Sega Master System Capacitor Replacement Guide
Replacing the original electrolytic capacitors in your Sega Master System is one of the most effective ways to restore video clarity, audio fidelity, and long-term reliability. Ageing capacitors are a common cause of video noise, audio hum, power instability, and “no boot” faults. Proactive recapping ensures your Master System continues to perform as intended for years to come.
🔍 Capacitor Inspection & Failure Signs
Before starting, visually inspect the board for these common signs of capacitor failure:
- Bulging or domed tops – Indicates internal gas build-up and imminent failure.
- Leaking electrolyte – Brown, white, or green residue at the base or leads.
- Corroded or stained PCB – Discolouration or green corrosion around capacitor pads.
- Video or audio noise – Wavy or unstable picture, buzzing or humming audio.
- Random resets or power loss – Especially after warm-up.
If any capacitor shows visible trouble, it is best practice to replace all electrolytics on the board.
📋 Sega Master System Capacitor Lists
The Master System exists in several board revisions, but the capacitor values are largely consistent across PAL and NTSC models. Always confirm values against your board’s silkscreen before ordering replacements.
🖥️ Mainboard Electrolytic Capacitors
| Ref. Designator | Capacitance | Voltage | Function / Location |
| C1 | 220 µF | 16 V | Audio output coupling |
| C2 | 10 µF | 16 V | Video amp decoupling |
| C3 | 47 µF | 16 V | 5 V rail smoothing (main) |
| C4 | 10 µF | 16 V | Reset circuit |
| C5 | 1 µF | 50 V | Video amp coupling |
| C6 | 220 µF | 10 V | Power input smoothing |
| C7 | 10 µF | 16 V | VDP decoupling |
| C8 | 1 µF | 50 V | Audio path |
| C9 | 100 µF | 16 V | Audio amp supply |
| C10 | 10 µF | 16 V | Misc. decoupling |
| C11 | 47 µF | 16 V | Audio amp bypass |
| C12 | 1 µF | 50 V | Video path |
| C13 | 10 µF | 16 V | Misc. decoupling |
| C14 | 10 µF | 16 V | Misc. decoupling |
| C15 | 10 µF | 16 V | Misc. decoupling |
Note: Some board revisions may combine or omit certain capacitors, or use slightly different values (e.g., 220 µF 10 V instead of 16 V). Always match or exceed the original voltage rating.
💾 Power Board (if present)
Some Master System models (notably the Model 1) include a separate power supply board:
| Ref | Capacitance | Voltage | Function |
| C101 | 470 µF | 16 V | 5 V regulator input |
| C102 | 1000 µF | 16 V | 5 V output smoothing |
🛠️ Recapping Procedure
- Disassemble – Remove all screws from the case bottom; gently lift the top shell. Unplug controller ports and RF/AV cables.
- Remove mainboard – Take out the screws securing the PCB; carefully unplug the power board (if present).
- Document capacitor locations – Take clear photos or notes before desoldering.
- Desolder old capacitors – Use a soldering iron (350–375 °C), solder-wick or pump. Avoid overheating pads.
- Clean pads – Remove old flux and any leaked electrolyte with isopropyl alcohol and a nylon brush.
- Install new capacitors – Observe polarity (long lead = +), match lead spacing. Use 105 °C, low-ESR types.
- Inspect work – Check for solder bridges and correct orientation.
- Reassemble and test – Power up and check for correct operation before fully closing the case.
🧰 Recommended Tools & Parts
- Temperature-controlled soldering iron (60–70 W, 2 mm chisel tip)
- Desoldering pump and solder-wick
- High-quality 63/37 or lead-free solder
- 105 °C, low-ESR radial capacitors (Nichicon, Panasonic, Rubycon)
- Isopropyl alcohol (IPA) and antistatic brush
- Multimeter (for continuity and voltage checks)
- Kapton tape (to insulate tall capacitors if needed)
⚙️ Post-Recap Voltage & Output Checks
After recapping, verify the following voltages and outputs:
| Test Point | Expected Value | Notes |
| Main 5 V rail (ICs, VDP) | 4.90 – 5.10 V | Measure at main filter cap or IC pin |
| Audio output (pin 1 AV) | No DC offset | Should be < 50 mV DC |
| Composite video output | Stable, noise-free | No rolling bars or flicker |
| Power input (after regulator) | 5 V DC | If using external PSU, check before and after recap |
If you see video “jailbars”, audio hum, or random resets after recapping, recheck polarity and solder joints.
💡 Additional Tips
- Always use capacitors rated for 105 °C and low ESR for best longevity.
- Double-check polarity – Electrolytic capacitors are polarised; reversing them can damage the board.
- Clean up thoroughly – Remove all old flux and leaked electrolyte to prevent future corrosion.
- Check the power supply – A failing external PSU can damage new capacitors and ICs.
- Avoid oversize capacitors – Ensure replacements fit under the RF shield and within the case.
- If AV modded – Some video/audio path capacitors may be omitted or replaced with different values; check your mod’s documentation.
