Macintosh LC III
Revision as of 18:08, 9 February 2026 by Josh (talk | contribs) (Added infobox image)
The Macintosh LC III is a personal computer released by Apple on February 10, 1993.[1] The LC III addressed the main performance limitation of earlier LC models by implementing a full 32-bit data bus, providing a substantial performance improvement over the Macintosh LC II.[2]
Macintosh LC III
Macintosh LC III
TypePersonal Computer
ReleasedFebruary 10, 1993
DiscontinuedFebruary 14, 1994
Intro priceUS$1,349
CPUMotorola 68030 @ 25 MHz
Memory4 MB RAM (expandable to 36 MB)
Storage80 MB SCSI HDD, 1.44 MB SuperDrive
Display640×480 8-bit (512K VRAM) or 16-bit (768K VRAM)
Sound8-bit stereo input/output
Dimensions2.9" H × 12.2" W × 15.3" D
Weight8.8 lbs (4.0 kg)
OS / FirmwareSystem 7.1 – System 7.6.1
PredecessorMacintosh LC II
SuccessorMacintosh LC III+
CodenameVail, Elsie III
Model no.M1254
Model Variants
The LC III was sold as the Performa 450 in consumer markets with bundled software.
The LC III uses a Motorola 68030 processor running at 25 MHz with a full 32-bit data bus—a significant improvement over the 16-bit bus of the LC and LC II. This change substantially improved memory performance and overall system responsiveness.[3]
The LC III includes a socket for an optional Motorola 68882 FPU (Floating Point Unit), the first LC to offer FPU support.
The Gestalt ID for the Macintosh LC III is 27.
Memory and Storage
RAM Configuration
The LC III shipped with 4 MB of RAM standard, expandable to 36 MB. A significant change from earlier LCs: the LC III uses a single 72-pin SIMM slot instead of 30-pin SIMM pairs.
RAM Configurations
Configuration SIMM Required
4 MB 4 MB 72-pin SIMM (or 4 MB onboard)
8 MB 4 MB onboard + 4 MB SIMM
12 MB 4 MB onboard + 8 MB SIMM
20 MB 4 MB onboard + 16 MB SIMM
36 MB 4 MB onboard + 32 MB SIMM
Video RAM
The LC III includes 512 KB of VRAM onboard, expandable to 768 KB with a 256 KB VRAM SIMM:
  • 512 KB VRAM: 640×480 at 8-bit (256 colors)
  • 768 KB VRAM: 640×480 at 16-bit (thousands of colors)
The LC III contains 1 MB of ROM, double that of earlier LC models.
Storage Systems
Standard storage included:
  • 80 MB internal SCSI hard drive
  • 1.44 MB SuperDrive
Input/Output and Expansion
Port Configuration
  • 1× Apple Desktop Bus (ADB) port
  • 1× External SCSI (DB-25)
  • 1× Audio input (3.5mm stereo minijack)
  • 1× Audio output (3.5mm stereo minijack)
  • 2× Serial ports (Mini DIN-8)
  • 1× Video output (DA-15)
Expansion
The LC III features a single LC Processor Direct Slot (LC PDS) and an FPU socket (PGA) for the 68882 coprocessor.
For detailed maintenance practices including cleaning, PRAM battery management, and connector care, refer to the dedicated Macintosh LC III General Maintenance page.
A comprehensive troubleshooting guide addressing common issues with the Macintosh LC III is available on the Macintosh LC III Troubleshooting page.
Capacitor Replacement
The Macintosh LC III logic board contains surface-mount electrolytic capacitors that commonly fail due to age. Detailed replacement guidelines can be found on the Macintosh LC III Capacitor Replacement Guide page.
Important: The LC III has a known factory defect where capacitor C22 was installed with reversed polarity due to a silkscreen error. See the capacitor replacement guide for details.
Macintosh LC III Technical Specifications
Component Specification
CPU Motorola 68030 @ 25 MHz
FPU Optional 68882 (socket provided)
PMMU Integrated in 68030
Data Bus 32-bit
System Bus 25 MHz
ROM 1 MB
RAM 4 MB (max 36 MB)
VRAM 512 KB (max 768 KB)
  1. Macintosh LC III, Apple History—link(accessed 2026-02-09)
  2. Apple Macintosh LC III Specs, EveryMac.com—link(accessed 2026-02-09)
  3. Macintosh LC III, Low End Mac—link(accessed 2026-02-09)
