The Macintosh Plus, SE and SE/30 feature a built-in diagnostic console accessible via a serial connection, which can be used for detailed hardware troubleshooting. Originally designed for use with specialized Apple diagnostic tools, this diagnostic mode can also be accessed via a standard serial connection using software such as PuTTY or similar serial terminal programs. Adrian Black's spreadsheet on this topic provides the most useful breakdown of how to use the diagnostic console Macintosh Diagnostics / Test Manager
Connecting to the Diagnostic Console
Connect your Macintosh to another computer using a serial cable (via the modem port):
  • Set your serial terminal (such as PuTTY) to the following:
    • Baud Rate: 9600
    • Data bits: 8
    • Stop bits: 2
    • Parity: None
  • Once connected, restart your Macintosh while holding the interrupt switch or issuing an interrupt command to enter diagnostic mode.
Commands & Tests
Below are detailed descriptions and commands for running specific diagnostic tests:
Preprogrammed Diagnostic Test Commands
Command Test Description
*T Runs preprogrammed diagnostic tests. Use with specific codes to run targeted tests.
*T0000 No operation (null test)
*T0001 ROM Checksum – Verifies ROM integrity. Errors indicate corrupted or damaged ROM.
*T0002 Small RAM Chunk Test – Checks initial RAM area for immediate failures.
*T0003 Full RAM Test (Bank B) – Tests full Bank B RAM after small chunk passes.
*T0004 Full RAM Test (Bank A) – Checks the second RAM bank thoroughly.
*T0005 Address Line Test – Verifies RAM addressing and unique addressing capability.
*T0006 VIA1 Access Test – Checks the proper operation of VIA1 chip.
*T0007 VIA2 Access Test (Mac II only) – Checks VIA2 chip operation.
*T0008 Front Desk Bus Test – Verifies access to Front Desk Bus components.
*T0008 MMU Access Test – Tests access to the Memory Management Unit.
*T0009 NuBus Access Test – Ensures NuBus communication is functional.
*T000A SCSI Chip Test – Confirms proper operation of SCSI controller.
*T000B IWM Chip Test – Verifies floppy drive controller functionality.
*T000C SCC Chip Test – Tests Serial Communications Controller for proper operation.
*T000D Data Bus Test – Validates data bus functionality, identifying bit faults.
Custom Non-Critical Tests
Non-critical tests use a different format:
Format: *TXXY
  • XX = Hexadecimal test number
  • Y = Number of repetitions
Example: *T841 runs test 0x84 once.
Custom Non-Critical Diagnostic Tests
Hex Code Test Description
80 Video RAM Test – Tests VRAM operation (Macintosh II).
81 Video Interface Test – Checks functionality of video hardware interface.
82 VIA Test – Comprehensive VIA chips test.
83 SCSI General Test – Tests general SCSI functionality.
84-86 SCC (Serial Communications Controller) Tests – Checks serial communications.
87 SCSI General Test – General SCSI device communication test.
88 Sound Test – Verifies audio hardware function.
Interpreting Response Codes
The console returns hexadecimal response codes:
Typical Response Codes
Response Code Meaning
020004030000 Test-specific failure indication (consult specific test for details).
020004030000 Data Bus Error accessing RAM.
0F000D NMI button pressed during boot (normal indication).
RAM Chip Identification (Subcode Explanation)
For memory tests, subcodes identify specific faulty chips:
RAM Chip Location & Subcode Identification
Data Bit Chip Location Subcode Bits (Hexadecimal)
0 F5 0001
1 F6 0002
2 F7 0004
3 F8 0008
4 F9 0010
5 F10 0020
6 F11 0040
7 F12 0080
8 G5 0100
9 G6 0200
10 G7 0400
11 G8 0800
12 G9 1000
13 G10 2000
14 G11 4000
15 G12 8000
Here is an example of testing 4MB of memory
*A
*R
*4
*3
*000000000
*0003FFFFC
*T000600010001
Once we get *T back...
*R
It should return all 0s if good.
Important Notes
  • Not all diagnostic tests work on every model; compatibility varies with ROM version.
  • SE/30 and other 256k ROM Macs do not support certain diagnostic commands listed here.
  • There is NO overflow protection when testing memory, if you try to address memory space that is over what is installed, the system will write it to back to the first byte of memory
