Macintosh SE FDHD
Revision as of 18:47, 1 October 2026 by Josh (talk | contribs) (Remove Category:Compact Macintosh (created in error, to be deleted))
The Macintosh SE FDHD is the Macintosh SE with Apple's 1.4 MB high-density floppy drive (FDHD, "floppy drive high density", later sold as the SuperDrive). It replaced the 800 KB SE on 1 August 1989 and was itself replaced on 15 October 1990, the day the Macintosh Classic was introduced.[1] EveryMac gives the price as US$3,700 and the model number as M5011.[2]
Macintosh SE FDHD
Macintosh SE FDHD, with the "FDHD" badge under the name (All About Apple museum, Wikimedia Commons, CC BY-SA 3.0)
TypePersonal computer
Released1 August 1989
Discontinued15 October 1990
Intro priceUS$3,700
CPUMotorola 68000 at 7.8336 MHz
Memory1 MB, expandable to 4 MB (30-pin SIMMs, 150 ns or faster)
Storage1.4 MB SuperDrive; optional second floppy drive, or 20 or 40 MB internal SCSI hard disk
Display9-inch monochrome CRT, 512 × 342 pixels
SoundFour-voice, 8-bit D/A conversion, 22 kHz sampling
ROM256 KB
ExpansionMacintosh SE expansion slot, 96-pin Euro-DIN
Power90–140 V AC or 170–270 V AC, 47–63 Hz, 100 W maximum
Dimensions13.6 × 9.6 × 10.9 in (34.5 × 24.4 × 27.6 cm)
Weight17–21 lb (7.7–9.5 kg), depending on drives fitted
OS / FirmwareSystem 6.0.3 – System 7.5.5
PredecessorMacintosh SE
SuccessorMacintosh Classic
Model no.M5011
Apart from the drive, its controller and its ROMs, the FDHD is the same machine as the SE: same case, analogue board, power supply, memory rules and service manual. The Macintosh SE/30, introduced in January 1989, had already brought the high-density drive to the compact Macs.[3]
What changed from the SE
  • The SWIM (Super Woz Integrated Machine), a development of the IWM, replaces it as the floppy controller, and the FDHD drive reads, writes and formats 400 KB, 800 KB and 1.4 MB disks.[4]
  • New ROMs support the drive. System 6.0.3 or later is required; with older software the SE mistakes the high-density drive for an 800 KB mechanism.[5]
  • The front bezel carries a high-density drive label, which Apple says may read "FDHD", "1.4 MB" or "SuperDrive".[5]
An older SE with its original ROMs cannot use high-density disks, but can use an FDHD drive with 800 KB disks.[1]
Identifying an FDHD logic board
Apple's rule for choosing an exchange logic board:[5]
  • battery in a holder: the machine shipped with the 1.4 MB drive, so use board 661-0536;
  • soldered battery with an IWM (disk controller not marked 344-0062): an 800 KB SE, board 661-0526;
  • soldered battery with a SWIM (344-0062): an SE upgraded with the kit below; use 661-0526 and move the customer's SWIM and ROMs across.
The 1.4 MB drive upgrade
Apple's SuperDrive Upgrade Kit for the SE contains two ROMs, a SWIM, an audio extension cable with a ferrite bead to reduce interference, the 1.4 MB drive, system software, two labels and a return form. The procedure:[5]
  1. Remove the cover, discharge the CRT, and remove the video board, the hard disk or upper floppy drive, the logic board and the lower floppy drive. See CRT Discharge Procedure.
  2. With an IC extractor, remove the IWM and the two ROMs.
  3. Fit the SWIM (344-0062) at D8, the high ROM (342-0701) at D6 and the low ROM (342-0702) at D7, each with its notch towards the RAM SIMMs.
  4. Fit the 1.4 MB drive as the lower drive, then refit the logic board, the upper drive, the video board and the cover.
  5. Put the high-density label next to the lower drive slot, install System 6.0.3 or later, and run diagnostics.
  6. Fit the audio extension cable, ferrite end towards the audio jack, between the audio cable and the rear audio jack.
Pina records one self-inflicted fault: an SE that shows a black-and-white checkerboard with no startup sound immediately after this upgrade has a reversed or misplaced ROM or controller chip at D6, D7 or D8.[6]
Apple recommends dust shields on all 1.4 MB drives. Replacement drives ship with one fitted; clean an existing drive before adding a shield.[5]
Apple's SE Service Source describes the FDHD machine; its specification pages list a 1.4 MB floppy drive.[5] The full table is on Macintosh SE#Specifications. The PRAM battery threshold is the SE's: replace the cell if it reads below 2.8 V.[5]
Maintenance and repair
The FDHD shares its maintenance, troubleshooting and capacitor pages with the SE:
  1. ↑ 1.0 1.1 Mac SE, Low End Mac—link(accessed 2026-09-30) The SE page also covers the FDHD: introduction and discontinuation dates, order number M5011.
  2. ↑ Macintosh SE FDHD Specs, EveryMac.com—link(accessed 2026-09-30)
  3. ↑ Mac SE/30, Low End Mac—link(accessed 2026-09-30)
  4. ↑ Apple Computer, Guide to the Macintosh Family Hardware, 2nd edition, Addison-Wesley, 1990, Chapter 1, p. 21. Hosted here: File:Apple Guide to the Macintosh Family Hardware 2nd Edition 1990.pdf.
  5. ↑ 5.0 5.1 5.2 5.3 5.4 5.5 5.6 Apple Computer, Macintosh SE Service Source (126 pp.), hosted here as File:Macintosh SE.pdf (see Macintosh SE Service Source). Specifications PDF pp. 6–13; Upgrades, 1.4 MB Drive Upgrade, PDF pp. 87–95; Take Apart, floppy drives, PDF pp. 55–59; Additional Procedures, Battery Verification PDF p. 98 and Identifying SE Logic Boards PDF pp. 106–111.
  6. ↑ Larry Pina, The Dead Mac Scrolls, Peachpit Press, 1992, p. 174. Hosted here: File:The Dead Mac Scrolls 1992.pdf.
