Apple IIc Plus
Revision as of 09:46, 10 May 2025 by Josh (talk | contribs) (Automated update by bot)
The Apple IIc Plus is the final model in the Apple IIc line, introduced by Apple Computer, Inc. in September 1988. It featured a faster 4 MHz 65C02 CPU, an internal 3.5" floppy drive, and several architectural enhancements over its predecessor, the Apple IIc.
Apple IIc Plus
File:Apple IIc logo.svg
File:Apple Iic Plus.jpg
Apple IIc Plus
TypeHome computer
ReleasedSeptember 1988
DiscontinuedNovember 1990
Intro priceUS$675 (1988)
CPUMOS Technology 65C02 @ 4 MHz
Memory128 KB RAM (expandable to 1 MB)
StorageInternal 3.5" (800 KB) floppy disk drive, external 5.25" supported
Display40×24 or 80×24 text, 280×192 (colour), 560×192 (monochrome) graphics
Sound1-bit speaker (toggle), same as Apple II series
Dimensions30.5 cm × 29.2 cm × 7.6 cm
Weight3.6 kg
OS / FirmwareApple DOS 3.3, ProDOS, Apple Pascal
PredecessorApple IIc
SuccessorNone
CodenameRaisin
Model no.A2S4500
🧠 Architecture and Processor
The IIc Plus is powered by a 65C02 microprocessor running at 4 MHz, a significant speed increase over the original IIc’s 1 MHz. The system uses a custom ASIC for memory and peripheral management, and retains the IIc’s all-in-one compact design with built-in keyboard and power supply.
Key architectural features:
  • CPU: MOS Technology 65C02 @ 4 MHz (software switchable to 1 MHz for compatibility)
  • ASIC: Custom Apple chip integrates memory, I/O, and timing functions
  • ROM: 32 KB (with built-in firmware for ProDOS, AppleSoft BASIC, and utility routines)
  • System bus: 8-bit data, 16-bit address (64 KB addressable per bank)
💾 Memory and Storage
The IIc Plus shipped with 128 KB RAM as standard, expandable up to 1 MB via third-party memory cards. The system features a built-in 3.5" double-sided 800 KB floppy disk drive, replacing the earlier IIc’s 5.25" drive. An external 5.25" drive can still be attached for backward compatibility.
  • RAM: 128 KB (expandable to 1 MB)
  • ROM: 32 KB
  • Internal storage: 3.5" Sony floppy (800 KB, GCR encoding)
  • External storage: Optional 5.25" floppy (140 KB), compatible with UniDisk 3.5 and external drives
🖥️ Display and Graphics
The IIc Plus supports the same video modes as earlier Apple II models, with both colour and monochrome output:
  • Text: 40×24 or 80×24 characters (with 80-column card)
  • Graphics:
    • Low-res: 40×48 (16 colours)
    • High-res: 280×192 (6 colours)
    • Double hi-res: 560×192 (monochrome)
  • Video output: Composite video (NTSC), RGB via third-party adapters
🔊 Sound Capabilities
Sound is generated via a simple 1-bit speaker, toggled directly by software, as in all Apple II models. No dedicated sound chip is present, but third-party sound cards are supported.
  • Speaker: Internal, 1-bit digital (toggle)
  • Expansion: Supports Apple II-compatible sound peripherals
🎮 Input/Output and Expansion
The IIc Plus maintains the IIc’s compact, closed-case design, but provides a range of built-in ports for peripherals and expansion:
  • Serial ports: Two DIN-5 (modem and printer)
  • Video: Composite video output (RCA), monochrome output (DIN-8)
  • Disk port: For external 5.25" or 3.5" drives
  • Joystick/mouse port: DE-9 connector
  • Audio: Internal speaker only
  • Keyboard: Integrated
  • Expansion: Internal memory expansion slot (up to 1 MB), no standard Apple II slots
🔍 PCB Schematics & Service Manual
The Apple IIc Plus consists of a single main logic board integrating CPU, RAM, ROM, floppy controller, and I/O. The power supply is internal, unlike earlier IIc models.
Logic Board Power Supply
File:Apple Iic Plus Logicboard.jpg
Apple IIc Plus Logic Board
File:Apple Iic Plus Schematic.png
Apple IIc Plus Schematic
File:Apple Iic Plus PSU.jpg
Apple IIc Plus Power Supply
File:Apple Iic Plus PSU Schematic.png
Power Supply Schematic
  • Apple IIc Plus Technical Reference Manual and schematics are available via Apple Service Source and archive.org.
