Apple Studio Display 15
Revision as of 12:17, 2 October 2026 by Josh (talk | contribs) (New page: display overview, specifications and parts from Apple Service Source and service guide, cited)
The Apple Studio Display 15 is Apple's first desktop flat-panel display: a 15.1-inch TFT active-matrix LCD with a fixed 1024 × 768 resolution, an external power adapter, and inputs for S-video and composite video as well as the computer.[1] Apple made three versions of it. The original (Rev. A, in dark blue and grey, "azul") and the Rev. B of January 1999 (translucent blue and white, with a VGA connector) have the same internal circuitry. The DVI version of December 1999, in graphite, has a digital DVI input and a USB hub and drops the video and audio connections.[2]
The original Studio Display (15-inch flat panel) on its desktop stand (Apple press photo, 1998)
Type 15.1-inch TFT active-matrix LCD display
Release date 1998
Interface Rev. A: 15-pin D-sub RGB; Rev. B: 15-pin mini D-sub VGA; both with ADB, S-video, composite video and audio. DVI version: DVI with a two-port USB hub
Weight 5.5 kg (12 lb) on the desktop stand; 3.5 kg (7.7 lb) on the picture-frame stand
Model M6356LL/A, M6356LL/B (number on the display: M4551); DVI: M7612LL/A (M7613)
Power 100-240 V AC, 50-60 Hz, through an external power adapter; under 35 W operating
Resolution 1024 × 768 native
Apple's DVI Service Source dates the original to May 1998.[2] Wikipedia gives its introduction as 17 March 1998, at the Seybold Seminars alongside the Power Macintosh G3/300, at US$1,999, and says a later 15-inch Studio Display with the Apple Display Connector and a clear easel stand followed in July 2000.[3]
Versions
The three analogue and DVI versions (Apple Service Source)[2]
Feature Rev. A Rev. B DVI
Introduced May 1998 January 1999 December 1999
Housing Azul (dark blue) and grey Translucent blue and white Graphite
Number on the display M4551 M4551 M7613
Data sheet number M6356/A M6356/A M7612/A
Video Analogue RGB Analogue RGB, VGA connector DVI digital
Control link ADB, on-screen display ADB, on-screen display USB, two downstream ports
Other inputs Composite and S-video, audio in and out Composite and S-video, audio in and out None
Video standards NTSC, PAL, SECAM NTSC, PAL, SECAM Not supported
Scaling Genesis GMZ1 Genesis GMZ1 ATI ratiometric
Requires PowerPC Mac OS 7.5 or later; Windows 95/NT PowerPC Mac OS 8.0 or later; Windows 95/NT AGP Power Mac G4, Mac OS 9.0 or later
The Rev. B data sheet gives order number M6356LL/B and the DVI data sheet M7612LL/A.[4][5]
The panel is a 15.1-inch TFT active-matrix LCD with a native 1024 × 768; Apple quotes typical brightness of 200 cd/m², contrast of 200:1 and viewing angles of 120° horizontal and 90° vertical.[1] Power comes from an external adapter; the Rev. A and Rev. B use adapter 922-3147 and the DVI version 922-4166.[1][2] Two stands came with each display, a desktop stand with tilt, swivel and height adjustment and a flip-out "picture-frame" stand.[1]
Apple did not supply parts inside the display: the display assembly is marked "not offered" in all three exploded views, and Apple's take-apart covers only the stands and the audio/video door.[1][2] In the US the display was repaired by mail-in through Apple's service facilitation process; in Canada the strategy was whole-unit replacement.[1]
Backlights and power
Apple's charts attribute a screen that has dimmed over time to failing backlights, which it gives an average life of 10,000 hours (about 40 hours a week for five years), and referred backlight replacement to Apple or an authorised dealer.[1] On the DVI version, a power light that repeats two short amber flashes and one long one indicates a backlight problem.[2]
Displays often turn up without their power adapter. TinkerDifferent members report that the adapter for the Rev. B (M4551) is rated 24 V at 1.875 A, that its plug is centre positive, and that the socket on the display cable takes a 5.5 × 2.5 mm barrel plug; one member ran the display from a generic 24 V 2 A supply through a barrel adapter, and another converted an old Verifone power adapter.[6] Check the polarity and voltage of any substitute before connecting it.
See Apple Studio Display 15 Troubleshooting Guide.
  1. ↑ 1.0 1.1 1.2 1.3 1.4 1.5 1.6 Apple Computer, Studio Display (15" flat panel) (Service Source), 55 pages, hosted as File:Apple studio display.pdf (see Studio Display (15" flat panel) Service Source). PDF page numbers: Overview pp. 3-4 (desktop stand and flip-out stand); Features p. 5; U.S. and Canada repair strategy pp. 6-10; Front View p. 11; Back View pp. 12-16 (A/V door ports, cable door with display cable, power adapter cable and ADB port; desktop stand with height adjustment and cable guide; two ADB ports on the stand base); Repair Issues: New Rev. B Version pp. 17-19 (January 1999; same performance and internal circuitry; VGA connector and VGA-to-Macintosh adapter; aqua and white housing); data sheets pp. 22-25; Troubleshooting pp. 27-32; Take Apart pp. 34-46; Exploded Views pp. 54-55.
  2. ↑ 2.0 2.1 2.2 2.3 2.4 2.5 Apple Computer, Studio Display DVI (Service Source), 53 pages, hosted as File:Studio.15dvi.pdf (see Studio Display DVI Service Source). Basics: features comparison of the DVI, Rev. B and Rev. A versions (housing, introduction dates December 1999, January 1999 and May 1998, numbers on the back of the display M7613, M4551 and M4551, numbers on the data sheet M7612/A, M6356/A and M6356/A, interfaces, controls, rear ports, power management, scaling chips and system requirements); DVI connector; repair strategy. Troubleshooting: First Checklist p. 28; No Image p. 29; Screen Resolutions p. 30; Screen Color p. 31; Screen Brightness p. 32; Focus p. 33; Error Messages p. 34; Error Lights p. 35; Miscellaneous pp. 36-38. Exploded view p. 53.
  3. ↑ Wikipedia, "Apple Studio Display (1998–2004)" (retrieved 2026-10-02). The 15-inch flat panel introduced at Seybold 1998 with the Power Macintosh G3/300 DT at US$1,999 (citing Macworld, June 1998); DA-15 input, two ADB ports, S-video and composite inputs, audio connectors; blueberry and white restyle with brighter panel and lower price (US$1,099) at Macworld January 1999; DVI and USB version; ADC model with a clear three-legged stand in July 2000, discontinued January 2003. History only.
  4. ↑ Apple Computer, Apple Studio Display data sheet (15.1-inch flat panel), L03512A, January 1999, hosted as File:Apple Studio Display 15-inch Data Sheet (January 1999).pdf (see Apple Studio Display 15 Documentation). 15.1-inch viewable TFT active-matrix LCD; 640 × 480 to 1024 × 768 at 60, 70 or 75 Hz; 15-pin mini D-sub VGA connector, two ADB connectors, S-video, composite video, two RCA audio inputs, DC input, mini-stereo audio output; 100-240 V AC, 50-60 Hz, under 35 W operating; 12 lb (5.5 kg) on the desktop stand, 7.7 lb (3.5 kg) on the picture-frame stand; tilt, swivel and height adjustment; operating 10-35 °C; does not work with PowerBook 1400, 3400 or 5300 or the PowerBook Duo 2300; order number M6356LL/B.
  5. ↑ Apple Computer, Apple Studio Display data sheet (15-inch flat panel, DVI), L04975A, December 1999, hosted as File:Apple Studio Display 15-inch DVI Data Sheet (December 1999).pdf. DVI 24-pin connector, two-port self-powered USB hub, DC input; 1024 × 768 native; 100-240 V AC, under 35 W; for the Power Mac G4 with ATI Rage 128 Pro graphics and built-in USB; order number M7612LL/A.
  6. ↑ TinkerDifferent forum thread "Apple 15 inch Studio Display (M4551) missing a power supply", February 2024 to January 2026. ComputerCompulsive: the blueberry display takes a 45 W, 24 V, 1.875 A adapter; later used a replacement with adapters. Fizzbinn: measured the plug as centre positive. PopeLeo: measured the barrel jack on the display as 5.5 × 2.5 mm; a generic 24 V 2 A supply with a female-to-female 5.5 × 2.5 mm adapter worked. Elemenoh: converted a Verifone power adapter with a female barrel connector. Community experience.
