Apple IIe Enhanced
Revision as of 18:07, 26 August 2025 by Josh (talk | contribs)
The Apple IIe Enhanced (commonly called Enhanced IIe) is an upgraded version of the standard Apple IIe model, introduced in March 1985. It features significant microprocessor, firmware, and character-ROM improvements aimed at enhancing compatibility and fixing known bugs.
Apple IIe Enhanced
Apple IIe Enhanced – the upgraded version of the Apple IIe
TypeHome computer
ReleasedMarch 1985
DiscontinuedNovember 1993
CPUWestern Design Center 65C02 @ 1.023 MHz (upgrade from NMOS 6502)
Memory64 KB RAM onboard (expandable via auxiliary/expansion slots)
StorageExternal cassette, 5.25″ Disk II floppy, optional 3.5″ drive, hard disk
Display40×24 and 80×24 text, 280×192 hi-res, 560×192 double hi-res (mono/colour with extended memory)
Sound1-bit built-in speaker
Dimensions48 cm × 38 cm × 11 cm
Weight5.4 kg
OS / FirmwareApple DOS 3.3, ProDOS, CP/M (with Z-80 card)
PredecessorApple IIe
SuccessorApple IIGS
CodenameDiana (same as IIe)
Model no.A2S2000 (Enhanced revision)
Enhancement Overview
Rather than a full redesign, the Enhanced IIe was created through a modest but impactful revision. Apple offered an official upgrade kit that included four socketed chips to be replaced: the original 6502 CPU, two system ROMs (Applesoft/Monitor), and the character ROM (Video ROM).
New CPU: Western Design Center 65C02
  • Upgraded from the original MOS Technology 6502 to the CMOS-based **65C02**, running at the same 1.023 MHz.
  • Benefits: lower power consumption, additional instructions and addressing modes, and improved reliability.
Firmware and Character ROM Updates
  • Updated Applesoft BASIC and Monitor firmware improved 80-column routines, fixed bugs, and enabled lowercase input.
  • Video ROM introduced MouseText — a set of box-drawing characters first seen in the Apple IIc.
These enhancements improved speed and reliability in text and programming routines, particularly in 80-column mode.
Appearance Differences
  • Enhanced IIe units received cosmetic updates: darker keycaps, smaller and black-printed key labels positioned at the top of the keys.
  • A small “Enhanced” sticker was placed near the power light to denote the upgraded version.
Memory and Expandability
  • Base memory remained 64 KB RAM, with expansion via auxiliary slot or internal expansion allowing up to 128 KB (commonly with an 80-column/64 KB card) and beyond with third-party RAM cards up to 1 MB.
Compatibility and Software Support
  • Enhanced firmware greatly improved compatibility with newer software and fixed known glitches—especially in 80-column and 80-column language support.
  • Lowercase input and MouseText broadened the usability for serious text-based applications.
  • Note: Some older programs that relied on the original character encoding saw display quirks due to the new MouseText mapping.
Upgrade Kit
Apple offered a user-installable Enhanced IIe upgrade kit, which included the four required chips plus a cosmetic “Enhanced” label template. The upgrade was relatively straightforward for users comfortable handling DIP sockets.
In the aftermarket and collector communities, the upgrade remains popular. A note of caution: authentic 65C02 CPUs are sometimes counterfeited or mis-labeled in online listings.
Historical and Commercial Significance
  • First shipped as a new SKU in March 1985 as part of Apple's ongoing IIe model updates, and was widely sold through to the line’s discontinuation in 1993.
  • The Enhanced IIe remains beloved among vintage Apple II collectors as delivering a “best of both worlds” blend of legacy Apple II compatibility and incremental modernization.
Technical Summary
Component Original IIe Enhanced IIe upgrade
CPU MOS 6502 @ 1.023 MHz WDC 65C02 @ 1.023 MHz (CMOS, more instructions)
System ROMs (Applesoft/Monitor) Original IIe firmware Updated firmware with bug fixes, lowercase, better 80-column routines
Character ROM (Video ROM) Standard character set Includes MouseText characters
Memory 64 KB onboard Same, expandable up to 1 MB
Appearance Original keycaps, no sticker Darker keycaps, “Enhanced” power-light sticker
