RetroTechCollection:Twinkle/Preferences
Invalid title for TemplateStyles' src attribute.
Use the settings in the panel below to customize Twinkle to suit your personal preferences.
Note that your preferences are stored in a subpage of your user page. Only you, Wikipedia interface administrators, and global interface editors can modify your preferences, but the settings you choose are visible as JavaScript code to everyone. You do not need to import your preferences manually, Twinkle will handle it for you.
Twinkle preferences
You must have Twinkle installed (either as a gadget or manually as a user script) to use this page.
If Twinkle is installed and working properly, you might need to wait a few moments for the script to load.
