Module:Userbox
Revision as of 00:48, 5 September 2025 by Josh (talk | contribs) (Created page with "-- This module implements {{userbox}}. local categoryHandler = require('Module:Category handler').main local p = {} -------------------------------------------------------------------------------- -- Helper functions -------------------------------------------------------------------------------- local function checkNum(val, default) -- Checks whether a value is a number greater than or equal to zero. If so, -- returns it as a number. If not, returns a default valu...")
Documentation for this module may be created at Module:Userbox/doc
local p = {}
-- Helper functions
	-- returns it as a number. If not, returns a default value.
	val = tonumber(val)
	if val and val >= 0 then
		return val
	else
		return default
	end
end
local function addSuffix(num, suffix)
	-- Turns a number into a string and adds a suffix.
	if num then
		return tostring(num) .. suffix
	else
		return nil
	end
end
local function checkNumAndAddSuffix(num, default, suffix)
	-- Checks a value with checkNum and adds a suffix.
	num = checkNum(num, default)
	return addSuffix(num, suffix)
end
local function makeCat(cat, sort)
	-- Makes a category link.
	if sort then
		return mw.ustring.format('[[Category:%s|%s]]', cat, sort)
	else
		return mw.ustring.format('[[Category:%s]]', cat)
	end
end
-- Argument processing
local function makeInvokeFunc(funcName)
	return function (frame)
		local origArgs = require('Module:Arguments').getArgs(frame)
		local args = {}
		for k, v in pairs(origArgs) do
			args[k] = v
		end
		return p.main(funcName, args)
	end
end
p.userbox = makeInvokeFunc('_userbox')
p['userbox-2'] = makeInvokeFunc('_userbox-2')
p['userbox-r'] = makeInvokeFunc('_userbox-r')
-- Main functions
function p.main(funcName, args)
	local userboxData = p[funcName](args)
	local userbox = p.render(userboxData)
	local cats = p.categories(args)
	return userbox .. (cats or '')
end
function p._userbox(args)
	-- Does argument processing for {{userbox}}.
	local data = {}
	-- Get div tag values.
	data.float = args.float or 'left'
	local borderWidthNum = checkNum(args['border-width'] or args['border-s'], 1) -- Used to calculate width.
	data.borderWidth = addSuffix(borderWidthNum, 'px')
	data.borderColor = args['border-color'] or args['border-c'] or args[1] or args['id-c'] or '#999'
	data.width = addSuffix(240 - 2 * borderWidthNum, 'px') -- Also used in the table tag.
	data.bodyClass = args.bodyclass
	-- Get table tag values.
	data.backgroundColor = args['info-background'] or args[2] or args['info-c'] or '#eee'
	-- Get info values.
	data.info = args.info or args[4] or "<code>{{{info}}}</code>"
	data.infoTextAlign = args['info-a'] or 'left'
	data.infoFontSize = checkNumAndAddSuffix(args['info-size'] or args['info-s'], 8, 'pt')
	data.infoHeight = checkNumAndAddSuffix(args['logo-height'] or args['id-h'], 45, 'px')
	data.infoPadding = args['info-padding'] or args['info-p'] or '0 4px 0 4px'
	data.infoLineHeight = args['info-line-height'] or args['info-lh'] or '1.25em'
	data.infoColor = args['info-color'] or args['info-fc'] or 'black'
	data.infoOtherParams = args['info-other-param'] or args['info-op']
	data.infoClass = args['info-class']
	-- Get id values.
	local id = args.logo or args[3] or args.id
	data.id = id
	data.showId = id and true or false
	data.idWidth = checkNumAndAddSuffix(args['logo-width'] or args['id-w'], 45, 'px')
	data.idHeight = checkNumAndAddSuffix(args['logo-height'] or args['id-h'], 45, 'px')
	data.idBackgroundColor = args['logo-background'] or args[1] or args['id-c'] or '#ddd'
	data.idTextAlign = args['id-a'] or 'center'
	data.idFontSize = checkNum(args['logo-size'] or args[5] or args['id-s'], 14)
	data.idColor = args['logo-color'] or args['id-fc'] or data.infoColor
	data.idPadding = args['logo-padding'] or args['id-p'] or '0 1px 0 0'
	data.idLineHeight = args['logo-line-height'] or args['id-lh'] or '1.25em'
	data.idOtherParams = args['logo-other-param'] or args['id-op']
	data.idClass = args['id-class']
	return data
end
p['_userbox-2'] = function (args)
	-- Does argument processing for {{userbox-2}}.
	local data = {}
	local borderWidthNum = checkNum(args['border-s'] or args[9], 1) -- Used to calculate width.
	data.borderColor = args['border-c'] or args[6] or args['id1-c'] or args[1] or '#999999'
	data.backgroundColor = args['info-c'] or args[2] or '#eeeeee'
	-- Get info values.
	data.infoFontSize = checkNumAndAddSuffix(args['info-s'], 8, 'pt')
	data.infoColor = args['info-fc'] or args[8] or 'black'
	data.infoPadding = args['info-p'] or '0 4px 0 4px'
	data.infoLineHeight = args['info-lh'] or '1.25em'
	data.infoOtherParams = args['info-op']
	-- Get id values.
	data.showId = true
	data.id = args.logo or args[3] or args.id1 or 'id1'
	data.idWidth = checkNumAndAddSuffix(args['id1-w'], 45, 'px')
	data.idHeight = checkNumAndAddSuffix(args['id-h'], 45, 'px')
	data.idBackgroundColor = args['id1-c'] or args[1] or '#dddddd'
	data.idTextAlign = 'center'
	data.idFontSize = checkNum(args['id1-s'], 14)
	data.idLineHeight = args['id1-lh'] or '1.25em'
	data.idColor = args['id1-fc'] or data.infoColor
	data.idPadding = args['id1-p'] or '0 1px 0 0'
	data.idOtherParams = args['id1-op']
	-- Get id2 values.
	data.showId2 = true
	data.id2 = args.logo or args[5] or args.id2 or 'id2'
	data.id2Width = checkNumAndAddSuffix(args['id2-w'], 45, 'px')
	data.id2Height = data.idHeight
	data.id2BackgroundColor = args['id2-c'] or args[7] or args[1] or '#dddddd'
	data.id2TextAlign = 'center'
	data.id2FontSize = checkNum(args['id2-s'], 14)
	data.id2LineHeight = args['id2-lh'] or '1.25em'
	data.id2Color = args['id2-fc'] or data.infoColor
	data.id2Padding = args['id2-p'] or '0 0 0 1px'
	data.id2OtherParams = args['id2-op']
	return data
end
p['_userbox-r'] = function (args)
	-- Does argument processing for {{userbox-r}}.
	local data = {}
	-- Get id values.
	data.showId = false -- We only show id2 in userbox-r.
	-- Get info values.
	data.infoTextAlign = args['info-align'] or args['info-a'] or 'left'
	-- Get id2 values.
	data.showId2 = true
	data.id2 = args.logo or args[3] or args.id or 'id'
	data.id2Width = checkNumAndAddSuffix(args['logo-width'] or args['id-w'], 45, 'px')
	data.id2Height = checkNumAndAddSuffix(args['logo-height'] or args['id-h'], 45, 'px')
	data.id2BackgroundColor = args['logo-background'] or args[1] or args['id-c'] or '#ddd'
	data.id2TextAlign = args['id-a'] or 'center'
	data.id2FontSize = checkNum(args['logo-size'] or args[5] or args['id-s'], 14)
	data.id2Color = args['logo-color'] or args['id-fc'] or data.infoColor
	data.id2Padding = args['logo-padding'] or args['id-p'] or '0 0 0 1px'
	data.id2LineHeight = args['logo-line-height'] or args['id-lh'] or '1.25em'
	data.id2OtherParams = args['logo-other-param'] or args['id-op']
	return data
end
function p.render(data)
	-- Renders the userbox html using the content of the data table.
	-- Render the div tag html.
	local root = mw.html.create('div')
	root
		:css('float', data.float)
		:css('border', (data.borderWidth or '') .. ' solid ' .. (data.borderColor or ''))
		:css('margin', '1px')
		:css('width', data.width)
		:addClass('wikipediauserbox')
		:addClass(data.bodyClass)
	-- Render the table tag html.
	local tableroot = root:tag('table')
	tableroot
		:attr('role', 'presentation')
		:css('border-collapse', 'collapse')
		:css('margin-bottom', '0')
		:css('margin-top', '0')
		:css('background', data.backgroundColor)
		:css('color', 'inherit')
	-- Render the id html.
	local tablerow = tableroot:tag('tr')
	if data.showId then
		tablerow:tag('td')
			:css('border', '0')
			:css('width', data.idWidth)
			:css('height', data.idHeight)
			:css('background', data.idBackgroundColor)
			:css('text-align', data.idTextAlign)
			:css('font-size', data.idFontSize .. 'pt')
			:css('font-weight', 'bold')
			:css('color', data.idColor)
			:css('padding', data.idPadding)
			:css('line-height', data.idLineHeight)
			:css('vertical-align', 'middle')
			:cssText(data.idOtherParams)
			:addClass(data.idClass)
			:wikitext(data.id)
	end
	-- Render the info html.
	tablerow:tag('td')
		:css('border', '0')
		:css('text-align', data.infoTextAlign)
		:css('font-size', data.infoFontSize)
		:css('padding', data.infoPadding)
		:css('height', data.infoHeight)
		:css('line-height', data.infoLineHeight)
		:css('color', data.infoColor)
		:cssText(data.infoOtherParams)
		:addClass(data.infoClass)
		:wikitext(data.info)
	-- Render the second id html.
	if data.showId2 then
		tablerow:tag('td')
			:css('border', '0')
			:css('width', data.id2Width)
			:css('height', data.id2Height)
			:css('background', data.id2BackgroundColor)
			:css('text-align', data.id2TextAlign)
			:css('font-size', data.id2FontSize .. 'pt')
			:css('color', data.id2Color)
			:css('padding', data.id2Padding)
			:css('line-height', data.id2LineHeight)
			:cssText(data.id2OtherParams)
			:wikitext(data.id2)
	end
	local title = mw.title.getCurrentTitle()
	if (title.namespace == 2) and not title.text:match("/") then
		return tostring(root) -- regular user page
	elseif title.namespace == 14 then
		return tostring(root) -- category
	elseif title.isTalkPage then
		return tostring(root) -- talk page
	end
	local legible = true
	local contrast = require('Module:Color contrast')._ratio
	local function has_text(wikitext)
		wikitext = wikitext:gsub("]]", "|]]")
		wikitext = wikitext:gsub("%[%[%s*[Mm][Ee][Dd][Ii][Aa]%s*:[^|]-(|.-)]]", "")
		wikitext = wikitext:gsub("%[%[%s*[Ii][Mm][Aa][Gg][Ee]%s*:[^|]-(|.-)]]", "")
		wikitext = wikitext:gsub("%[%[%s*[Ff][Ii][Ll][Ee]%s*:[^|]-(|.-)]]", "")
		return mw.text.trim(wikitext) ~= ""
	end
	if contrast { data.infoColor, data.backgroundColor, error = 0 } < 4.5 then
		legible = false
	end
	-- For bold text >= 14pt, requirement is only 3.
	local idContrastThreshold = 4.5
	local id2ContrastThreshold = 4.5
	if (data.idFontSize or 0) >= 14 then
		idContrastThreshold = 3
	end
	if (data.id2FontSize or 0) >= 14 then
		id2ContrastThreshold = 3
	end
	if data.showId and contrast { data.idColor, data.idBackgroundColor, error = 0 } < idContrastThreshold then
		if has_text(data.id or "") then
			legible = false
		end
	end
	if data.showId2 and contrast { data.id2Color, data.id2BackgroundColor, error = 0 } < id2ContrastThreshold then
		if has_text(data.id2 or "") then
			legible = false
		end
	end
	if not legible then
		root:wikitext('[[Category:Userboxes with insufficient color contrast]]')
	end
end
function p.categories(args, page)
	-- Gets categories from [[Module:Category handler]].
	-- The page parameter makes the function act as though the module was being called from that page.
	-- It is included for testing purposes.
	local cats = {}
	cats[#cats + 1] = args.usercategory
	cats[#cats + 1] = args.usercategory2
	cats[#cats + 1] = args.usercategory3
	cats[#cats + 1] = args.usercategory4
	cats[#cats + 1] = args.usercategory5
	-- Get the title object
	local title
	if page then
		title = mw.title.new(page)
	else
	end
	-- Build category handler arguments.
	local chargs = {}
	chargs.page = page
	chargs.nocat = args.nocat
	chargs.main = '[[Category:Pages with templates in the wrong namespace]]'
	if args.notcatsubpages then
		chargs.subpage = 'no'
	end
	-- User namespace.
	local user = ''
	for i, cat in ipairs(cats) do
		user = user .. makeCat(cat)
	end
	chargs.user = user
	-- Template namespace.
	local basepage = title.baseText
	local template = ''
		template = template .. makeCat(cat, ' ' .. basepage)
	end
	chargs.template = template
	return categoryHandler(chargs)
end
return p
