Template:Uw-aeblock
Revision as of 19:47, 4 September 2025 by RetroTechCollection>Tamzin (fix error on temp pblocks)
To enforce an arbitration decision, you have been blocked temporarily from editing Wikipedia. You are welcome to edit once the block expires; however, please note that the repetition of similar behavior may result in a longer block or other sanctions.
If you believe this block is unjustified, please read the guide to appealing blocks (specifically this section) before appealing. Place the following on your talk page: {{unblock|reason=Please copy my appeal to the [[WP:AE|arbitration enforcement noticeboard]] or [[WP:AN|administrators' noticeboard]]. Your reason here OR place the reason below this template. ~~~~}}. If you intend to appeal on the arbitration enforcement noticeboard, I suggest you use the arbitration enforcement appeals template on your talk page so it can be copied over easily. You may also appeal directly to me (by email), before or instead of appealing on your talk page.
Reminder to administrators: In May 2014, ArbCom adopted the following procedure instructing administrators regarding Arbitration Enforcement blocks: "No administrator may modify a sanction placed by another administrator without: (1) the explicit prior affirmative consent of the enforcing administrator; or (2) prior affirmative agreement for the modification at (a) AE or (b) AN or (c) ARCA (see "Important notes"). Administrators modifying sanctions out of process may at the discretion of the committee be desysopped."
