will not chime, chimes but shows no video, plays distorted or missing audio, or shows a garbled or checkerboard screen. Wash the affected area and replace every electrolytic with a tantalum or polymer part, then repair any lifted traces. The switch-mode power supply (ASTEC or TDK on the LC-family machines) holds its own electrolytics and fails the same way, so recap it alongside the board.[1]
PRAM battery
editThe Macintosh Quadra 800 backs up its clock and Parameter RAM from a 3.6 V ½AA lithium cell. These cells — red Maxell parts especially — leak or burst and corrode the board, so remove an aged one on sight. A flat cell can also stop a soft-power machine booting or disturb the video; left plugged in, trickle power preserves the settings, but a machine switched off at the wall with a dead cell loses them. Clean the area and fit a fresh 3.6 V cell.[2]
Boot chime and Sad Mac
editRead the start-up sound first: a normal chime with a black screen points to the display path or the monitor, an absent chime or a "chord of death" points to RAM or a core fault, and a Sad Mac shows a numeric code — see Sad Mac Error Codes.
Related Pages
edit- Macintosh Quadra 800 General Maintenance
- Macintosh Quadra 800 Capacitor Replacement Guide
- Sad Mac Error Codes
- ↑ Mac84, Macintosh LC series power-supply recapping guide; the MacCaps capacitor reference; and iFixit. Source for surface-mount electrolytic leakage eating traces, pads and pins, the ASTEC/TDK LC power-supply cap failures, and Apple's use of tantalum (non-leaking) capacitors on the Quadra 700/900 logic boards.
