Acorn Archimedes A3000
Revision as of 18:19, 9 September 2025 by Josh (talk | contribs) (Memory Map)
The Acorn Archimedes A3000 was a single-box home computer released in May 1989 as part of Acorn's Archimedes range. The first all-in-one Archimedes model, it integrated keyboard, motherboard, and floppy drive in a wedge-shaped case reminiscent of the earlier 8-bit machines while incorporating the revolutionary ARM RISC processor architecture.
TypeHome Computer
ReleasedMay 1989
Discontinued1991
Intro price£649 (1989)
CPUARM2 (ARM250 in later models) @ 8 MHz
Memory1 MB RAM (expandable to 4 MB)
Storage3.5" floppy drive (800 KB/1.6 MB), optional hard drive
Display640×512 (16 colours), 640×256 (256 colours), 1152×896 (monochrome)
Sound8-channel stereo, 8-bit logarithmic DAC
Dimensions430 mm × 340 mm × 95 mm
Weight5.5 kg
OS / FirmwareRISC OS 2.00 (later 3.00)
PredecessorAcorn Archimedes A310
SuccessorAcorn A3010
Architecture
The A3000 utilized either the discrete ARM2 processor with support chips or the later ARM250, a single-chip solution integrating the ARM2 core, MEMC memory controller, VIDC video controller, and IOC input/output controller into one package.
System Architecture
Component Early A3000 Late A3000 Function
CPU ARM2 @ 8 MHz ARM250 @ 12 MHz 32-bit RISC processor
MEMC MEMC1a (separate) Integrated in ARM250 Memory controller, DMA
VIDC VIDC1a (separate) Integrated in ARM250 Video and sound controller
IOC IOC (separate) Integrated in ARM250 I/O controller, timers
RAM 1 MB (4× 256K×9) 1 MB minimum Fast page mode DRAM
ROM 2 MB (4× 512 KB) 2 MB RISC OS, applications
Memory Map
A3000 Memory Organization
Address Range Size Function Access Type
$0000000 – $01FFFFF 2 MB Logical RAM space User mode
$0200000 – $02FFFFF 1 MB Physical RAM (1 MB model) Direct
$0300000 – $033FFFF 256 KB Additional RAM (if fitted) Direct
$0340000 – $035FFFF 128 KB VIDC frame buffer DMA
$0360000 – $037FFFF 128 KB Sound DMA buffers DMA
$0380000 – $03FFFFF 512 KB System space Supervisor
$1000000 – $1FFFFFF 16 MB Expansion cards I/O cycles
$2000000 – $2FFFFFF 16 MB Expansion cards Synchronous
$3000000 – $33FFFFF 4 MB I/O controllers I/O space
$3400000 – $35FFFFF 2 MB ROM (low) Read only
$3600000 – $37FFFFF 2 MB ROM (high) Read only
$3800000 – $3FFFFFF 8 MB ROM (expansion) Read only
Hardware Specifications
ARM2 Processor Details
Feature Specification Notes
Architecture 32-bit RISC 26-bit address space
Registers 27× 32-bit 16 general + PC + status
Pipeline 3-stage Fetch, decode, execute
Cache None Direct memory execution
Instructions Fixed 32-bit Conditional execution
Modes 4 processor modes User, IRQ, FIQ, Supervisor
Performance 4 MIPS @ 8 MHz 0.5 instructions per clock
VIDC (Video Controller)
The VIDC1a provided advanced video capabilities:
Function Specification Implementation
Palette 4096 colours 12-bit RGB (4 bits per channel)
Sprites Hardware pointer 32×32 pixels, 3 colours
DMA Video, cursor, sound Cycle-stealing from RAM
Pixel rates 8, 12, 16, 24 MHz Software programmable
Sync generation H/V sync Programmable timing
Sound channels 8 stereo Logarithmic DAC
Display Modes
Mode Resolution Colours Refresh Memory Used
0 640×256 2 50 Hz 20 KB
1 640×256 4 50 Hz 40 KB
2 640×256 16 50 Hz 80 KB
8 640×256 4 50 Hz 40 KB
9 640×256 16 50 Hz 80 KB
10 640×256 256 50 Hz 160 KB
11 640×512 2 50 Hz 40 KB
12 640×512 16 50 Hz 160 KB
13 640×512 256 50 Hz 320 KB
15 640×512 16 50 Hz 160 KB
18 640×512 2 75 Hz 40 KB
19 640×512 4 75 Hz 80 KB
20 640×512 16 75 Hz 160 KB
21 640×512 256 75 Hz 320 KB
23 1152×896 Mono 75 Hz 132 KB
Input/Output
Internal Expansion
The A3000 provided limited internal expansion:
Slot Type Purpose Compatibility
RAM expansion 4× SIMM sockets Up to 4 MB total 256K×9 or 1M×9 SIMMs
Mini podule Proprietary connector Internal expansion Network cards, SCSI
Serial upgrade 20-pin header RS423/RS232 Optional 6551 ACIA
User port 20-pin IDC Digital I/O BBC Micro compatible
Econet 5-pin DIN Network Optional module
External Ports
Port Connector Function Signals
Monitor 15-pin D-sub Analogue RGB R,G,B, H/V sync
Serial 9-pin D-sub RS423 TxD, RxD, CTS, RTS
Parallel 25-pin D-sub Centronics 8-bit data + control
Mouse 9-pin mini-DIN Quadrature X/Y movement, 3 buttons
Keyboard Built-in Matrix scan 102-key extended
Headphones 3.5mm jack Stereo audio 8-bit log DAC output
Econet 5-pin DIN Network Clock, data (optional)
Floppy Drive System
The A3000 included an internal 3.5" floppy drive:
Specification ADFS Format DOS Format
Capacity 800 KB (D) / 1.6 MB (E) 720 KB / 1.44 MB
Sectors/track 5 (D) / 10 (E) 9 / 18
Tracks 80 80
Sides 2 2
Sector size 1024 bytes 512 bytes
Controller WD1772 @ 8 MHz WD1772
Data rate 250 kbps 250/500 kbps
Sound System
The VIDC provided sophisticated audio:
Audio Specifications
  • Channels: 8 independent stereo channels
  • Sample rate: Variable up to 48 kHz
  • Resolution: 8-bit logarithmic (µ-law)
  • DMA: Automatic buffer refill
  • Stereo positioning: 7 positions per channel
  • Output: Internal speaker + headphone jack
Sound DMA System
  • Buffer size: 16 bytes per channel
  • Interrupt: On buffer empty
  • Latency: < 1ms at 20 kHz sample rate
  • Total bandwidth: 384 KB/s maximum
Power Supply
Internal switched-mode PSU specifications:
  • Input: 220-240V AC, 50 Hz
  • Output voltages:
* +5V @ 4A (logic)
* +12V @ 1A (drives)
* -5V @ 100mA (serial)
  • Power consumption: 35W typical, 45W maximum
  • Cooling: Passive convection
ROM Software
RISC OS 2.00/3.00
The 2 MB ROM contained:
  • RISC OS kernel: Memory management, task switching
  • Desktop: WIMP environment (Windows, Icons, Menus, Pointer)
  • Filing systems: ADFS, DFS, NetFS, RamFS
  • BASIC V: Enhanced BBC BASIC with assembler
  • Applications: Edit, Paint, Draw, Configure
  • Fonts: Trinity, Homerton, Corpus (outline fonts)
  • Printer drivers: Dot matrix, inkjet, laser support
ROM Organization
Address Size Contents
$3400000 512 KB RISC OS kernel and modules
$3480000 512 KB Desktop and WindowManager
$3500000 512 KB Applications (Draw, Paint, Edit)
$3580000 512 KB Fonts and printing system
ARM250 Variant
Later A3000 models used the ARM250 integrated processor:
Feature ARM2 System ARM250 System
Chip count 4 (ARM2, MEMC, VIDC, IOC) 1 (ARM250)
Clock speed 8 MHz 12 MHz
Power consumption 8W (chips only) 3W
Cache None 4 KB unified
Manufacturing 3µm 1.5µm CMOS
Cost Higher 60% reduction
Technical Limitations
Limitation Cause Impact
No hardware FPU Cost reduction Slow floating point via software
26-bit addressing ARM2 design 64 MB address space limit
Single expansion slot Case constraints Limited upgrade options
No SCSI interface Cost reduction External SCSI pods required
8-bit sound VIDC limitation Lower quality than CD audio
No genlock Consumer positioning No video production capability
Known Hardware Issues
Power Supply Problems
  • Capacitor failure: Switchmode PSU capacitors dry out after 30+ years
  • Voltage drift: +5V rail drops causing system instability
  • Thermal stress: Poor ventilation causes PSU overheating
Battery Leakage
  • CMOS battery: 3.6V NiCd prone to leaking alkaline electrolyte
  • PCB damage: Battery leakage corrodes nearby traces
  • Clock failure: System loses time and configuration
Keyboard Issues
  • Membrane failure: Key bounce and non-response
  • Controller chip: 8051 microcontroller failures
  • Cable stress: Ribbon cable fractures at hinge point
Floppy Drive
  • Head alignment: Drift causes read errors
  • Belt deterioration: Drive belt turns to sticky mess
  • Capacitor leakage: Drive PCB capacitors fail
Manufacturing Variants
Model Processor ROM Version Production Period
A3000 (early) ARM2 + support chips RISC OS 2.00 May 1989 - Dec 1989
A3000 (mid) ARM2 + support chips RISC OS 2.01 Jan 1990 - Jun 1990
A3000 (late) ARM250 RISC OS 3.00 Jul 1990 - Dec 1991
A3000 (final) ARM250 RISC OS 3.10 Jan 1991 - May 1991
Memory Timing
MEMC memory controller timing:
  • Page mode: 2-1-1-1 cycles for sequential access
  • Random access: 4 cycles (N-cycle)
  • Video DMA: Steals 1 in 4 cycles during active display
  • Sound DMA: On-demand, priority over CPU
  • Refresh: 128 cycles every 4ms
Performance measurements:
  • Sequential read: 16 MB/s
  • Random read: 8 MB/s
  • Video bandwidth: 4 MB/s (mode 13)
  • Effective CPU bandwidth: 12 MB/s
Critical maintenance includes replacing the CMOS battery before leakage occurs, cleaning the case ventilation slots to prevent overheating, and checking the PSU capacitors for bulging or leakage. The keyboard membrane should be inspected for wear, and the floppy drive requires periodic cleaning and lubrication. Internal dust should be removed with compressed air, particularly around the processor and PSU.
Common faults include startup failures (check PSU voltages and CMOS battery), corrupted display (VIDC timing or RAM faults), and floppy drive errors (clean heads, replace belt). The "Machine startup held" message indicates CMOS corruption requiring battery replacement. Intermittent crashes often result from PSU capacitor degradation or thermal issues.
Essential capacitors requiring replacement:
  • PSU primary: 220µF 200V, 47µF 50V
  • PSU secondary: 2200µF 16V, 1000µF 16V (×2)
  • Motherboard: 100µF 16V (×4), 47µF 16V (×6)
  • Floppy controller: 10µF 25V (×3)
Expansion Options
Internal Mini-Podule
Compatible expansion cards:
  • Econet module: Network interface
  • SCSI interface: Hard drive controller
  • MIDI interface: Musical instrument connectivity
  • User port: Digital I/O interface
External Expansions
  • External podule backplane: Adds 2-4 standard podule slots
  • Hard drive podule: SCSI or IDE interfaces
  • Genlock podule: Video synchronization
  • Ethernet podule: 10Base2/10BaseT networking
