Apple Keyboard (M0116)
The Apple Keyboard, also known as the Apple Standard Keyboard (Model M0116), was the first Macintosh keyboard to officially use the "Apple Keyboard" designation. Introduced on March 2, 1987, alongside the Macintosh II and Macintosh SE, it represented a significant upgrade from the lighter Apple Desktop Bus Keyboard with its more robust construction and professional appearance. The keyboard featured mechanical Alps SKCM switches and dual ADB ports, establishing design principles that would influence Apple keyboards throughout the late 1980s. Production continued until 1990 when it was replaced by the Apple Keyboard II.
| Apple Keyboard | |
| Apple Keyboard M0116 with Alps SKCM Orange switches | |
| Type | Computer keyboard |
| Discontinued | 1990 |
| Price | US$129 (retail) |
| Interface | Apple Desktop Bus |
| Compatible | All ADB-equipped Macs, Apple IIGS, NeXT (limited) |
| Dimensions | 442 mm W × 140 mm D × 44 mm H (rear) |
| Weight | 1.25 kg (2.75 lbs) |
| Predecessor | Apple Desktop Bus Keyboard (A9M0330) |
| Successor | Apple Keyboard II (M0487) |
| Model | M0116 (ANSI), M0118 (ISO) |
Design Philosophy
The Apple Keyboard embodied the transition from Apple's consumer-focused compact computers to professional workstations. The Macintosh II and SE were sold without keyboards, allowing customers to choose between this standard model or the larger Apple Extended Keyboard. The M0116's substantial construction, with its thick internal steel plate and wider frame bezels, visually communicated the power and capability of Apple's new modular computer systems.
The keyboard maintained the 81-key layout introduced with the Apple Desktop Bus Keyboard for the Apple IIGS, including the unconventional placement of certain keys that would later be revised in subsequent models. This layout represented a transitional period in Apple keyboard design, combining elements from both Apple II and Macintosh lineages.
Model Variants
M0116 (ANSI Layout)
The standard M0116 featured the ANSI layout common in North America:
- 81 keys total
- Backward L-shaped Return key
- Single-row arrow key arrangement
- Control key positioned left of 'A'
- Tilde/grave key left of spacebar
M0118 (ISO Layout)
The M0118 variant accommodated international markets:
- Vertical Return key configuration
- Additional key between left Shift and Z
- Caps Lock in standard position (unlike M0116)
- Support for language-specific keycap legends
M0117 Designation
Some keyboards bore serial numbers ending in "M0117", suggesting either:
- A planned but unreleased variant
- Internal designation for specific manufacturing batches
- Regional variants with modified layouts
Regional Variants
Documented international versions include:
- M0118 Finnish/Swedish: Nordic characters on keycaps
- M0117AB Arabic: Dual Arabic/Latin legends
- M0118 Japanese: JIS layout compatibility
Switch Technology
Alps SKCM Switches
The keyboard utilized Alps Electric mechanical switches, with two primary variants:
Alps SKCM Orange:
- Tactile, non-clicky operation
- Actuation force: 70g ± 10g
- Total travel: 3.5mm
- Actuation point: 2.0mm
- Darker orange slider color
- Production period: 1987-1988
Alps SKCM Salmon:
- Pink-salmon slider color
- Production period: 1988-1990
Alps SKCL Lock (Caps Lock):
- Mechanical latching mechanism
- Physical lock-down when activated
- Cream or white-colored housing
- Distinct from standard switches
Switch Characteristics
Both Orange and Salmon variants provided:
- Smooth tactile feedback
- Minimal switch wobble
- Consistent actuation across all keys
- Durability rated for 10 million actuations
- Superior feel compared to contemporary rubber dome designs
Enthusiasts debate the differences between Orange and Salmon switches, with many attributing perceived variations to age and condition rather than inherent design differences. Orange Alps switches have achieved legendary status among mechanical keyboard enthusiasts, often rated as one of the finest tactile switches ever produced.
Physical Specifications
Dimensions and Weight
- Width: 442mm (17.4 inches)
- Depth: 140mm (5.5 inches)
- Height (front): 30mm (1.2 inches)
- Height (rear): 44mm (1.7 inches)
- Weight: 1.25kg (2.75 lbs)
- Typing angle: 7 degrees (fixed)
Construction
- Case material: ABS plastic, Platinum gray (Pantone 423C)
- Internal plate: 1.5mm steel, powder-coated
- Keycaps: PBT plastic, dye-sublimated legends
- Spacebar: ABS plastic (exception to PBT)
- Cable: Coiled ADB cable, 1.2m extended
Layout Peculiarities
The M0116 featured several non-standard key placements:
- Control key: Left of 'A' (Apple II legacy position)
- Caps Lock: Bottom left corner
- Tilde/Grave: Left of spacebar
- Arrow keys: Single row (← → ↓ ↑ order)
- Escape key: Present (first on Mac keyboard)
Technical Specifications
Electrical Characteristics
- Interface: Apple Desktop Bus (ADB)
- Power consumption: 25mA typical, 50mA maximum
- Operating voltage: 4.75V - 5.25V
- Data rate: 10 kbit/s (ADB maximum)
ADB Implementation
- Device type: Keyboard
- Default address: $2
- Handler ID: $01 (Standard Keyboard Protocol)
- Polling rate: 100 Hz maximum
- Key rollover: 2-key guaranteed
Connector Configuration
Two 4-pin mini-DIN ADB ports:
- Left port: Typically for upstream connection
- Right port: Typically for mouse connection
- Bidirectional: Either port could serve either function
- Daisy-chain capable: Multiple devices supported
Protocol Details
Register 0 (Key events):
- 2 bytes returned per poll
- Each byte: 7-bit keycode + 1-bit up/down flag
- Power key uses both bytes when pressed
Register 2 (LED control):
- Bit 0: Num Lock LED (not present)
- Bit 1: Caps Lock LED (mechanical)
- Bit 2: Scroll Lock LED (not present)
Register 3 (Device info):
- Handler ID: $01 or $02
- Device address: $2 (default)
Keycap Specifications
Material and Manufacturing
- Material: PBT plastic (except spacebar)
- Legend application: Dye sublimation
- Profile Apple Standard (similar to Cherry profile)
- Thickness 1.5mm average
- Texture Smooth matte finish
Typography
- Font Univers 57 Condensed
- Style Italic for special keys
- Position Bottom-left corner of keycap
- Color Dark gray on beige keys
Stabilizers
- Type Wire stabilizers (Alps-specific)
- Keys with stabilizers
* Spacebar (6.25 units) * Return key * Shift keys (both) * Caps Lock
Manufacturing Details
Production Facilities
Manufacturing locations determined by serial number prefixes:
Taiwan:
- Primary production facility
- Majority of units produced
- Higher build quality consistency
Singapore:
- Secondary production facility
- Limited production runs
- Minor assembly variations
Ireland:
- Final assembly for European market
- Quality control and testing
- Regional customization
Serial Number Format
Format: PPYWW######M0116
- PP: Production facility code
- Y: Year code (7=1987, 8=1988, 9=1989, 0=1990)
- WW: Week of manufacture (01-52)
- ######: Sequential unit number
Quality Control
Each keyboard underwent:
- Key switch testing (all keys)
- ADB communication verification
- Physical inspection
- Burn-in period (select units)
Internal Design
PCB Layout
- PCB material: FR-4 fiberglass
- Layers Single-sided with jumper wires
- Controller Custom Apple ADB controller IC
- Supporting ICs 74-series logic gates
Assembly Process
- Steel plate preparation and coating
- Switch installation into plate
- PCB mounting to switch pins
- Wave soldering of all connections
- Cable attachment and strain relief
- Case assembly with self-tapping screws
- Quality control testing
- Packaging with protective materials
Component Suppliers
- Switches Alps Electric Co., Japan
- Keycaps Signature Plastics (suspected)
- PCB Various Taiwan manufacturers
- Controller IC Custom Apple silicon
- Cable Coiled by various suppliers
Software Compatibility
System Software
- Minimum System 3.2 (ADB support)
- Maximum Mac OS 9.2.2
- Optimal System 6.0.x through Mac OS 8.6
Third-Party Support
- A/UX Full compatibility
- BeOS Supported with drivers
- Linux Kernel support for PowerPC Macs
- NetBSD Native ADB support
Special Key Functions
- Power key Direct system power control
- Command key System modifier
- Option key Alternate character access
- Control key Terminal emulation, shortcuts
Maintenance & Repair
Disassembly Procedure
Required tools
- Phillips screwdriver #1
- Plastic spudger
- Isopropyl alcohol 90%+
- Cotton swabs
Steps
- Remove six screws from case bottom
- Carefully separate case halves
- Disconnect cable from PCB (if removable)
- Document wire colors and positions
- Remove PCB mounting screws
- Lift PCB and plate assembly
Switch Maintenance
Cleaning procedure
- Remove keycap with wire puller
- Apply drops of isopropyl alcohol
- Actuate switch repeatedly
- Allow to dry completely
- Test switch operation
Switch replacement
- Desolder defective switch
- Clean PCB pads thoroughly
- Install replacement Alps switch
- Ensure proper alignment
- Solder and test
Common Issues
| Problem | Cause | Solution |
| Key not registering | Dirty switch contacts | Clean with isopropyl alcohol |
| Multiple keys failing | PCB trace damage | Repair traces with wire jumpers |
| ADB not recognized | Cable damage | Test continuity, replace cable |
| Intermittent operation | Cold solder joints | Reflow solder connections |
| Caps Lock stuck | Mechanical latch worn | Replace SKCL switch |
| Keys feel scratchy | Switch contamination | Disassemble and clean switches |
Restoration
Retrobrighting
- Suitable for yellowed cases
- Use hydrogen peroxide cream
- UV exposure or heat acceleration
- Monitor progress carefully
Switch restoration
- Ultrasonic cleaning of switch parts
- Replacement of worn springs
- Lubrication with appropriate grease
Keycap restoration
- Denture tablet cleaning
- Avoid harsh chemicals on legends
- Gentle brushing for stubborn stains
Modern Usage
ADB to USB Conversion
Hardware adapters
- Griffin iMate Original commercial solution
- Wombat Modern bidirectional converter
- TMK converter Open-source DIY option
- Drakware Premium conversion cables
Compatibility considerations
- Power key may not function
- Some key combinations limited
- Latency varies by adapter
- Modern OS driver support varies
Collector Information
Value factors
- Switch type (Orange > Salmon)
- Condition of case and keycaps
- Presence of original cable
- Manufacturing date (earlier preferred)
- Complete documentation
Authentication
- Verify serial number format
- Check switch type matches era
- Confirm keycap profile and legends
- Inspect PCB date codes
Market values (2024)
- Good condition $150-250
- Excellent condition $250-400
- Mint/boxed $400-600
- Orange Alps premium +$50-100
Legacy and Impact
The Apple Keyboard M0116 occupied a unique position in Apple's keyboard evolution. While its non-standard layout proved controversial and was quickly revised in later models, the build quality and switch technology represented a high point in Apple keyboard construction. The robust steel plate construction and mechanical Alps switches provided a typing experience that many enthusiasts still consider superior to modern offerings.
The keyboard's design influenced the industry standard for construction methods, with the plate-mounted switches becoming the preferred configuration for premium mechanical keyboards. The dual ADB ports pioneered the concept of keyboard-integrated USB hubs seen in many modern keyboards.
Despite its relatively short three-year production run, the M0116 achieved legendary status among collectors and mechanical keyboard enthusiasts. The Orange Alps switches in particular are highly sought after for custom keyboard builds, often commanding premium prices when harvested from donor boards.
Production Statistics
While Apple never published official production numbers, analysis of serial numbers suggests:
- Total production: Approximately 500,000 units
- Peak production 1988
- Orange Alps units ~40% of production
- Salmon Alps units ~60% of production
- Survival rate Estimated 10-15% in working condition
- Apple Desktop Bus
- Apple Extended Keyboard
- Apple Desktop Bus Keyboard
- Apple Keyboard II
- Macintosh II
- Macintosh SE
