Macintosh Performa 6100
Revision as of 12:20, 10 February 2026 by Josh (talk | contribs) (Convert from redirect to standalone article with full specs)
The Macintosh Performa 6100 is the consumer-oriented version of the Power Macintosh 6100/60, released on November 1, 1994. It is the base model of the Performa 6100 series without a CD-ROM drive, differing from the Performa 6110CD only in the absence of the optical drive.
TypePersonal Computer
ReleasedNovember 1, 1994
DiscontinuedJuly 1, 1995
CPUPowerPC 601 @ 60 MHz
Memory8 MB RAM (expandable to 72 MB)
Storage250 MB SCSI HDD
DisplaySupports 640×480 at 16-bit color
SoundStereo 16-bit input/output, mono speaker
Dimensions3.4" H × 16.3" W × 15.6" D
Weight14 lbs (6.4 kg)
OS / FirmwareSystem 7.5 – Mac OS 9.1
PredecessorPerforma 475
SuccessorPerforma 6200CD
CodenamePiltdown Man
Model no.M1596
The Performa 6100 was the first PowerPC-based Performa, representing Apple's transition from the Motorola 680x0 architecture to the PowerPC platform in the consumer market.[1]
Differences from Performa 6110CD
The Performa 6100 differs from the Performa 6110CD in the following ways:
  • CD-ROM: Not included
  • Price: Lower entry price point
All other specifications are identical.
The Performa 6100 uses the PowerPC 601 processor running at 60 MHz on a 30 MHz system bus. The 601 was the first generation PowerPC chip developed jointly by Apple, IBM, and Motorola (the "AIM alliance"). It features a 32-bit architecture with a 64-bit data path and integrates the FPU on-die.
Cache Configuration
  • L1 Cache: 32 KB (16 KB data + 16 KB instruction)
  • L2 Cache: Optional 256 KB (cache slot on logic board)
Memory and Storage
RAM Configuration
Specification Details
RAM Type 72-pin FPM or EDO SIMMs
Minimum Speed 80 ns
Motherboard RAM 8 MB soldered
Maximum RAM 72 MB (136 MB with third-party 64 MB SIMMs)
RAM Slots 2 (matched pairs required)
Storage Systems
  • Hard Drive: 250 MB internal SCSI
  • Floppy: 1.44 MB SuperDrive (manual inject)
  • Interface: 50-pin internal SCSI, DB-25 external SCSI
Display and Graphics
Video output is provided through the HDI-45 connector. The system uses 640 KB of system RAM dedicated to video functions.
  • Standard Resolution: 640×480 at 16-bit color
  • Maximum Resolution: 832×624 at 8-bit color
  • VRAM: 640 KB (borrowed from system RAM)
For detailed maintenance practices, refer to the dedicated Macintosh Performa 6110CD General Maintenance page.
Detailed capacitor replacement guidelines can be found on the Macintosh Performa 6110CD Capacitor Replacement Guide page.
A comprehensive troubleshooting guide is available on the Macintosh Performa 6110CD Troubleshooting page.
  1. Macintosh Performa 6110CD, EveryMac.com—link(accessed 2026-02-10)
