Apple UniDisk 3.5
Revision as of 16:15, 9 February 2026 by Josh (talk | contribs) (Remove webpage screenshot image (will be replaced with proper device photo))
The Apple UniDisk 3.5 (model A2M2053) was Apple's first 3½-inch floppy drive for the Apple II series, released in September 1985—four months before the equivalent drive was available for the Macintosh. The UniDisk 3.5 was an "intelligent" or "smart" drive containing its own processor, RAM, and firmware, making it incompatible with the Macintosh despite using an identical Sony 800K mechanism.
Apple UniDisk 3.5
Apple UniDisk 3.5 (Model A2M2053)
Type Floppy disk drive
Discontinued 1990
Price US$499
Interface 19-pin D-sub (SmartPort)
Compatible Apple IIc (ROM upgrade), Apple IIe (Liron card), Apple IIGS
Dimensions ~200 mm × 175 mm × 50 mm
Weight ~800 g
Predecessor Disk II
Successor Apple 3.5 Drive
Model A2M2053
Background
Apple introduced the 3.5-inch format with the Macintosh in 1984, but the Apple II's 1 MHz 6502 processor was too slow to handle the higher bitrate of 3.5-inch drives using software-driven control. The UniDisk 3.5 solved this by incorporating its own controller within the drive.
Design
Smart Drive Architecture
The UniDisk 3.5 contains substantial internal electronics:
  • CPU: 65C02 at 2.0 MHz (GTE G65SC02P-2)
  • RAM: 2 KB static RAM (Hitachi HM6116LP-2)
  • ROM: 8 KB firmware (A2M2053-V1.0)
  • Controller: IWM (Integrated Woz Machine) chip
This architecture allows the drive to handle disk I/O independently, communicating with the Apple II via the SmartPort protocol.
Physical Construction
The drive uses Snow White design language:
  • Matching case color for Apple IIc
  • Daisy-chain pass-through connector
  • Manual eject button
  • Sony 800K double-sided mechanism
SmartPort Interface
The 19-pin D-sub connector uses the SmartPort protocol:
  • Drive handles low-level disk operations
  • Host computer issues high-level commands
  • Enables use with slower processors
  • Supports daisy-chaining multiple devices
Compatibility
Requires Special Hardware
The UniDisk 3.5 cannot use standard Disk II controllers:
Apple IIc:
  • Original IIc requires ROM upgrade (256K ROM)
  • Later production IIc includes compatible ROM
  • IIc Plus natively compatible
Apple IIe:
  • Requires Liron controller card (or later SWIM-based card)
  • Standard Disk II controller not compatible
Apple IIGS:
  • Native SmartPort support
  • However, Apple 3.5 Drive (A9M0106) operates faster
  • UniDisk 3.5 was intentionally slowed for Apple II compatibility
Not Macintosh Compatible
Despite using the same Sony mechanism as the Mac 800K drive, the UniDisk 3.5 is not compatible with any Macintosh. The internal controller circuitry can be bypassed to enable Mac compatibility, but this voids the "smart" functionality.
Format
Parameter Value
Capacity 800 KB
Sides Double-sided
Tracks 80 per side
Encoding GCR variable speed
File system ProDOS (Apple II), HFS (not recommended)
The 800K format matches the Macintosh format, enabling disk exchange between platforms when properly formatted.
Parameter Value
Model number A2M2053
Capacity 800 KB
Media 3.5-inch DD floppy
Internal CPU 65C02 @ 2.0 MHz
Internal RAM 2 KB
Internal ROM 8 KB
Mechanism Sony 800K double-sided
Case color Snow White (IIc matching)
Price (1985) US$499
Market Reception
The 3.5-inch format was not widely adopted by Apple II users (except IIGS owners):
  • Most commercial software remained on 5.25-inch disks
  • Larger installed base of Disk II drives
  • Required expensive controller card for IIe
  • ROM upgrade needed for original IIc
The IIGS, with its enhanced capabilities and native SmartPort support, was the primary market for 3.5-inch drives in the Apple II ecosystem.
Successor: Apple 3.5 Drive
The Apple 3.5 Drive (A9M0106, 1986) replaced the UniDisk 3.5:
  • Removed internal controller (cheaper)
  • Cross-platform (Mac and Apple II)
  • Only compatible with IIGS and IIc Plus
  • Faster operation on IIGS
The UniDisk 3.5 remained available for IIe and original IIc users who couldn't use the simpler Apple 3.5 Drive.
Maintenance
Head Cleaning
Use a 3.5-inch head cleaning disk periodically.
Firmware
The internal ROM can become corrupted or fail. Replacement ROMs are scarce; non-functional smart drives are often converted to "dumb" drives for Mac use.
Common Issues
Problem Cause Solution
Not recognized SmartPort not supported Verify compatible host
Read errors Dirty heads Clean heads
Intermittent Failing internal electronics Difficult repair
Slow operation Normal on Apple II IIGS operates faster
Collecting
Identification
  • Model A2M2053 on label
  • Snow White case (not Platinum)
  • "UniDisk 3.5" nameplate
  • 19-pin D-sub connector
Value Factors
  • Working internal electronics (smart functionality)
  • Original packaging
  • Condition of mechanism
UniDisk 3.5 drives command higher prices than Apple 3.5 Drives due to their smart drive capability and relative scarcity.
Testing
Test on appropriate system:
  • Apple IIc (with ROM upgrade)
  • Apple IIe (with Liron card)
  • Apple IIGS
Verify SmartPort functionality, not just basic disk operations.
  • Wikipedia — Macintosh External Disk Drive
  • wiki.apple2.org — A2 3.5 Drives
  • GitHub rigreco/UniDisk — UniDisk co-processor documentation
