Capacitors are critical components in all electronic devices, providing filtering, decoupling, timing, and voltage regulation. Over time, capacitors—especially electrolytic capacitors—can degrade or fail entirely. Recognizing the symptoms of failing capacitors is essential for diagnosing and repairing vintage or modern electronics.
⚠️ Common Symptoms of Capacitor Failure
| Symptom |
Description |
Common Devices Affected
| Bulging or domed tops |
The capacitor’s top should be flat. Bulging indicates internal gas buildup from dielectric breakdown. |
Power supplies, motherboards, CRTs
| Leaking electrolyte |
Brown, tan, or white crust forms around capacitor base or vents. This corrosive fluid damages nearby components and PCB traces. |
Analog boards, vintage computers, audio gear
| No power / intermittent startup |
Failed power filter capacitors cause voltage drops or power-up failure. |
TVs, amplifiers, game consoles, PCs
| High-pitched whining or buzzing |
Failing capacitors in switching circuits may cause coil whine or unstable oscillation. |
Power bricks, CRTs, LCDs
| Image distortion / display anomalies |
In CRTs or LCDs, bad capacitors in video or deflection circuits can cause image ripple, shrinking, or flicker. |
Monitors, televisions
| Audio distortion or hum |
Filtering capacitors in amplifiers may leak or dry out, introducing 60Hz hum, buzzing, or reduced volume. |
Audio receivers, speakers, synths
| Overheating components |
Failed capacitors cause voltage ripple, making voltage regulators or power ICs run hot. |
Any device with power regulation
| Reboot loops or crashing |
Voltage instability causes CPUs or logic systems to behave unpredictably. |
Routers, computers, set-top boxes
🔍 Visual Signs of Capacitor Damage
Electrolytic Capacitors
- Bulging vent on top
- Leaking fluid at base
- Discolored PCB area
- Burnt or corroded leads
- Lifted or cracked casing
Tantalum Capacitors
- Usually fail short-circuit
- May exhibit smoke, spark, or explosion
- Blackened or cracked shell
Ceramic Capacitors
- Rarely leak, but can:
- Crack due to stress
- Short if physically damaged
- May show no outward signs but cause logic instability
🧪 How to Test a Suspect Capacitor
| Method |
Tool Required |
Notes
| Visual inspection |
None |
First and easiest check
| ESR testing |
ESR meter |
Low ESR is critical for power filtering
| Capacitance measurement |
Capacitance meter |
Must desolder at least one leg
| Multimeter continuity test |
Digital multimeter |
Detects shorts or opens in some cases
🛠️ Recommended Action
- Always replace failed capacitors with equal or higher voltage rating.
- Use 105°C-rated capacitors in power supplies for longevity.
- When possible, choose Japanese-brand capacitors (e.g., Nichicon, Rubycon, Panasonic).
- Clean the PCB after leakage using isopropyl alcohol and inspect for damaged traces.
- Recap entire groups of capacitors together if failures are widespread.
💡 Preventative Tips
- Power up vintage gear periodically to help reform capacitors.
- Store electronics in cool, dry environments.
- Avoid prolonged exposure to heat, dust, or moisture.
📚 Related Pages
