Apple SuperDrive
Revision as of 12:55, 9 February 2026 by Josh (talk | contribs) (Created accessory article)
Template:Infobox Accessory
The Apple SuperDrive (originally Apple FDHD Drive, model G7287) was Apple's first high-density 1.44 MB 3½-inch floppy disk drive, introduced in 1989. The drive supported all Apple 3.5-inch formats (400K, 800K, 1.44 MB) plus IBM PC formats (720K, 1.44 MB), enabling cross-platform file exchange. The SuperDrive became standard equipment in every desktop Macintosh until the iMac eliminated the floppy drive in 1998.
Background
Following IBM's introduction of 1.44 MB high-density floppy drives in the PS/2 systems (1987), Apple adopted the format for cross-compatibility with MS-DOS and Windows systems. The SuperDrive used the industry-standard MFM (Modified Frequency Modulation) scheme for PC compatibility while maintaining backward compatibility with Apple's proprietary GCR (Group Coded Recording) variable-speed formats.
Naming
  • Apple FDHD Drive — Original name (Floppy Disk High Density)
  • Apple SuperDrive — Later marketing name (G7287)
Note: Apple later reused "SuperDrive" for optical drives, creating some confusion. This article covers the 1989 floppy drive.
Design
Physical Construction
The external SuperDrive uses the Platinum gray case design:
  • Matches Apple 3.5 Drive enclosure
  • Manual eject button (for Apple II compatibility)
  • Daisy-chain connector
  • DE-19 floppy port connection
Drive Mechanism
The internal Sony mechanism supports:
  • Double-sided, high-density media
  • Variable speed for Apple GCR formats
  • Fixed speed for PC MFM formats
  • Auto-inject (desktop) or manual-inject (PowerPC) variants
Format Support
Format Capacity Encoding Platform
Apple 400K 400 KB GCR variable Mac MFS
Apple 800K 800 KB GCR variable Mac HFS
Apple 1.44 MB 1.44 MB GCR/MFM Mac HFS
PC 720K 720 KB MFM fixed MS-DOS
PC 1.44 MB 1.44 MB MFM fixed MS-DOS/Windows
PC format reading requires appropriate system software (Apple File Exchange or later system versions with DOS mounting).
Compatibility
Requirements
Full SuperDrive functionality requires the SWIM (Sander–Wozniak Integrated Machine) floppy disk controller:
  • Present in Mac SE FDHD and later Macintoshes
  • Available via Apple II 3.5 Disk Controller Card
  • Not present in original IIGS, IIc Plus, or older Macs
Fallback Mode
When connected to systems with the older IWM (Integrated Woz Machine) controller:
  • Functions as standard 800K drive
  • No high-density or PC format support
  • No 1.44 MB capacity
Compatible Systems
Full Support (SWIM):
  • Macintosh SE FDHD and later (through Classic II)
  • Apple IIe (with 3.5 Disk Controller Card)
  • Apple IIGS (with 3.5 Disk Controller Card)
800K Mode Only (IWM):
  • Original Apple IIGS
  • Apple IIc Plus
  • Macintosh Plus, SE
Not Compatible:
  • Apple IIe without controller card
  • Macintosh 128K, 512K (no HFS support)
Parameter Value
Model number G7287
Capacity 400K, 800K, 1.44 MB (Apple); 720K, 1.44 MB (PC)
Media 3.5-inch floppy, DD or HD
Interface DE-19 floppy port
Transfer rate Variable (depends on format and zone)
Mechanism Sony auto-inject or manual-inject
Case color Platinum gray
Production History
  • 1989 — Introduced as Apple FDHD Drive
  • 1989 — Renamed SuperDrive
  • 1989 — Internal version standard in SE FDHD, Mac IIx, IIcx, IIci
  • 1991 — Apple II 3.5 Disk Controller Card enables Apple II support
  • 1994 — PowerPC Macs switch to manual-inject mechanism
  • 1998 — iMac G3 eliminates floppy drive entirely
The external SuperDrive was discontinued after the Classic II; subsequent Macs included internal drives or used the HDI-20 PowerBook external drive.
Maintenance
Head Cleaning
  • Use 3.5-inch head cleaning disk
  • Follow cleaning disk instructions
  • Do not over-clean (excessive cleaning wears heads)
Eject Mechanism
Auto-inject drives are prone to eject motor failure:
  • Symptoms: Disk won't eject, grinding noise
  • Solution: Manual eject via paperclip hole (emergency) or motor replacement
Common Issues
Problem Cause Solution
Won't read any disks Dirty heads Clean heads
Won't read HD disks Connected to IWM system Requires SWIM controller
Won't eject Eject motor failure Manual eject or repair
Reads Apple but not PC Software issue Install Apple File Exchange
Intermittent errors Worn drive Replace mechanism
Collecting
Identification
  • Model G7287 on label
  • Platinum gray case
  • DE-19 connector (19-pin)
  • Supports HD media (check disk hole sensor)
Condition Assessment
  • Mint: Original box, fully functional all formats
  • Excellent: Reads/writes all formats reliably
  • Good: Reads/writes most formats
  • Fair: Some formats unreliable
  • Poor: Non-functional
Testing
Test with multiple disk types:
  • 400K single-sided (if Mac supports MFS)
  • 800K double-density
  • 1.44 MB high-density
  • PC formatted 1.44 MB (with appropriate software)
Legacy
The SuperDrive represented Apple's embrace of industry-standard formats after years of proprietary designs. Its ability to read PC disks made the Macintosh more viable in mixed-platform environments.
The elimination of the floppy drive with the 1998 iMac was controversial at the time but prescient—CD-ROM and eventually USB drives supplanted floppy disks entirely.
  • Wikipedia — Macintosh External Disk Drive
  • Big Mess o' Wires — M0131 floppy drive documentation
  • EveryMac specifications
