Template:Protected page text/full
Why is the page protected?
What can I do?
| This template is used in MediaWiki:Protectedpagetext. Changes to it can cause immediate changes to the RetroTechCollection user interface. To avoid major disruption, any changes should be tested in the template's /sandbox or /testcases subpages, or in your own user subpage. The tested changes can be added to this page in a single edit. Please discuss changes on the talk page before implementing them. |
Lua error in Module:TNT at line 159: Missing JsonConfig extension; Cannot load https://commons.wikimedia.org/wiki/Data:I18n/Uses TemplateStyles.tab.
This template displays the text that users see when they do not have permission to edit a page. This template was created to encourage reuse of code in the MediaWiki messages that display said errors.
For convenience, there are seven subtemplates already filled out with the settings for semi-protection, extended-confirmed protection, template protection, full protection, cascade protection, user JSON page protection, and user script protection: {{Protected page text/semi}}, {{Protected page text/extendedconfirmed}}, {{Protected page text/template}}, {{Protected page text/full}}, {{Protected page text/cascade}}, {{Protected page text/user-json}} and {{Protected page text/interface}}. It is recommended that you use these subtemplates, as this will allow you to benefit from future updates to the templates.
Syntax
editPre-defined settings
editSemi-protection {{protected page text/semi}}
Extendedconfirmed protection {{protected page text/extendedconfirmed}}
Template protection {{protected page text/template}}
Full protection {{protected page text/full}}
Pages transcluded in cascade-protected pages {{protected page text/cascade}}
Protection of user JSON pages {{protected page text/user-json}}
Protection of user scripts {{protected page text/interface}}
Manual settings
edit<syntaxhighlight lang="wikitext">
What can I do?
</syntaxhighlight>
Parameters
edit|image=– The shackle image used in the top message box. Defaults toFull-protection-shackle.svg.|protection-message=– The message inside the top message box. This should explain that the page is protected, and who can edit it. This parameter is required.|suggestions=– If this parameter is set with any text, the template shows the "Why is the page protected?" and "What can I do?" headings with a list of suggestions on what actions editors can take upon discovering that they can't edit the page. This parameter can be used with the #ifexist parser function to display the suggestions only on existing pages (i.e. to disable them on create-protected pages).|protection-reason=– The general reasons why pages of a given protection level might be protected. This is the first bullet point under the "Why is the page protected?" heading. This parameter is required.|log-text=– Optional text to use instead of the protection log explanation in the "Why is the page protected?" heading.|login-message=– If this parameter is set with any text, the template displays a message about logging in and becoming autoconfirmed.|main-page-links=– If this parameter is set with any text, and the current page is the Main Page, the template displays advice for new editors and a link to Wikipedia:Main Page/Errors.|template-links=– If this parameter is set with any text, and the current page is in the template namespace, the template will display links to the documentation and the template sandbox if they exist.|who-can-edit=– The users that can edit pages protected at this level. This should start with a capital letter and include a grammatical article, e.g.An [[Wikipedia:Administrator|administrator]]. This parameter is required.|request-type=– The value to send to the|type=parameter of Template:Submit an edit request. Possible values aresemi,templateandfull. This parameter is required.|hide-requestlower=– If this parameter is set with any text, the template will hide the message about requesting lowering of protection at WP:RFPP. This is unlikely to be used except for pages subject to cascade-protection and which will have it indefinitely (requests to lower the protection on that particular page must necessarily be declined).
Example
editThe following example uses the code for full protection.
Code
edit<syntaxhighlight lang="wikitext" style="white-space: pre-wrap;">
What can I do?
</syntaxhighlight>
Result
What can I do?
