Commodore VIC-20 Capacitor Replacement Guide
Revision as of 08:32, 12 May 2025 by Josh (talk | contribs)
Replacing electrolytic capacitors (“recapping”) in a Commodore VIC-20 is one of the highest-impact reliability upgrades you can perform. A fresh capacitor set restores clean DC rails, reduces video noise, cures random resets, and protects rare MOS chips from over-ripple voltage spikes.
  • Bulging tops – Any domed aluminium case is a near-certain failure.
  • Electrolyte residue – Brown crust or oily film at the capacitor base.
  • ESR drift – Even if a cap looks fine, elevated ESR (> 2 Ω on small signal caps, > 0.2 Ω on main filters) is enough to destabilise the 5 V rail.
  • Heat-darkened PCB – Large cans (C11/C13) often cook the FR-4 underneath; that heat ages surrounding parts as well.
If any of the above are present – or if the machine is 40 years old and un-serviced – replace the full set.
VIC-20 Logic-Board Capacitor Lists (by Assy #)
The VIC-20 has a single logic board the tables below contain all the replaceable capacitors.
Early 2-Prong Board (Assy 324003 & “214003”)
Early VIC-20 Capacitors
Board Ref Capacitance Voltage Purpose (rail / circuit)
C10 100 µF 16 V 9 VAC ► +5 V pre-reg filter
C11 4 700 µF 10 V Main +5 V bulk filter
C12 220 µF 25 V +12 V line for VIC analogue core
C13 1 000 µF 16 V Secondary +5 V smoothing (regulator out)
C18 10 µF 16 V Power-on reset RC timer
C90 3.3 µF 50 V Audio-path coupling (VIC DAC)
C91 470 µF 10 V Datasette motor supply filter
Values mirror Commodore service-manual BOM; some very early 1981 PCBs mark C10/C12 as 35 V parts – 25 V or 35 V replacements are both acceptable.
Cost-Reduced “VIC-20 CR” Board (Assy 250403)
Cost-Reduced VIC-20 Capacitors
Typical Ref Capacitance Voltage Notes
C1 22 µF 25 V Reset / audio decouple (moved by layout change)
C2 10 µF 50 V Cassette sense filter
C4 1 000 µF 16 V Bulk +5 V – external PSU now supplies DC directly
C6 470 µF 10 V 9 VAC► +12 V doubler filter (VIC & cassette motor)
C7 100 µF 16 V VIC chroma/luma decouple (near RF modulator)
C8 220 µF 25 V +12 V rail post-rectifier filter
> Board markings vary. Commodore deleted the on-board 7805 on Assy 250403, so the 4 700 µF can is absent; the largest can you will see is 1 000 µF. Always cross-check against your board silkscreen before ordering.
Recapping Procedure
  1. Disassemble – Remove six case screws, slide keyboard forward, lift the RF shield.
  2. Label cables – Photos help when reconnecting the power-LED & keyboard flex.
  3. Desolder caps cleanly using a temperature-controlled iron & braid / pump; apply gentle upward pressure only after all solder is molten to avoid lifting pads (VIC-20 traces are thin).
  4. Install new capacitors – observe polarity: the striped/- side to ground. Lead-spacing on main filters is 5 mm; modern 8 mm diameter caps fit without bending.
  5. Inspect & wash – Flux residue is mildly conductive; scrub with 99 % IPA and a soft brush.
  6. Re-form (optional) – Bring the board up on a bench supply through a 1 Ω resistor for the first 30 s to reform large cans gently.
Post-Recap Voltage Checks
Expected Rails (No-Cartridge, BASIC Prompt)
Test Point Early 324003 CR 250403 Notes
+5 V (6502 pin 40) 4.95 – 5.10 V 4.95 – 5.10 V Regulator (early) vs external PSU
+12 V (VIC pin 28) 11.6 – 12.6 V 11.6 – 12.6 V Derived from 9 VAC doubler
9 VAC (cassette port pin 4) 8.5 – 10.0 V AC same Drives tape motor & 12 V doubler
An oscilloscope should show < 50 mV p-p ripple on +5 V after recap.
  • 60 W temperature-controlled iron (fine conical tip)
  • Desolder‐pump and braid – VIC pads lift easily if overheated.
  • ESR-meter (handy to confirm big cans).
  • Leaded 63/37 Sn-Pb solder (melts ~183 °C – safer for old FR-4).
  • Radial 105 °C capacitors from Nichicon, Panasonic FR/FC, Rubycon ZLJ or equivalent.
  • Small flush-cutters, IPA, ESD wrist-strap.
💡 Extra Tips
  • Socket clean-up: while the board is open, reseat the VIC, CPU & VIA ICs – oxidation here causes more faults than bad caps.
  • Regulator upgrade (early board): consider replacing the TO-220 7805 with a modern drop-in switching regulator to cut internal heat by ~8 °C.
  • Composite-mod recap: if you’ve removed the RF modulator in favour of direct composite, you can omit its two 100 µF caps – they only filter the RF can’s internal 5 V line.
  • Cap spacing: Commodore often bent electrolytic leads outward – clip the old leads flush and use the holes; don’t enlarge them with a drill, the inner-layer vias run very close.
  • Stagger your install: replace and test in sections (power, then audio/video). If something suddenly fails you’ll know which group to re-check.
