The Macintosh SE utilizes 30-pin SIMM (Single Inline Memory Module) chips and supports the following configurations:
Macintosh SE RAM Configurations
Total RAM SIMM Configuration Individual SIMM Capacity
1 MB (stock) 4 ร— 256 KB 256 KB
2 MB 4 ร— 512 KB 512 KB
2.5 MB 2 ร— 512 KB + 2 ร— 1 MB Mixed (512 KB & 1 MB)
4 MB (maximum) 4 ร— 1 MB 1 MB
  • The Macintosh SE requires SIMMs with 150 ns or faster access time.
  • All four SIMM slots must be populated with memory of the same capacity unless using a 2.5 MB mixed configuration.
    • If using the 2.5 MB configuration, install the 1 MB SIMMs in Slots 1/2 and 256 KB SIMMs in Slots 3/4.
  • If using 1 MB SIMMs, you must clip the R35 resistor on Rev 1 logic boards, or, move the jumper in the same location on Rev 2 boards.
Macintosh SE (Soldered) Memory Upgrade Guide
Macintosh SE (Jumpers) Memory Upgrade Guide
๐Ÿ›  Required Tools
To upgrade the Macintosh SE memory, you will need:
  • Torx T15 screwdriver (for case removal)
  • Plastic spudger or pry tool (to carefully separate the case)
  • Anti-static wrist strap (to prevent electrostatic discharge)
  • Compatible 30-pin SIMMs (matching capacity and speed)
๐Ÿ”ง Memory Upgrade Procedure
Step 1: Prepare the Macintosh SE Ensure the Macintosh SE is completely powered off and unplugged. Work on a grounded surface and wear an anti-static wrist strap to protect components from static discharge.
Step 2: Remove the Case Use a Torx T15 screwdriver to remove the four screws securing the rear case. Carefully separate the two halves using a plastic spudger. Be cautious of the CRT, as it retains high voltage even when unplugged.
Step 3: Locate the SIMM Slots The memory slots are on the logic board, positioned near the rear ports. You'll need to slide the logic board out from the bottom metal chasis.
Step 4: Remove Existing SIMMs If replacing existing memory, gently (they easily snap) push apart the retention clips on each side of the SIMM slot and remove the modules.
Step 5: Install New SIMMs Align the new SIMMs with the slots, ensuring the notch on the side of the SIMM matches the keying of the slot. Firmly push down until the SIMM snaps into place.
  • If upgrading to 4 MB using 1 MB SIMMs, clip the leg on the R35 resistor, or move the jumper on the logic board.
  • If using a 2.5 MB mixed configuration, install 1 MB SIMMs in Slots 1/2 and 256 KB SIMMs in Slots 3/4.
Step 6: Reassemble the Macintosh SE Once the memory is installed, reassemble the case and secure it with the Torx screws.
Step 7: Verify the Upgrade Power on the Macintosh SE and check the memory count within the Finder. If the full capacity is not recognized, ensure:
  • All SIMMs are properly seated.
  • SIMMs are of matching speed and configuration.
  • The correct resistor was clipped for 1 MB SIMMs.
โ— Common Issues and Troubleshooting
Issue Possible Cause Solution
Macintosh SE beeps on startup Incompatible or faulty SIMMs Ensure SIMMs are 30-pin, 150 ns or faster, properly seated and (or) Non-Parity
Memory not recognized correctly Mismatched SIMM capacities Use four identical SIMMs or a supported 2.5 MB configuration.
System crashes or instability Faulty or damaged SIMMs Replace with known-good, compatible memory modules.
๐Ÿ“œ Additional Resources
