The legendary Commodore 64 (C-64, C64 C, “bread bin”, 64C, Aldi C64, SX-64) is now 40-plus years old. Aging electrolytic capacitors, brittle plastics, and the infamous “death‐brick” PSU all put these machines at risk.
Commodore 64 (250425) Motherboard
This page collects best-practice hardware care, preventive service, fault-pre-emption, and periodic checks for every board revision from 1982 ASSY 250407 to the late 250469-05 short board. Follow the sections below to keep a C-64 healthy for the next four decades.
🔍 Identify Your Board Revision
C-64 Motherboard Generations
ASSY Year(s) Key Differences
326298 (“Rev A”) 1982 5-pin A/V DIN, 6567R56A / 6569R1 VIC-II, ceramic SID (6581R1), fully socketed
250407 / 250425 1983-84 8-pin A/V DIN, original long board, PLA 906114-01, discrete DRAM (8×4164)
250466 1984-85 Long board, HMOS-II 6510 CPU & 8701 clock chip, “short” color RAM, improved RF modulator
250469 rev 3/4/5 (“64C short”) 1986-92 Short board, 64-pin CSG 8500 CPU + PLA inside 64-pin “Super PLA” (Chips #252535-xx), HMOS-II 8565 VIC-II, 8580 SID, 2×128-kbit DRAMs
SX-64 portable 1984-86 5″ RGB CRT, 1541 mechanism inside; logic equivalent to 250425
Find the ASSY number silkscreened near the cartridge port or RF modulator.
🧼 Regular Cleaning
Case & Keyboard
  • Wipe ABS plastic with a damp micro-fiber cloth & mild dish-soap.
  • Keys pop off vertically; clean plungers with 99 % IPA. De-yellow with retro-brite only if you can monitor surface temp.
  • Lube space-bar stabiliser wire with plastic-safe grease.
PCB Dust & Oxidation
  • Disconnect PSU; wait 5 min for the +5 V rail to drain.
  • Blow dust with compressed air, brush gently with anti-static brush.
  • Re-seat every socketed IC to wipe oxidised contacts.
🔋 Power Supply: The “Death Brick”
Commodore 64 Power Supply
Original Commodore linear bricks often drift above 5.5 V DC, frying PLA, DRAM and SID.
Pin Function Healthy Range
1 (red) +5 V DC 4.95 – 5.20 V
2 (white) GND 0 V
6 (yellow) 9 VAC @ 1 A 9.0 – 11.0 V rms
Measure with a multimeter before every session. Safe replacements: modern switch-mode “C64RMK2”, Ray Carlsen’s CR adapter, or over-voltage-protected DIY bricks.
💣 Capacitor Health
C-64 boards generally fare better than Amigas, but filter cans in the RF modulator and 5 V/12 V regulators dry out. Early long boards: replace the 1000 µF / 16 V +5 V filter, 470 µF / 25 V +12 V, and the two 220 µF caps in the cassette/9 VAC rectifier path. Short board 250469-05 uses SMD tantalums—rarely fail, but the modulator still contains 22 µF / 16 V electrolytics. See Commodore 64 Capacitor Replacement Guide for more detailed replacement information.
⚠️ Known Failure-Prone ICs
C-64 Common Chip Failures
IC Part # Typical Symptom Quick Test / Hint
PLA 906114-01
251064-01
Black screen, random colors, crash on cartridge Replace with GAL-based PLAnkton or EPROM “PLA20V8”
SID 6581 / 8580 No sound, stuck keys, overheating Touch pin 28 audio-out—hear hum? Swap with known good SID
VIC-II 6567/6569 / 8565 Black screen, jail-bars, bad color, sparkle pixels Check 12 V @ pin 13 (long board)
CIA #1 / #2 6526 Dead keyboard / joystick / IEC, time -outs Swap the two CIAs—fault moves? Easy socket test
DRAM 4164 ×8 or 41464 ×2 Random chars, “OUT OF MEMORY”, intermittent crash Dead-test cart pinpoints bad bit
📏 Voltage & Clock Test Points
Node Board Pad / IC Pin Expected Reading
+5 V DC 6510 pin 40 4.95 – 5.20 V
+12 V DC (long boards) 7812 VR1 out or VIC pin 13 11.8 – 12.3 V
9 VAC User-port pin 10 vs 12 9–11 V rms (scope shows 50/60 Hz sine)
CPU φ2 clock 6510 pin 2 985 kHz (PAL) / 1.022 MHz (NTSC)
Reset 6510 pin 3 Low ≤ 100 ms then High (+5 V)
🧰 Essential Tools
  • ESD wrist-strap & soft bristle brush
  • Digital multimeter (check PSU every session)
  • Solder station + flux & desolder braid (for PLA/SID sockets)
  • Diagnostic cartridges: C-64 Dead Test 781220 & Diagnostic Rev. 586220
  • Freeze spray or hot-air pencil for thermal fault hunts
📝 Preventive Maintenance Checklist
  1. Test PSU – verify +5 V & 9 VAC before connecting computer.
  2. Inspect regulators 7805 / 7812 for cracked solder joints; re-flow if dull.
  3. Re-seat chips annually; apply DeoxIT to sockets.
  4. Add heat-sinks to VIC-II, SID, PLA (especially early ceramic packages).
  5. Clean cartridge & expansion edge-connectors with isopropyl + pink eraser.
  6. Replace RF modulator electrolytics if video shows shimmering border.
  7. Ventilation – leave 2 cm clearance above vents; consider modern transparent top-shell or fan for hot climates.
🛠️ Quick-Fix Flowcharts
🖥️ No Video / Black Screen
  • Check PSU rails → OK?
  • Feel PLA & VIC: burning hot = replace.
  • Swap PLA → CPU / VIC → both CIAs → ROMs.
  • Still black? probe φ2 clock & Reset; if missing, suspect 8701 clock generator or bad crystal.
🎨 Garbled Characters / Checkerboard
  • Run Dead Test cart: code flashes DRAM bank; count flashes to identify bad 4164.
  • If only colors wrong → replace 2114 color RAM.
  • If only certain glyphs wrong → character ROM (901225-01) socket issue.
🔊 No Sound
  • Confirm volume & cable → check SID pin 27 audio-out with scope; flat-line = dead SID.
  • Audio present before modulator but silent on TV = RF modulator electrolytic or bad audio-mix resistor.
⌨️ Keyboard / Joystick Dead
  • Swap CIAs; if fixed, replace bad 6526.
  • If row/column missing → inspect keyboard ribbon; repair broken trace with conductive ink.
