Apple LaserWriter II SC
Revision as of 18:29, 14 September 2025 by Josh (talk | contribs)
The Apple LaserWriter IISC was an entry-level laser printer in the LaserWriter II series, released in January 1988 at US$2,999. Unlike other LaserWriter models, the IISC eliminated PostScript support and LocalTalk networking to reduce costs, instead using SCSI for connectivity and relying on the host Macintosh's QuickDraw to rasterize pages. The printer used a Canon LBP-SX print engine and featured a slower Motorola 68000 processor running at 7.45 MHz with only 1 MB of RAM. The IISC included dual SCSI ports for daisy-chaining and an ADB port for future expansion that was never utilized. The printer was discontinued in July 1990, replaced by the Personal LaserWriter SC.
Apple LaserWriter IISC (1988)
Type Laser printer
Discontinued July 1, 1990
Price US$2,999 (1988 retail)
Interface SCSI (dual ports), ADB
Compatible Macintosh with SCSI
Dimensions 8.7" H × 20.2" W × 18.7" D
Weight 45 lbs (20.4 kg)
Model M6000
Power 900W maximum, 90-126V/50-60Hz
Technical Specifications
Physical Specifications
  • Dimensions: 8.7" H × 20.2" W × 18.7" D (221 × 513 × 475 mm)
  • Weight: 45 lbs (20.4 kg)
  • Operating temperature: 50°F to 90°F (10°C to 32°C)
  • Humidity: 20% to 80% non-condensing
  • Acoustic noise: 48 dBA operating
Performance
  • Print speed: 8 pages per minute
  • Resolution: 300 × 300 dpi
  • First page out: Approximately 35 seconds
  • Engine life: 300,000 pages rated
  • Duty cycle: 3,000 pages per month recommended
Power Requirements
  • Input voltage: 90-126V AC (auto-ranging)
  • Frequency: 50-60 Hz
  • Power consumption: 900W maximum
  • Current draw: 7.5A maximum
  • Heat output: 3,078 BTU per hour
System Architecture
Processor and Memory
The LaserWriter IISC used significantly reduced processing power compared to PostScript models:
Central Processing Unit:
  • CPU: Motorola MC68000
  • Clock speed: 7.45 MHz (slowest in LaserWriter line)
  • Data bus: 16-bit
  • Address bus: 24-bit
Memory Configuration:
  • ROM: 16 KB (minimal boot ROM only)
  • RAM: 1 MB total (fixed)
 * No separate workspace RAM
 * Frame buffer shared with system memory
  • RAM type: 120ns DRAM (4 × 256 KB chips)
  • RAM slots: 4 (fully populated)
  • Memory expansion: None possible
Controller Board Design
The IISC controller board was simplified compared to PostScript models:
  • Page description: QuickDraw host-based rendering
  • Font handling: No built-in fonts
  • Graphics processing: Bitmap reception only
  • SCSI controller: NCR 5380 or compatible
  • Interface logic: Minimal glue logic
QuickDraw Printing
Unlike PostScript LaserWriters, the IISC relied entirely on the host Macintosh:
Printing Process:
  1. Macintosh renders page using QuickDraw
  2. Bitmap transmitted via SCSI
  3. Printer receives and prints bitmap directly
  4. No processing or interpretation in printer
Font Requirements:
  • System 6: Adobe Type Manager (ATM) for scalable fonts
  • System 7: TrueType fonts supported natively
  • Bitmap fonts: Scaled by host, quality dependent on size
Canon LBP-SX Engine
The IISC used the improved Canon LBP-SX engine, shared with all LaserWriter II models:
Engine Specifications:
  • Technology: Laser xerography (electrophotographic)
  • Photosensitive drum: Organic photoconductor (OPC)
  • Laser type: Semiconductor laser diode
  • Developer system: Single-component toner
  • Fusing: Heat roller system
  • Paper path: Straight-through design
Improvements over LBP-CX:
  • Reduced size and weight
  • Improved paper handling
  • Better reliability
  • Quieter operation
Consumables
  • Toner cartridge: Apple M6002 or HP 92295A
  • Yield: Approximately 4,000 pages at 5% coverage
  • Drum life: Integrated with toner cartridge
  • OPC drum: Longer life than LBP-CX
  • Paper tray: 250-sheet capacity letter/legal cassette
  • Manual feed: Single-sheet bypass
Interfaces
SCSI Interface
The IISC was unique among LaserWriters in using SCSI as its primary interface:
SCSI Specifications:
  • Controller: NCR 5380 or compatible
  • SCSI version: SCSI-1 asynchronous
  • Transfer rate: Up to 5 MB/s theoretical (1-2 MB/s typical)
  • Connectors: Two DB-25 female ports
  • Termination: Internal termination when at chain end
  • Cable length: Maximum 6 meters total chain
SCSI Configuration:
  • SCSI ID: Set via DIP switches (0-6 usable)
  • ID 7: Reserved for self-test mode
  • Daisy-chaining: Supported via dual ports
  • Parity: Not implemented
SCSI ID DIP Switch Settings:
ID SW1 SW2 SW3 Function
0 OFF OFF OFF Normal operation
1 ON OFF OFF Normal operation
2 OFF ON OFF Normal operation
3 ON ON OFF Normal operation
4 OFF OFF ON Normal operation
5 ON OFF ON Normal operation
6 OFF ON ON Normal operation
7 ON ON ON Self-test mode
ADB Port
The IISC included an Apple Desktop Bus port that was never utilized:
ADB Specifications:
  • Connector: 4-pin mini-DIN
  • Purpose: Reserved for future expansion
  • Implementation: Non-functional in production units
  • Planned uses: Unknown (possibly status display or control panel)
Missing Interfaces
Unlike other LaserWriter II models, the IISC lacked:
  • LocalTalk/AppleTalk networking
  • RS-232 serial port
  • RS-422 serial port
  • Ethernet (never available on any LaserWriter II)
Paper Handling
Input Specifications
  • Standard cassette: 250 sheets
  • Manual feed: Single sheets
  • Paper sizes: Letter, Legal, A4, Executive
  • Paper weight: 16-28 lb bond (60-105 g/m²)
  • Media types: Plain paper, transparencies, envelopes, labels
Output Specifications
  • Output tray: 250-sheet capacity face-down
  • Stacking: Sequential page order
  • Duplex: Manual duplex only
Diagnostic Features
Self-Test Mode
Setting SCSI ID to 7 activated self-test mode:
  • Printer attempts to print test page on power-up
  • Test page shows configuration and status
  • No computer connection required
  • Useful for troubleshooting hardware issues
Status Indicators
Front panel LEDs indicated printer status:
  • Ready (green): Solid when ready to print
  • Paper (amber): Paper out or jam
  • Service (red): Service required
  • Two red lights blinking: Common failure mode
Error Conditions
Common error states indicated by LED patterns:
  • Continuous red blinking: Controller board failure
  • Alternating amber/red: Print engine problem
  • All lights on: Power supply issue
  • No lights: Fuse blown or power supply dead
Driver Software
Macintosh System Requirements
  • Minimum OS: System 6.0.3
  • Recommended: System 7.0 or later
  • RAM: 2 MB minimum, 4 MB recommended
  • SCSI: Built-in or expansion card
Driver Installation
The IISC required specific printer drivers:
  • LaserWriter IISC driver: Included with printer
  • Personal LaserWriter SC driver: Sometimes compatible
  • Chooser extension: Required for printer selection
  • Font support: ATM or TrueType required for quality output
Printing Process
  1. Select LaserWriter IISC in Chooser
  2. Application sends QuickDraw commands to driver
  3. Driver renders page to bitmap
  4. Bitmap compressed and sent via SCSI
  5. Printer receives and prints bitmap
Common Issues and Maintenance
Known Problems
Common IISC Failures
Component Symptoms Cause Repair
DC controller Two red lights blinking Capacitor failure Recap board
Logic board No communication Bad capacitors (3 total) Replace capacitors
SCSI termination Intermittent connection Termination issues Check SCSI chain
Power supply No power or cycling Capacitor failure Replace all electrolytics
Fuser assembly Poor toner adhesion Worn heating element Replace fuser
Scanner motor Horizontal lines Motor failure Replace motor assembly
Capacitor Issues
The IISC logic board contained only three electrolytic capacitors, but failure was common:
  • Symptoms: Two blinking red lights, no response
  • All three capacitors should be replaced preventively
  • Use 105°C rated replacements
SCSI Troubleshooting
Connection Issues:
  • Verify unique SCSI ID (0-6)
  • Check cable quality and length
  • Ensure proper termination
  • Test with printer as only SCSI device
Driver Problems:
  • Reinstall printer driver
  • Try Personal LaserWriter SC driver
  • Check SCSI chain for conflicts
  • Verify System software compatibility
Preventive Maintenance
Regular Service:
  • Monthly: Clean corona wires
  • 50,000 pages: General cleaning and inspection
  • 100,000 pages: Replace transfer corona
  • 200,000 pages: Replace fuser assembly
  • 300,000 pages: Major overhaul
Cleaning Procedures:
  • Use only toner-rated vacuum
  • Clean paper path with lint-free cloth
  • Wipe exterior with damp cloth
  • Avoid liquid near electronics
Upgrade Path
Controller Board Upgrades
The IISC could be upgraded to higher LaserWriter II models by replacing the controller board:
Available Upgrades:
  • IINT board: Added PostScript and LocalTalk
  • IINTX board: Added PostScript, LocalTalk, and SCSI font storage
  • IIf board: Added PostScript Level 2 and SCSI
  • IIg board: Added PostScript Level 2 and Ethernet
Upgrade Process:
  1. Remove IISC controller board
  2. Install replacement board
  3. Update printer drivers
  4. Configure for network if applicable
Cost Consideration: Upgrade boards were expensive, often costing more than a used printer
Service Information
DC Controller Settings
The DC controller board included service adjustments:
  • Print density: Potentiometer adjustment
  • Registration: Mechanical laser alignment
  • Service button: Initiates test page
Test Points
  • +5V DC digital logic
  • +24V DC motor supply
  • SCSI signal lines
  • High voltage (requires special probe)
Service Mode
  • Set SCSI ID to 7 for self-test
  • Hold service button on DC controller for test page
  • No other service modes available
Comparison with LaserWriter II Models
LaserWriter II Series Comparison
Feature IISC IINT IINTX IIf IIg
PostScript No Level 1 Level 1 Level 2 Level 2
Processor 68000 @ 7.45 MHz 68000 @ 11.5 MHz 68020 @ 16.67 MHz 68030 @ 25 MHz 68030 @ 25 MHz
RAM 1 MB fixed 2 MB min 2-12 MB 2-32 MB 5-32 MB
LocalTalk No Yes Yes Yes Yes
SCSI Yes (2 ports) No Yes (font storage) Yes Yes
Ethernet No No No No Yes
ADB Yes (unused) Yes (unused) Yes (unused) No No
Price (1988) $2,999 $4,599 $5,999 $3,599 (1991) $4,599 (1991)
Compatibility
System Requirements
  • System 6.0.3 minimum: Basic printing support
  • System 6.0.5 or later: Improved driver
  • System 7.0: TrueType font support
  • System 7.1: Best compatibility
  • System 7.5.x: Fully supported
Compatible Macintosh Models
Any Macintosh with SCSI port:
  • Macintosh Plus and later
  • Macintosh SE, SE/30
  • Macintosh II series
  • Macintosh LC series (with SCSI)
  • Macintosh Quadra series
  • PowerBook models with SCSI
Software Compatibility
  • Required QuickDraw-aware applications
  • No PostScript support
  • Limited graphics capabilities
  • Best with word processors and simple layouts
Service Manual
The LaserWriter II series service manual is available on the Apple Service Source page.
