Macintosh SE FDHD
Revision as of 13:47, 10 February 2026 by Josh (talk | contribs) (General Maintenance)
The Macintosh SE FDHD (FDHD = Floppy Disk High Density) is a compact Macintosh computer released on August 1, 1989.[1] It was the first compact monochrome Macintosh to include a high-density 1.44 MB "SuperDrive" floppy disk drive, replacing the 800K drive found in the original Macintosh SE.
Macintosh SE FDHD
Macintosh SE FDHD
ReleasedAugust 1, 1989
DiscontinuedOctober 15, 1990
Intro priceUS$3,700
CPUMotorola 68000 @ 8 MHz
Memory1 MB RAM (expandable to 4 MB)
Storage20 MB or 40 MB SCSI hard drive
Display9" monochrome CRT (512×342 pixels)
SoundMono 8-bit, 22 kHz
Dimensions13.6" H × 9.69" W × 10.9" D
Weight17.0 lbs (7.7 kg)
OS / FirmwareSystem 3.3 – 7.5.5
PredecessorMacintosh SE
SuccessorMacintosh SE/30
Model no.M5011
The SE FDHD shares the same chassis and overall design as the standard SE but incorporates the updated disk drive and ROM to support high-density floppy disks.
Hardware Overview
Processor and Memory
The SE FDHD uses a Motorola 68000 processor running at 8 MHz with a 16-bit data path. It ships with 1 MB of RAM and can be expanded to 4 MB using four 30-pin SIMM slots. RAM must be installed in matching pairs.
The system includes a 1.44 MB SuperDrive floppy disk drive that can read and write both 800K and 1.44 MB disks. Internal hard drive options include 20 MB or 40 MB SCSI drives.
Display
The built-in 9" monochrome CRT displays a resolution of 512×342 pixels.
Expansion
Like the standard SE, the FDHD features an SE PDS (Processor Direct Slot) for expansion cards such as accelerators or Ethernet adapters.
For detailed maintenance practices including cleaning, PRAM battery management, connector corrosion prevention, and voltage adjustments, refer to the dedicated General Maintenance page.
A comprehensive troubleshooting guide addressing no power, chime but no video, intermittent operation, Sad Mac errors, and floppy drive problems is available on the Troubleshooting page.
Detailed capacitor replacement guidelines can be found on the Capacitor Replacement Guide page.
  1. Macintosh SE FDHD Specs, EveryMac.com—link(accessed 2026-02-10)
