Sinclair ZX Spectrum Capacitor Replacement Guide
Revision as of 10:43, 12 May 2025 by Josh (talk | contribs)
Replacing the electrolytic capacitors (“recapping”) in your Sinclair ZX Spectrum is a crucial maintenance step to ensure long-term reliability, stable video output, and protection against power-related failures. Aging capacitors are a common cause of instability, random resets, video artifacts, and audio noise.
  • Bulging or leaning capacitors – especially the large power filter (C9 on Issue 2/3 boards).
  • Leaking electrolyte – brown or green crust at the base of a capacitor.
  • Corrosion or PCB staining – green residue or darkened areas around caps.
  • Video or audio glitches – rolling picture, loss of sync, or buzzing audio may indicate dried-out decoupling capacitors.
  • Intermittent resets or boot failures – often caused by high-ESR or failed timing capacitors.
If any capacitor shows signs of failure, it is strongly recommended to replace all electrolytics on the board.
ZX Spectrum Capacitor Lists
The original ZX Spectrum was produced in several board revisions (Issue 1–6A). Capacitor values are generally consistent, but always verify against your board’s silkscreen.
ZX Spectrum 16K/48K (Issue 2, 3, 4, 4A, 5, 6A)
ZX Spectrum Mainboard Electrolytic Capacitors
Ref Capacitance Voltage Purpose / Rail
C1 1 µF 63 V Composite video coupling
C2 22 µF 16 V 5 V decoupling (ULA)
C3 1 µF 63 V EAR/MIC input coupling
C5 22 µF 16 V 5 V decoupling (CPU)
C6 1 µF 63 V EAR/MIC output coupling
C7 22 µF 16 V 5 V decoupling (RAM)
C8 22 µF 16 V 5 V decoupling (RAM)
C9 1000 µF 16 V Main 5 V power filter
C10 22 µF 16 V 5 V decoupling (ROM)
C11 22 µF 16 V 5 V decoupling (logic)
C12 22 µF 16 V 5 V decoupling (logic)
C27 1 µF 63 V MIC output coupling
Some early Issue 1 boards have minor differences; always check your board.
ZX Spectrum+ and 128K Models
The ZX Spectrum+ uses the same mainboard as late 48K models, with identical capacitor values. The 128K “Toastrack” and +2 add a few extra capacitors for the sound circuit, DC-DC converter, and RAM.
ZX Spectrum 128K/+2 Additional Electrolytic Capacitors
C46 470 µF 16 V DC-DC converter smoothing
C47 100 µF 16 V +12 V RAM supply
C48 22 µF 16 V +12 V RAM supply
C49 10 µF 16 V +12 V RAM supply
C50 1 µF 63 V Audio coupling
C51 1 µF 63 V Audio coupling
C52 1 µF 63 V Audio coupling
The +2A/+3 models use a different PCB and power supply; consult their specific service manuals for capacitor lists.
Recapping Procedure
  1. Disassemble – Remove case screws, carefully separate keyboard membrane from mainboard.
  2. Label keyboard and speaker leads.
  3. Desolder capacitors – Use solder wick or a pump; avoid lifting PCB pads.
  4. Install new capacitors – Match polarity (long lead = +), and lead spacing (2.5 mm or 5 mm).
  5. Keep capacitor height ≤ 13 mm to clear the case.
  6. Clean flux residue with IPA and inspect for solder bridges.
  7. Reassemble and test – Power up with a known-good supply.
Post-Recap Voltage / Ripple Checks
Expected Rails – BASIC prompt, no peripherals
Test Point Voltage (DC) Max Ripple (p-p)
Main 5 V (IC pin 14/28) 4.90 – 5.10 V < 50 mV
+12 V (128K RAM, if present) 11.5 – 12.5 V < 100 mV
-5 V (128K RAM, if present) -4.5 – -5.5 V < 100 mV
Excessive ripple can cause video instability or RAM errors.
  • 40–60 W temperature-controlled soldering iron (fine tip)
  • Solder wick and/or desoldering pump
  • 105 °C, low-ESR radial electrolytic capacitors (Nichicon, Panasonic, Rubycon)
  • Isopropyl alcohol (IPA) and antistatic brush
  • Kapton tape (to insulate capacitors near the modulator or case)
Extra Tips
  • Check your power supply first! A faulty PSU can damage new capacitors and ICs.
  • Replace all electrolytics at once – partial recaps are not recommended.
  • Observe polarity! Electrolytic capacitors are polarized; incorrect fitting can cause failure.
  • Keep leads short and capacitors close to the PCB for best fit.
  • Clean up any electrolyte residue from old leaking capacitors to prevent corrosion.
  • If you have video mods (composite, S-Video), ensure you use quality capacitors in the video path (C1, C3, C6, C27).
