Power Macintosh 6500 Capacitor Replacement Guide
Revision as of 13:39, 10 February 2026 by Josh (talk | contribs) (Created capacitor replacement guide for Power Macintosh 6500)
Replacing electrolytic capacitors (recapping) in your Power Macintosh 6500 is an important maintenance task for long-term reliability. Capacitors from the mid-1990s may leak, dry out, or fail, causing various system problems.
Capacitor Inspection
Before recapping, inspect the logic board and power supply for signs of capacitor failure:
  • Bulging Tops – The normally flat or slightly indented top of the capacitor is domed or bulging
  • Leaking Electrolyte – Brown or black residue around the base or top of capacitors
  • Corrosion or PCB Staining – Discoloration on the circuit board near capacitors indicates leakage
Symptoms of Capacitor Failure
Common symptoms that may indicate the need for recapping:
  • System won't power on or randomly shuts off
  • Audio distortion or crackling
  • Video artifacts or display problems
  • Random crashes or instability
  • System fails to boot reliably
Power Macintosh 6500 Capacitor List
Power Supply Capacitors
The power supply contains high-voltage capacitors. Exercise extreme caution.
⚠️ WARNING: Power supply capacitors can retain dangerous voltage even when unplugged. Allow adequate discharge time or use proper discharge procedures.
Logic Board Capacitors
The Power Macintosh 6500 logic board contains several electrolytic capacitors that should be replaced if showing signs of age or failure. Capacitor values and quantities vary by board revision.
Common logic board capacitors include:
  • Various values of 10µF to 1000µF
  • Voltage ratings typically 6.3V to 25V
  • SMD and through-hole types
Note: Consult board-specific documentation or visually identify capacitor values before ordering replacements.
  1. Discharge and Prepare
    • Unplug the system and wait at least 15 minutes
    • Remove the case cover and locate the logic board
    • Use a wrist strap to prevent ESD damage
  1. Document Capacitor Locations
    • Photograph the board before starting
    • Note polarity markings (negative stripe on capacitor, + or - on PCB)
  1. Remove Old Capacitors
    • Use a temperature-controlled soldering iron (recommended 350°C/660°F)
    • For through-hole: heat each lead and gently pull the capacitor free
    • For SMD: use hot air or carefully heat each end alternately
    • Use desoldering braid or pump to remove excess solder
  1. Prepare Pads
    • Clean pads with isopropyl alcohol and a brush
    • Check for lifted traces or pad damage
    • Apply fresh solder to tin the pads
  1. Install New Capacitors
    • Verify correct polarity (negative stripe to negative marking)
    • Use quality replacement capacitors rated for the same or higher voltage
    • Solder securely with minimal heat application time
  1. Trim and Inspect
    • Trim leads flush on through-hole capacitors
    • Check for solder bridges or cold joints
    • Use a multimeter to verify no shorts exist
  1. Clean and Test
    • Clean the board with isopropyl alcohol
    • Allow to dry completely
    • Reassemble and test the system
  • Temperature-controlled soldering iron (chisel tip recommended)
  • Desoldering pump or wick/braid
  • Fine solder (0.5mm–0.8mm diameter)
  • Isopropyl alcohol (90%+) and ESD-safe brush
  • Multimeter for continuity testing
  • Magnifying glass or loupe
  • Anti-static wrist strap
  • Safety glasses
Voltage Adjustment After Recap
After replacing capacitors, verify power supply output:
  • +5V rail: 4.85V – 5.15V
  • +12V rail: 11.9V – 12.7V
Additional Tips
  • Use quality Japanese-brand capacitors (Nichicon, Panasonic, Rubycon)
  • Match or exceed original voltage ratings
  • Match capacitance values exactly
  • Consider replacing all electrolytic capacitors at once for thorough restoration
  • Take photos throughout the process for reference
  • Work in a well-lit, clean environment
